Question about Bulova Watches
I have a new Accutron courchevel women's chronograph. (A gift, worn for about 5 days.) The dials on the chronograph faces, and the sweep hand that measures seconds when the stopwatch is used, will not re-set to the 12 o'clock . Instead, all are 1 or 2 settings towards the 1 o'clock position.
  • Betsy Reed Jul 27, 2009
    Aside from basic information (Stainless Steel, Sapphire Crystal, Water Resistant 50 Meters), the number C876000 appears.
  • 3,037 Answers
This is a internal alignment problem. Since you just got the chronograph, take it back and get it replaced with a different one. Simple as that since it should be under warranty. Let me know how this turns out.
Benjamin
Posted on Jul 27, 2009
  • Bulova Master
  • 13,433 Answers
Do you see a model or a serial or similiar on the back or on the front of the watch? Please send me anything you find from it.
Posted on Jul 25, 2009
What are the three little faces for? do not have instructions
Your watch is a chronograph or a watch that includes a stopwatch. Two of the three dials are for recording minutes and hours with the large sweep second hand recording seconds. Pushing the upper button starts and stops the stopwatch function. Pressing the lower resets everything to zero. The small bottome dial is the seconds hand for the watch, it always is moving.
Dec 29, 2011 | Callaway Golf Unisex CY2085 Collection...
What is the worth of a bulova accutron 14kt gold mother of pearl face serial #59252 worth
mcdevito75 here, Bulova Accutron, nice watch, of course there are many, many factors that go into the value of any watch, depending on Maker, Model, Condition of the watch also. I would figure your Bulova Accutron is in the area of $125.00------- $200.00 range. Your best bet is to find a jeweler in your area or an appraiser, even online for the latest value of your watch.
Aug 15, 2010 | Bulova Wrist Accutron Lucerne White M. Of...
I have an accutron and i want to reset the my
No need to go to the shop as you can reset chrono hand yourself. Read manual and follow instructions. If you don't have manual, try this: Pull out crown and then push the button and hold it. If this does not work, try push and hold the button whilst other one is held pushed. In short terms - try to use as many different combinations as you can and you will find which way is right.
Jan 09, 2010 | Accutron Bulova Tahoe Chronograph 26B32...
The second hand on my invicta chronograph watch doesn't reset to zero
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Dec 26, 2009 | Invicta Subaqua Noma Iii S
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
How to set day of week mini dial?
Pull out the crown and advance hands forwards. When the hour and minute hand will pass 12 o'clock (midnight), you will notice the day hand will jump to the next (following) day. Advance hands as long as needed to reach the desired day.
Rate me, please.
Jul 23, 2009 | Invicta Square Angel Diamond Chronograph...
Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Apr 03, 2009 | Watches
Fossil Watch Chronograph Problem minute counter resets to 59 instead of 60
1. Pull out the time set mode button.
2. Press the upper right button repeatedly until the sweep hand makes it back to 00/60.
3. Press the time set button back into normal position.
Oct 01, 2008 | Watches
Re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. ashfaque.r@googlemail.com
May 18, 2008 | Seiko SNA553 Alarm Chronograph
Accutron Tahoe Chronograph
i have the same watch it needs a cleaning by a watch maker not jewler hope this helps
Nov 13, 2006 | Bulova Men's Accutron Tahoe Watch
Watches Logo
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
