Nano portable air conditioner cf14000e I need new hose with fixture and window slide
SOURCE: Parts for Fedders Portable Air conditioner model # SFPEB08F2A
there are two separate solid plastic pieces between the hose and the body of the unit
i have a hose but I am about to donate the unit
Posted on Jul 20, 2008
  • 10865 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
you can contact the company directly at
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
good luck with this.
Posted on Feb 14, 2009
  • 134 Answers
You need to go here
SOURCE: beaumark portable air conditioner operation
Beaumark air conditioners are made by GE…head over to their site and download a manual for their air conditioners - they are very similar.
Posted on Jul 06, 2010
SOURCE: danby dpac7008 portable air conditioner
how do u turn on a silhouetto dandy floor air condition
Posted on Sep 04, 2010
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
The air hose on my Aussie Air N13174 portable air conditioner is broken. Where can I buy hose replacement?
take a pieceof the old hoe with you and go to a hardware store and have them cut you a new piece.
Jan 23, 2015 | Heating & Cooling
Amcor KF9000E portable air conditioner manual
My amcor kf9000e has stopped blowing cool air. What could be wrong with it?
May 18, 2012 | Amcor AF9000E Portable Air Conditioner
Hello, I need the hose to drain water outside that fits the fridgidair portable air conditioner #FAPO9EP1Z1. Is there another small tube or is there any other hoses or vents that I need? I don't see...
impreston - with out the following parts , you really don't have "just the air conditioner."
1- Flexible Exhaust Hose
2- Hose Adapters
1- Sliding Window Kit
1-Foam Window Seal
1-Remote Control
The drain hose is something you supply. A garden hose, no longer than 5 feet will do if you want it to be a continusos drain, rather than drain into the water collectiong bucket. But, without the first 4 items lister above, you won't be able to operate the unit.
Here is a link that may be of some help to you, since you don't have an Owner's Manual.
You will beed to contact Frigidaire (1 -800-374-4432 ) for the parts you're missing.
Hope this helped you. Please let me know. Thanks.
Jul 12, 2011 | Frigidaire FAP094P1Z Portable Air...
Do not know how to connect hose on portable air conditioner to the air conditioner and window
Joni, if we new the brand and model number of your portable AC unit, we could probably help you.
Please advise. Thanks.
Jun 15, 2011 | Heating & Cooling
I need to get an on-line manual/problem w/hoses thru window
Jun 01, 2010 | Amana AP095R Portable Air Conditioner
Parts for Amcor Portable Air Conditioner
Your parts can be found at amazon, click here and take a look: Finally charging for our multi device world. I hope this was helpful. Cheers
Apr 30, 2010 | Amcor AF9000E Portable Air Conditioner
Hot air coming out of back
portable air conditioners mainly have two hoses one hose is exhaust thats the one that is blowing hot air. the one pulling is return.. the hot air blowing out should be exhausted to the outside. the blowing air needs a hose and to be laid out a window the back should have model and serial maybe product number. the two holes are either 4 inch or three inch and most portable units other than hand me downs come with a window frame that allows the hot exchanged air to go outside and cooler air to be used for heat exchange.
May 28, 2009 | Maytag NMPEB08F2A Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
