Question about Coleman Heating & Cooling
I need wiring diagram for the contactor on coleman model BRHQ0301BD
    Top Expert:
  • Coleman Master
  • 41,752 Answers
Contact Coleman directly to request the wiring diagram
Posted on May 18, 2017
COLEMAN A/C mod. 2436-901 compressor motor hummes but doesn't start. need wiring diagram or info. on starting capactor value inforfation in cover has deteriorated.
I cannot find your model, and wiring diagrams for Coleman are not easy to get. I think best solution is contacting Coleman and asking a copy of the service manual
Jun 22, 2008 | Coleman Heating & Cooling
I have a Coleman mach 3 ac unit. ive replaced everything except the compressor. the fan will come on but when i put it on ac it blows the fuse in the thermostat.
Fuse in the tstat?? First inspect the low voltage wire outside for imperfections, such as bare wires. Unhook the low voltage wires to condenser outside and cap with existing wire nuts. Then replace fuse and turn system on with cooling. If fuse still good then you have a short in the contactor coil in the condenser. Need new contactor. If fuse only blows when a call for cooling it's in the wire for low voltage or the contactor itself.
May 21, 2017 | Coleman Heating & Cooling
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
New Contactor not pulling in on coleman ac unit
The contactor is powered by another device that is not able to handle the current. It is essentially a switch. You need a wiring diagram for the unit and have to use a meter to check voltages for the contactor. Make sure that it is wired right also. The voltage should be in the neighborhood of about 24 volts on the coil side.
May 12, 2015 | Coleman Heating & Cooling
How can I get a diagram of the wiring for Coleman A/C & Heat Unit...model DRHS042100
If you go to the coleman website for residential Air conditioners you should be able to find a diagram. If you need help with a certain part to wire I can assit you with that.
May 02, 2011 | Coleman Heating & Cooling
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
Defrost timer wiring diagrams show below:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
Need wiring diagram
check the capicitor if it is domed up on top bad check the wires at the compressor to see if burnt take a insulated object and bump the contactor in to see if comp starts if so then out on low voltage circ check for call from stat on common to yellow then follow the connections may be out on low psi switch located in the suction line
May 09, 2009 | Heating & Cooling
Heating & Cooling Logo
44 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
