Question about HP Boating
Replace pull cord 2 hp eska outboard - HP Boating
    Top Expert:
  • HP Master
  • 49,994 Answers
Saddleethod as any pull start engine
remove the recoil section from the engine and replace the cord
it not sure how to do it , take the recoil section to a service shop
Posted on May 17, 2017
We have an old not sure how old suzuki 14 hp outboard which does not have a kill cord . Can we retro fit ? Thanks
Symply replace the actual engine stop switch with a kill cord type.
Every Suzuki model should fit...
Aug 12, 2017 | Suzuki Boating
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
What is 2 cycle mix for 5.0 hp Eska out board motor
if it's an older one I would suggest about 40:1 but be careful and please use a certified marine oil for this... oh and next time... find the right catagory
Aug 16, 2014 | Garden
How i thread my pull cord on my 6.0 HP outboard evinrude
How old? If it is the old system that looks like a spiral ramp, very carefully. I knot one end, feed it into the hole at the top and then feed it around without taking apart the starter. The spring is a pain to work with.
May 18, 2014 | Clymer EvinrudeJohnson Outboard Shop...
No water flowing out my 40hp envenrude outboard water exaust port
Plossibly clogged intakes (grim in intakes) or thermostats not opening. I would suggest pulling the lower unit and then your thermostat housing and use a water hose to back-flush it out. Also check the thermostats in boiling water to make certain opening.
May 09, 2014 | Clymer Evinrude/johnson 2-40 Hp Outboards...
Yamaha 4HP outboard - cannot pull starter cord - jammed.
Engine or gearcase seized...
Remove the recoil starter ( 3 bolts and the startingear link)
If you can turn the flywheel slightly: Gearcase seized
If you can't turn the flywheel at all: Engine seized.
In both cases: If you can't disassemble and have the job done yourself, forget that motor...
Dec 09, 2012 | Clymer Marine Maintenance and Repair...
15 hp crysler outboard motor pull start diagram
You will need a special tool to do that job. It is just a 10/24 long bolt bent to form a crank and a nut spun on it and soldered or double nutted to keep it in place.
Remove the top slotted bolt and replace it with the tool.
Release the pressure on the cross pin by back winding the spring- and remove the cross pin.
The starter gear will slide up the shaft after you remove the flywheel. Or you can loosen the 2 screws on the top bracket.
Now release the tension on the spring and pull the core from the spool.
The spool comes out and the rope must be freed from the guide.
The reverse is about the same- feed the cord and spool it up attach the handle.
Replace the top bracket if you removed it. Put on the starter gear
grease the spring with light grease inspect the nylon base and coil anchor (tiny brass cinch squeezed on to the stub of spring coming from the base.
Now -with the tool- wind the spring backward about 5 times and insert the pin thru the gear and into the shaft. With the tool in place pull the starter thru several times to see if the tension is right and you didn't forget the rope guide..
Replace the original screw to hold the pin in place.
This works for most pop-up starters.
Oct 20, 2011 | Light Outboard Motor Boat Bass Fishing...
My 1988 ( i think) 6hp Johnson outboard motor is always hard to start if it is cold. It can take 10 - 15 minutes of pulling on the cord to start it when cold but will start first go every time once it has...
I would suggest you replace the 2 coils. Also, is choke closing properly? The carb if never rebuilt, could cause this problem. A carb kit and 2 coils should not cost much, maybe 20 each for coils and 17 for carb kit. Make sure carb is adjusted properly with outboard in water and warmed up. Mixture screw should be turned in slowly clockwise until engine just pops(lean). Then slowly open it apprx. 1/8 turn. This will aid engine in starting next time. Also, make sure primer bulb firms up when squeezed.
Feb 09, 2011 | Boating
Boating Logo
24 people viewed this question
Top HP Boating Experts
vince
Are you a HP Boating Expert? Answer questions, earn points and help others
