Question about Time Computers & Internet
How to program for 4 areas at a specific time of day and time on each area
4 Suggested Answers
SOURCE: Getting "No GPS; Please move to open area" with every address
I rebooted, took out the battery and put it back in. Everything is working.
Posted on Mar 26, 2009
  • 221 Answers
SOURCE: 'Looking for a users manual for the Uniden
Hello Jeff,
Here's a link where you can get the owner's manual in pdf. format, just scroll down the list until you find your model number, when you click it will download the manual in pdf. format.
http://www.uniden.com/index/manuals_results.cfm?cat=3
Posted on Apr 06, 2009
  • 10406 Answers
SOURCE: Creating a ring using two circles in c++ program
Nice try!
If nobody has helped you since September 2008, when you asked the question, you probably scored a "zero" in your computer-programming course, and probably don't need an answer to your "homework" assignment.
Posted on Dec 05, 2009
I have a 12 station Orbit Model #57900and I want to water the same stations two to three times a day
Program modes
Program A or 1 is your primary program setting. All Zones will run on this program.
Select program B. Or 2
Set start time for program B usually an hour or two after the LAST zone (12) run time on program A or 1
1. set selected run time for the zones you want to run. 5 min -20 min ( leave the others 00:00 or off)
Select program C or 3
And repeat above.
Keep track of the start times of each program as 12 zones running for 10 min will add up to 120 min or 2 hours total. So if Program A/1 starts at 6am it will finish at 8 am. Set program B/2 start time at 11am. Them select the specific area/zone you want to run again will water the area a second time. Just remember to leave the other areas you don't want to water Set at 00:00 or off. Repeat through all the programs and you off to enjoy your day. Cheers
Jun 06, 2016 | Orbit Hardware & Accessories
I have just bought the yardworks 2 zone water timer from Canadian Tire and there are no instructions anywhere. I have managed to get it to work for one minute and I have it set to do the same in one hour...
Delayed Watering
You can delay the first watering cycle of each watering zone by up to 12 hours by using the small button at the bottom middle of each zone area. Press the delay button 1 time for each hour you wish to delay the first start time. The "Low Battery" light will illuminate when you press the button. The maximum delay is 12 hours.
For example, if you are programming at 4:00 in the afternoon and you want your timer to water every 12 hours, but you want the first watering of the day to start at 6:00 a.m., press the Delay button two times. Without the delay, the first cycle would have occurred 12 hours after the timer is programmed (4:00 a.m.). The delay feature changes that to 6:00 a.m. The timer will then water every 12 hours after that.
Aug 02, 2011 | Garden
Cannot set for a second watering time for certain areas of lawn. Have a Orbit 6 Station. Certain areas of lawn have been replaced and require additional watering.
Set up a B Program for the zones that need extra watering.
Say you want zone 2 and zone 3 to run 20 minutes every day in addition to your normal watering.
Set B Program, put Z2 and Z3 time of 20 minutes in, set a start time that is away from your normal watering time, say 6:00 pm. Set every day watering.
Your normal program will water and Z2 and 3 will water every day, too.
Gary
Jun 29, 2011 | Hardware & Accessories
I have treated the area with roundup for about a 70% kill rate. A friend just mowed over the area. Will this impact the ongoing kill, and do I need to spray the area again?
When was the field mowed after spraying? If it was after three days, then the plants that were treated will die off. You probably should plan to retreat the areas that weren't killed after those plants are growing again. (It will take a few days depending on moisture and other conditions.)
In general, you can spray any missed plants 7 days after the first treatment. Then mow or seed the area 3 days after the second treatment.
If the field was mowed prior to the three days after the first treatment, retreat the entire area after the new growth begins.
For specific details, read the label for your Roundup product. Scotts has the label at the bottom of their product pages. All of the Scotts Roundup products are listed here: http://www.scotts.com/smg/catalog/productCategorySubSelf.jsp;jsessionid=64F09279DC15FE8877450FE65C85C38E?itemId=cat50096&navAction=jump . Select the specific one you used and click on the View Product details link. Then click on the View Label link. For example the label for the Roundup RTU (ready to use) Pump and Go Spray formulation is here: http://www.scotts.com/smg/products/round_up/kill_and_prevent_weeds/pdf/BasePNG.pdf .
I hope this helps.
May 23, 2011 | Roundup "" Weed & Grass Killer
How do I use "look
I'm assuming that you're referring to the Look Back service offered by Time Warner Cable. If not, then ignore this.
Look Back allows you play back shows that you might not have recorded on your DVR (maybe you don't even have a DVR). The time window is within 3 days after the show airs, and it's only for specific shows... oh, and only on certain channels.
If you are on a Look Back-enabled channel, an Enhanced logo will appear on the screen, at which point you can hit Select on the remote to access it. From there, you can go to the day and program that you wish to watch. For more info, refer to Time Warner Cable's website. This website is for Texas, but it gives you an idea (to get the specific Look Back channels in your area, you'll want to change your location at the top of the page):
http://www.timewarnercable.com/texas/site.faqs/DigitalCab/#Look+Back
I hope this helps.
Mar 02, 2011 | Televison & Video
Cannot set time @ date for Ohsen watch...AD0721...thanks
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
Nov 30, 2010 | Watches
My ASUS Webcam program is Lifeframe and every time I try to open the program it says my Camera is used by another program, but I just used it like a hour ago. Any Advice?
We ran a typical Asus laptop battery of tests, including games, applications, and a couple other areas. Time constraints limited the amount of testing we could get done before the NDA lift (and it's already a few hours late), but we will be providing a follow-up article with further testing and information. That said, if there are any specific areas that you'd like to see tested, feel free to e-mail me or leave a comment.
Nov 15, 2010 | ASUS Computers & Internet
Is there an easy to understand user manual for the aube TH132 AF ? Even my father in law can't understadn how to operate the under floor heating on a timer...
http://www.uheat.co.uk/aube_th132_underfloor_heating_thermostat.htm
TH132 is a thermostat for under-floor heating
Go to the website above and download on-line copy of your manual
On-line manual let you read bigger print & lets you break down the steps easier
I am sure by the time this answer reaches you, the problem will be solved
This is true because manuals are frustrating, until you tell somebody it can't be figured out >> which gives you time to rest >> after which the manual makes sense.
BUT I am frequently wrong, and you may be at a standstill
A quick look at the manual.
You can also select which part of the manual is giving you a problem and then I will help you through that specific difficulty
Wiring: I guess the instructions at bottom of manual apply to your model
Your 240Volt hot wires from breaker box connect to terminals 1 & 5
Your two wires supplying power to heat connect to 2 & 4
Pilot wire to terminal 3
Floor sensor to 6 or 7 >> wire from sensor can connect to either pole
The TH132 has two sensors, 1 located inside the TH132, the other sensor located in floor
Set up:
The first part describes 10 buttons (right away you know this is complicated)
There is a brief description of both sensors
Step 1 shows how to configure the start and temp-display switches
Step 2 covers installation of module on base
I guess you hook up power at this point because the display is supposed to light up
This implies that the bottom part of manual should be located more towards the top, and the power-up directive seems to be missing. Bad manual.
Step 2 shows what the display looks like with first power-up
Step 3 tells how to set current time and day.
Step 4 adjust temp setpoints >> floor temp is pre-programmed to 82 degrees
Step 4 shows that you press-and-hold the sunshine or moon button to have it display
The sunshine button is the upper temp setting, the moon is the lower temp setting
Step 5 is operating mode > choose automatic for programming to operate
Step 6 is programming, which carries on with about 24 steps
If this is your problem area, let me know
Now the manual suggests you make a chart of your programs
Other programmable devices don't work when there is a conflict in programming
Wow I see the TH132 is 'equipped with a proportional adaptive controller..' that carries a two year warranty. I'm sure you'll rest easy knowing that.
Reply back with the specific trouble area, and we'll get it going for you.
Oct 21, 2010 | Aube Technologies Aube 7-Day Programmable...
How do I reset my Intermatic wall switch timer?
If CR2 battery went dead or if battery removed more than 1 minute, then time-date disappeared, but programming stays in timer indefinitely even if power is off.
To reset time-date. (From Section 5 in manual)
Press MODE until screen displays SET UP
> Press ON-OFF until HOUR shows ... use + key to change hour
> Press ON-OFF until MINute shows ... use + key to change minute
> Repeat same sequence for Year, Month, Day
> Press ON-OFF until DST daylight savings time ... use + key ... choose AUTO if area has DST ... choose MANual if areas does not have DST
> Press MODE to exit and save settings
Other programming steps are long.
Manual shows programming steps:
http://waterheatertimer.org/Intermatic-st01c.pdf
Walk through programming steps:
http://waterheatertimer.org/ST01C-program.html
Sep 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Nice try!
Sep 15, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Top Time Computers & Internet Experts
dhnguyen
Mike Tramer
Level 1 Expert
Taelisin
Are you a Time Computer and Internet Expert? Answer questions, earn points and help others
