Question about Refrigerators
Temp control frozen - Refrigerators
I have a FF82 model and it is starting to freeze food. there is some frozen water in the bottom. The temp control dial doesnt move. What shoudl I do to fix this.
Temp dial shouldn't have a setting that would freeze your refrigerator side products anyway. Make sure damper to fridge isn't stuck or frozen which cuts off air from freezer to fridge when temp is achieved. If all working properly for sure. Sounds like bad temp control.
Oct 25, 2016 | Refrigerators
Accidently entered incorrect code in temperature control pad and now the panel is frozen and registers 56 degrees on both fresh and frozen Frigidaire Gallery refrigerator FGHN2844LF2.
You have entered the control into "Sb," which is "Sabbath mode."
Hold the temp up and temp down buttons simultaneously for 5 seconds and the "56" should disappear...
Jul 18, 2016 | Frigidaire Refrigerators
Problem getting into diagnostic mode
refrigerators are not supposed to be set below about 40 degrees . foodistobe kept cold not frozen there
Apr 27, 2012 | GE Refrigerators
I have an arcticaire a40ra model which usually holds temp at 4C. I came into work this morning and everything is frozen. I don't see a thermostat to adjust or reset temp. How do i adjust the temp?
There has to be a control somewhere on the fridge. Some newer models have digital controls located on the outer doors panels, or its going to be inside. Read your owners manual
www.FixMyFridge.net
Mar 08, 2010 | Refrigerators
Kenmore 253.74813404 not cold enough - ice cream soft - outside in garage - 35 - 65 degrees now - almost 5 yrs old - evap coil not frozen so it is defrosting - perhaps temp control ?
IS THE TEMP IN YOUR GARAGE ABOVE 40 DEG. THE THERMOSTAT WILL NOT CLOSE IF THE AMBIENT TEMP IT TOO LOW, OTHER THAN THAT IF ITS NOT RUNNING IT POSS. COLD CONTROL
Jan 13, 2010 | Kenmore Refrigerators
Frozen food in the refrigerator
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 31, 2009 | LG LFX25960ST Stainless Steel French Door...
Refrigerator temperature running too high
Oct 03, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker is not making ice, yet the water dispensor works fine
Check the temp of the freezer. Is the ice cream frozen hard? If not the temp has to be corrected first. Check to see if the freezer control is set too warm. You CANNOT make ice if the freezer control is set too warm
Aug 23, 2009 | Kenmore Refrigerators
Freezer does not seem to keep things frozen in my refridgerator .
probable reason for this is that the thermostat controls freezer temp and freezer follows suit.
if temp in your garage is low ie in winter, then the fridge doesn't need to switch on and the freezer temp rises.
i know this sounds barmy but it is true
Nov 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Frozen Fridge
the temperature controlis most likely bad since you cant control it. the control is the knob you turn to set the temp with. you should be able to replace it yourself fairly easily.
Dec 20, 2007 | Refrigerators
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
