Question about Teac Audio Players & Recorders
Teac x-7r, Record mute constantly flashes when system is powered on. System will erase tape when in record mode but will not permit new info to be recorded
SOURCE: black screen in record mode
dont ever buy sony again! Problem solved
Posted on Jun 07, 2008
SOURCE: Sharp Viewcam VL-AH151 Hi-8
Make sure the little red tab on top of the tape is set to record and not save. The camcorder will not let you record it its set to save
Posted on Sep 21, 2008
  • 20 Answers
SOURCE: Sanyo Xacti VPC-HD1- doesn't do anything in record mode
As I have been writing on other HD1/2 problems, sometimes it can be the card which is an issue. If the card is too slow or perhaps corrupted then the device can find it difficult to record.
This and other soft faults (that are reperable by turning the power on and off, changing or reinserting the card, removing the battery) are often indicated by a flashing red recording light.
Posted on Jan 06, 2009
SOURCE: My Teac Z-7000 will not record tapes
some weeks ago I got this really impressive deck (Teac Z 7000) from a colleague, and found the same problem. I fixed it, and the fix is not too complicated. It´s the potentiometers that do fail. All pots are from the same manufacturer (Alps) and construction. The problem is that the wisher is broken away from the holding plastic and will loose contact completely. You can check that with a normal ohmmeter: You´ll find the total resistance over the outer terminals but endless resistance from one of the outer terminals to the middle wisher contact. The values are: 100 kOhm linear for each of the upper left pots (fader,space), 2x22kOhm pos.log. for the lower left pot (phone volume). So, what does a broken wisher at the "fade in" pot do? The Recorder "thinks" that You selected an "endless" fade in time, and the result is : no record level. You can do an easy "quick and dirty" fix just to see if that´s the problem: Hold- or better solder- a say 47kOhm resistor in parallel to the conducted potentiometer terminals and try to record.
4 of 5 pots have been defective in my deck, and I´ve replaced them with standard types from my local electronic supplier (Conrad electronic, has a shop in Frankfurt/Main). Well, the new parts didn´t fit perfectly, I used a file to get them in (not visible from outside). Also I lost the possibility of pushing the knobs in and out, but that is not a really problem.
I assume this fix might also help owners of the Teac Z-6000 and Z-5000, which- most probably- use the same type of potentiometers.
This text was written by Boris Witke, Kelsterbach (near Frankfurt/Main), Germany. E-Mail: Please tell me if You were successful, possibly we get lucky users of these really fascinating machines.
Posted on Feb 24, 2009
  • 43 Answers
SOURCE: erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Posted on Aug 17, 2009
How to record a cassete tape
Typically, to record on a cassette tape you must press BOTH "Record and Play" buttons at the same time and the tape recorder will begin to record.
Nov 26, 2014 | Audio Players & Recorders
Reel recorder
The A4070G can record in each direction but has a switch that needs to change to switch the heads. This must be stuck after all this time and so the deck needs service. They are not easy unit to work on. I have one in my shop now. The bad news is that they use combo record and erase Ferrite heads that can not be sourced anymore.
I am very familiar with this model as I worked at Teac and fixed many of them.
Apr 20, 2014 | Teac Audio Players & Recorders
Mute handycam dcr
Could be because LP record mode was used.
Alo it may be tape dropouts.
Dropouts occur after too many record/erase cycles.
Oct 31, 2013 | Panasonic Palmcorder PV-GS12 Mini DV...
Info to change message on telephone dect 6.0 telephone Uniden dect 6.0
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: “Hello, no one is available to take your call. Please leave a message after the tone.”
You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
  1. Press /mute. The system announces the number of new and old messages, then starts to play themessages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that thesystem is in the command waiting mode.
  3. Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the announcement.
  4. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recordedgreeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time.
  1. Press the /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
  3. Press 6. The system plays the current greeting.
Jan 06, 2010 | Uniden DECT 6.0 Cordless Telephone...
Camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Dec 27, 2009 | RCA CC6363 Camcorder
I cannot erase a tape
Audio cassette tapes are not erasable.
You must record over the recorded portion or side of the tape you want to delete. You can of course record silence if you want a "clean" or "new" tape (turn the volume all the way down and then press the record button).
I found that I could do very fast with some recorders by pressing the record button and simultaneously pressing fast forward.
Oct 25, 2009 | Olympus Pearlcorder S701 Handheld Cassette...
Erasing the tape on a sony handycam vision please
Well the cheapest way is to go into record mode, cap the lens with the black lens cap and record a 'black' picture on the tape. This will erase all the pictures on the tape and leave you with a 'black' screen on the whole tape.
Oct 05, 2009 | Sony Handycam CCD-TRV37 Camcorder
Erasing recorded tapes
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
Wont let me record! Flashes "Protection!"
My Samsung camcorder one day displays protection. Used or new tape no difference. Used the menu options to remove protection and it gives me a play mode alert. Regardless I can not record in protection mode. Help!
Feb 08, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
VCR ejects tape when I try to record using the timer facility
Simple. The Cassette's 'Prevent Erasure' tab is missing. Just cover with Scotch tape and reload. Now try recording.
Nov 29, 2008 | Televison & Video
32 people viewed this question
Top Teac Audio Players & Recorders Experts
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
