Samsung SGH-t819 Cellular Phone Logo
Posted on Jul 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Upper righthand corner, blue full moon, 1 cm in size. (solid blue circle)
shameer ahamed
Level 2:
  • Expert 89 Answers
  • Posted on Jul 25, 2009
shameer ahamed
Expert
Level 2:
Answers
89
Questions
Helped
42092
Points
297
The LCD in your phone got damaged and so try to replace the LCD in the authorized service station.
2014 dodge journey sxt 3.6 timing chain diagram
/* override srp image link color and background color */ .galleryImage { background-color: #002F56; color: rgb(0, 47, 86); } Fig. 1 Front cover pry pointsFig. 2 No. 1 piston TDC positionFig. 3 No. 1 piston TDC alignmentFig. 4 Camshaft TDC alignmentFig. 5 Timing chain alignmentFig. 6 Lefthand cam phaser alignmentFig. 7 Timing chain alignment marksFig. 8 Upper intake manifold tightening sequenceFig. 9 Valve cover tightening sequence. LefthandFig. 10 Valve cover tightening sequence. Righthand Print Options Print Text Only Print Text and images Print Timing Chain, Replace Caution: The magnetic timing wheels must not come in contact with magnets or any other strong magnetic field. This will destroy the timing wheels ability to correctly relay camshaft position to camshaft position sensor. 1. Disconnect battery ground cable. 2. Remove air cleaner housing assembly. 3. Remove upper intake manifold. 4. Remove valve covers. 5. Remove spark plugs, then raise and support vehicle. 6. Drain cooling system into suitable container. 7. Remove upper and lower oil pans. 8. Remove righthand engine mount bracket. 9. Remove bolts from front cover. 10. Carefully remove front cover by carefully prying at seven indicated points, Fig. 1. 11. Rotate crankshaft counterclockwise to place No. 1 position at TDC on exhaust stroke by aligning dimple on crankshaft with block/bearing junction, Fig. 2. Lefthand side cam phaser arrows should point toward each other and be parallel to valve cover sealing surface. 12. Mark rotation direction of following timing chains for reference during installation: a. Lefthand side cam chain. b. Righthand side cam chain. c. Oil pump chain. d. Primary chain. 13. Reset righthand cam chain tensioner by pushing back tensioner piston and installing tensioner pin tool No. 8514, or equivalent. 14. Reset lefthand cam chain tensioner by lifting pawl, pushing back piston and installing tensioner pin tool No. 8514, or equivalent. 15. Disengage oil pump chain tensioner spring from dowel pin, then remove oil pump chain tensioner. 16. Remove oil pump sprocket T45 retaining bolt, then remove oil pump sprocket and oil pump chain. 17. Install righthand camshaft phaser lock tool No. 10202, or equivalent. Minor rotation may be required to install camshaft phaser lock. 18. Loosen both intake oil control valves, then exhaust oil control valve. 19. Remove righthand camshaft phaser lock tool, then oil control valve from righthand side intake cam phaser. 20. Pull righthand side intake cam phaser off of camshaft, then remove righthand side cam chain. 21. Remove oil control valve, then pull righthand side exhaust cam phaser off camshaft. 22. Install lefthand camshaft phaser lock tool No. 10202, or equivalent. Minor rotation may be required to install camshaft phaser lock. 23. Loosen both intake oil control valve and exhaust oil control valve. 24. Remove lefthand camshaft phaser lock tool, then oil control valve from lefthand side exhaust cam phaser. 25. Pull lefthand side exhaust cam phaser off of camshaft, then remove lefthand side cam chain. 26. Remove oil control valve, then pull lefthand side intake cam phaser off of camshaft. 27. Reset primary chain tensioner by pushing back tensioner piston and installing tensioner pin tool No. 8514, or equivalent. Remove two T30 bolts, then primary chain tensioner. 28. Remove timing chain. 29. Reverse procedure to install, note following: a. Verify No. 1 piston is positioned at TDC by aligning dimple on crankshaft with block/bearing cap junction, Fig. 3. b. Verify camshafts are set at TDC by positioning alignment holes vertically, Fig. 4. c. Ensure timing chain plated link is located at 12 o'clock when dimple on crankshaft is aligned with block/bearing cap junction, Fig. 5. d. Position lefthand side cam phasers so that arrows point toward each other and are parallel to valve cover sealing surface, Fig. 6. e. Torque idler sprocket bolt to 18 ft. lbs. f. Torque oil control valve to 110 ft. lbs. g. Torque oil pump sprocket bolt to 18 ft. lbs. h. Ensure there are 12 chain pins between exhaust cam phaser triangle marking and intake cam phaser circle marking, Fig. 7. i. Torque upper intake manifold bolts to 80 inch lbs., in sequence, as illustrated in Fig. 8. j. Torque lefthand valve cover bolts in sequence, as illustrated in Fig. 9, to 106 inch lbs. k. Torque righthand valve cover bolts in sequence, as illustrated in Fig. 10, to 106 inch lbs. l. Torque timing chain tensioner to 106 inch lbs. m. Torque timing chain guide to 106 inch lbs.
Print - As Shown Print - Fit To Page / 1
  • Fig. 1 Front cover pry points
  • Fig. 2 No. 1 piston TDC position
  • Fig. 3 No. 1 piston TDC alignment
  • Fig. 4 Camshaft TDC alignment
  • Fig. 5 Timing chain alignment
  • Fig. 6 Lefthand cam phaser alignment
  • Fig. 7 Timing chain alignment marks
  • Fig. 8 Upper intake manifold tightening sequence
  • Fig. 9 Valve cover tightening sequence. Lefthand
  • Fig. 10 Valve cover tightening sequence. Righthand
2answers
Is there a month with with two full moons
Moon cycle is about 28 1/2 days, so every so often there is a month with two full moons. This happens "once in a blue moon". Hence the expression
Mar 06, 2015 • Optics
When if the moon full each month
The full moon varies when it arrives. A blue moon is the second full moon in a calendar month. The full moon has nothing to do with when you will have your baby.
Mar 28, 2014 • Vacuums
1helpful
If you know about area formulas of class 8 and 9,please solve my question?there is a circle.in the between of the circle,there is a rectangle of dimension 4cm and 3cm.if the rectangle will cut out what...
The diameter of the circle is the diagonal of the rectangle use Pythagoras this rectangle is a made from two 3,4,5 triangles, so the diameter is 5cm, the radius will be 2.5cm don't forget the BODMAS ordering rule (Brackets of Division Multiplication Addition and Subtraction) Also rounding to 2 decimal places. This solution is based on all four corners of the rectangle touching the circumference of the circle.
Area of a circle is P (22/7) i x Radius (squared ^2) ====> 22/7 x 2.5cm ^ 2 ====> 22/7 x 6.25cm
TOTAL AREA of CIRCLE = 19.64 cm^2
Area of the rectangle is length x width ====> 4 cm x 3 cm
TOTAL AREA of RECTANGLE = 12 cm ^2
The remaining portion is the circle area minus the rectangle 19.64-12 = 7.64 cm^2
SIMPLES brought to you by SpideRaY @ http://www.windowstipsclub.com
To close window on right hand of yahoo so i can view full screen
1.If you right click on the blue header of the page you will see Restore, move, minimize, maximize, etc.
2. Click maximize to see if the screen enlarges or increases in size.
3. Then click the X in the upper right hand corner of the screen and this will close the window.
My Hitachi LCD rear projection TV has blue color in left corner
It is most likely the tube going out. Find some one to replace the tube if the TV is fairly new other wise it is going to be a trend. One tube now and another.. and so on. Ride it out as long as you can then go for an upgrade
1helpful
Half moon cubes too large. Intermittent harvest.
Counter clockwise should decrease it. Just turn it 1/4 turn each time and check it after it makes another batch of ice. Then reread this post and do it again till it's the way you want it.
How do i charg an mp3
The way I figure it out is to just unhook it and look at the screen. Go into your music and look at the upper right corner. there's a rectangular battery looking thing. If it's a solid dark blue color, it's full.
How to use Tile Saw
To cut a tile using a wet tile saw, measure the exact space in which the tile will fit. Cuts are usually along a perimeter, in a corner, or around an electrical outlet. Mark the line on the full-sized tile in grease pencil. Most saws will accommodate tiles up to 12 inches (30 cm) in size, but oversized saws can be rented for huge floor tiles. Wearing safety glasses, place the tile on the moveable platform, and line up the mark with the edge of the saw. With the motor running, slide the platform toward the blade with an even but gentle pressure. Since you are grinding the tile apart, ensure that the water have sufficient time to cool everything.
2answers
Frozen image
I am suspecting that the battery is dead. Have you tried replacing the battery? You can always contact SanDisk for support. If it is still under warranty, then just send it back for a replacement.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
