Question about Miele Dishwashers
My Miele WT 945 wont pump any water in and the warning light comes on. Where is the antiflood detector so i can check it is dried out
  • 1294 Answers
SOURCE: Miele WT 945 Washer Dryer - Spin not working + Water Inlet/Drain Light Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Your filter of the water inlet valve is accessible outside the machine; it is at the water entry point. Close your faucet & check this out; this gets clogged often.
Hope i am helpful...... Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 25, 2008
SOURCE: Miele G646SC Plus dishwasher Drainage / inlet warning light
I had the same problem a few days ago. I followed the instructions to clean the filter and check to see that the impeller was free to rotate in both directions. The problem persisted. After reading this thread, and a similar one on another site, I tried what mikeboerma suggested in "solution #3", and bingo, problem solved. The magic combination is to push and hold the on/off button and the start/stop button.
Posted on Mar 22, 2009
  • 5 Answers
SOURCE: Miele G646 dishwasher keeps trying to pump out
Had a similar problem with an 846, but with the inlet outlet lamp flashing. the bottom tray had filled with watedr froma dodgy seal. I switched off and disconnected the electricity. Removed the bottom front cover below the door (2 screws behind the pretty kickboard which also had to come off). The bottom of the machien was a big puddle. I dried this out with paper twowel, put the machine back together and it ran fine. I am going to replace the pump seals now as the machine seems otherwise OK.
Good luck with yours. rupertvdpP
Posted on Aug 11, 2009
Testimonial: "true, bottom tray was wet fron small split in waste pipe taped it up and have ordered new one thanks for the info job well done"
  • 14 Answers
SOURCE: Miele dishwasher drying problem
you need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
Posted on Aug 26, 2009
joe_lishman
  • 192 Answers
SOURCE: Inlet/drain light flashes on miele dishwasher and
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Posted on Jan 17, 2010
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Why is my Miele WT945 front lader washer dryer not taking water in properly or at all?
you may try cleaning the inlet screen by removing the fill hose.then pry the ccreen out with a small screwdriver.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
May 05, 2014 | Miele WT945 Front Load Washer / Dryer
Main internal fuse location for Miele WT 945
Hi Dear.
As I know,your machine does not have replaceable fuse in it. Thanks.
Jan 04, 2012 | Miele WT945 Front Load Washer / Dryer
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is this...
Open the door manually.
Open the drain flap on front left bottom
The door release can be seen hanging, pull the cord, the door will open.
Close and open the door 2 or 3 times and your machine will work ok.
S. Datta
Bickley
Mar 06, 2011 | Miele WT945 Front Load Washer / Dryer
Have a zanussi dishwasher ZDF601K trouble shooter says -,antiflood device activated call engineer is there anything I can try ?
antiflooddevice bottom of machine it detects water and shuts machine down or pump keeps runnining ,clear water from bottom of machine and dry check for leaks UN PLUG FROM MAINS WHILE YOU CHECK IT AND DRY AREA
Jan 22, 2011 | Zanussi Dishwashers
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
May 19, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Aeg favorite 645
to check the antiflood, remove the bottom front panel and the bottom tray is exposed. if there is water in the tray, this will actuate the antiflood switch. just mop out the water and the machine will run. turn off from mains when you do this.
however, this will not give a hum. the antiflood switch just turns on the drain pump.
if no water found then get back to me
Oct 02, 2008 | Dishwashers
Feb 24, 2008 | Miele WT945 Front Load Washer / Dryer
Dishwashers Logo
21 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
