Can I get clos caption with this tt tv box? Ty
What would cause loud idling sound , jerking motion and unresponsive brakes to a 2001 audi tt (manual transmission) after adding brake fluid?
loud idling may be higher rpm's and unresponsive brakes point to a vacuum leak in the power booster hose that will run very clos to the reservoir.
Dec 25, 2013 | 2001 Audi TT
Curing the "black box" on some TV channels
Here's the symptom: A mysterious black box covers some or most of the picture on your TV, but not all the time. It may not show up on all channels, or sometimes it disappears only to come back later.
No, it's not the picture tube, it's your closed-captioning. Somehow your TV has been set to "text mode", and the screen is being cleared for text that isn't there. On channels or shows where captions aren't being broadcast, there's no box. But the box returns when captioning is being sent.
Many TV set remote controls have a single button to set closed-caption modes, so it's easy to set a TV to "text" without knowing it. (Especially when you have kids who love to press buttons!) Then when the box pops up, it's a mystery.
Simply press the captioning button on the remote, or use the set's menu, to cycle through the settings until you turn captions off. No more box!
on Jan 31, 2010 | Televison & Video
Replaced TY-LA1000 Lamp and now a black box across the picture, TV is PT-50LC14
Check in main menu (set and box if using one) under closed captions--one of the settings is TEXT--black box will appear in middle of screen and certain channels--with the remote turn text off.
Apr 05, 2012 | Panasonic Televison & Video
We have a Sharp 25J-M100 and we cannot turn off the Closed Caption. We hit menu on our Sharp Remote Control and go down to Closed Caption and make sure it is off. The words never go off of the screen. Our...
If the captions are turned off on your TV, they have to be coming from your cable box. The TV is just displaying what it's getting. Check your cable box menu and make sure captions are turned off there. Cable boxes, especially on digital systems, can prevent the TV's caption decoder from operating properly. So they need to be able to provide captioning, and I suspect you've turned it on somehow. Comcast should be able to tell you how to turn off captions if you can't figure out the menus.
Jul 15, 2011 | Televison & Video
How do i remove the caption from screen on a konka tv?
On Time Warner Cable box change the Closed Caption to T3. This will remove the closed caption box when you change channels.
Sep 18, 2009 | Televison & Video
Closed caption stays on even though the set up menu states the "caption vision" is off
if you are on a cable or dish box caption is coming from the box, on cable turn TV on, box off press menu, get box service menu, turn caption off pretty simple
Aug 09, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv Has Big Black Box
shut off close caption. use the CC button onthe remote or go in to the menu and change close caption to CC1. this box is the close caption in TEXT(1,2) which will put on a black box whenever there is caption present.
Feb 22, 2008 | Apex Digital PF2720 27" TV
Closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Nov 27, 2007 | LG 42PX5D 42 in. Plasma HDTV
Closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Nov 14, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
