Question about Boating
How to replace pull cord on eska outboard motor
2 Suggested Answers
  • 48313 Answers
SOURCE: Replace pull cord 2 hp eska outboard
saddleethod as any pull start engine
remove the recoil section from the engine and replace the cord
it not sure how to do it , take the recoil section to a service shop
Posted on May 17, 2017
May 17, 2017 | HP Boating
Where is rhw spark plug on my wee boat motor.Where can I get manual for it with diagram of parts on motor. The only thing I can identify is the pull cord and lever for choke- I think.Any help much app
see this video
see the orange thick wire your outboard may be similar notice the spark plug at the back of the motor near the bottom of the engine at the end of the thick orange cable. I recommend looking for a similar thick electrical cable and follow it to where it ends up.
Nov 02, 2014 | Boating
How do I start my Johnson colt outboard motor
check for gas, pull choke lever out , prime if there is a primer bulb , then pull the rope . preferrably with the motor in the water on a boat . or at least in a tank of water so you don't ruin the water pump.
Nov 01, 2014 | Boating
How i thread my pull cord on my 6.0 HP outboard evinrude
How old? If it is the old system that looks like a spiral ramp, very carefully. I knot one end, feed it into the hole at the top and then feed it around without taking apart the starter. The spring is a pain to work with.
May 18, 2014 | Clymer EvinrudeJohnson Outboard Shop...
Yamaha 4HP outboard - cannot pull starter cord - jammed.
Engine or gearcase seized...
Remove the recoil starter ( 3 bolts and the startingear link)
If you can turn the flywheel slightly: Gearcase seized
If you can't turn the flywheel at all: Engine seized.
In both cases: If you can't disassemble and have the job done yourself, forget that motor...
Dec 09, 2012 | Clymer Marine Maintenance and Repair...
15 hp crysler outboard motor pull start diagram
You will need a special tool to do that job. It is just a 10/24 long bolt bent to form a crank and a nut spun on it and soldered or double nutted to keep it in place.
Remove the top slotted bolt and replace it with the tool.
Release the pressure on the cross pin by back winding the spring- and remove the cross pin.
The starter gear will slide up the shaft after you remove the flywheel. Or you can loosen the 2 screws on the top bracket.
Now release the tension on the spring and pull the core from the spool.
The spool comes out and the rope must be freed from the guide.
The reverse is about the same- feed the cord and spool it up attach the handle.
Replace the top bracket if you removed it. Put on the starter gear
grease the spring with light grease inspect the nylon base and coil anchor (tiny brass cinch squeezed on to the stub of spring coming from the base.
Now -with the tool- wind the spring backward about 5 times and insert the pin thru the gear and into the shaft. With the tool in place pull the starter thru several times to see if the tension is right and you didn't forget the rope guide..
Replace the original screw to hold the pin in place.
This works for most pop-up starters.
Oct 20, 2011 | Light Outboard Motor Boat Bass Fishing...
My 1988 ( i think) 6hp Johnson outboard motor is always hard to start if it is cold. It can take 10 - 15 minutes of pulling on the cord to start it when cold but will start first go every time once it has...
I would suggest you replace the 2 coils. Also, is choke closing properly? The carb if never rebuilt, could cause this problem. A carb kit and 2 coils should not cost much, maybe 20 each for coils and 17 for carb kit. Make sure carb is adjusted properly with outboard in water and warmed up. Mixture screw should be turned in slowly clockwise until engine just pops(lean). Then slowly open it apprx. 1/8 turn. This will aid engine in starting next time. Also, make sure primer bulb firms up when squeezed.
Feb 09, 2011 | Boating
Evinrude outboard motor starter rope
most likly is missing a washer,has been reassembled incorrectly.take apart and check
May 06, 2009 | Boating
Boating Logo
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
