Question about Craftsman Garden
Craftsman yt3000 chainsaw rope gets stuck when trying to start.rope doesn't go back in to engage. Is it the spring?
Opelmanz
  • 62 Answers
SOURCE: Broken Pull String
Yes, it is possible that the spring needs to be pre-tensioned. its also possible that something was put together a little out of alignment, or some part is too tight and its too hard for the spring to wind in the chord. try to reassemble the chainsaw with a couple more turns on the spring and see if that helps.
paul
Posted on Oct 31, 2008
SOURCE: can't start my leaf blower
You might have damaged the "spring re-wind" or the cord is jambed. If you know how to disassemble the housing (see owner's manual), then check to see if the cord is stuck, then manually re-wind it and pull it slowly and then let it rewind slowly. Do not attempt to remove the spring housing unless you have several hours to spare to rewind the spring, as it will "unspring" with great force - all over the place. Zing! The only other solution, of course, is to take it back to Sears for repair. Yuck. Have had several in the shop for other reasons that couldn't be easily DIY repaired - time after time.
Most ****-smen products cause more headaches than they prompt smiles of joy. I have pretty much determined that the manufacturers of ****-smen (who ever they are) plan it that way. Most home-owner products of this sort only last for 3-4 years, if you're lucky. I have also tried other brands; none are much to rave about. You could always do what I do, if I don't have any warrantee time left, or an extended agreement; give it a nice funeral (or run over it with a tank and send the remains to the CEO of Sears) and spend the money for a new one (any brand - even Craps-men) or use a rake..... :(
If you do get it to work, try pulling the cord with less force and NEVER let it "spring back" by letting go of the handle. Let is rewind as you hold it. GOOD LUCK!
Posted on Nov 09, 2008
  • 61 Answers
SOURCE: recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Posted on Jul 04, 2009
bobbyburns
SOURCE: Reattaching the recoil spring to the rope pulley
i have the same probelm
Posted on Jul 08, 2009
  • 97 Answers
SOURCE: My Poulan Pro 150E pull cord will not engage to
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Posted on Sep 02, 2011
Why does the drive speed of my Craftsman Lawn Tractor fluctuate between fast and slow.
I feel you may have a spring that is on the carb that has broken or come off. The thing the spring goes on is just floating back and forth as the engine revs making it rev up and down. I had that happen and had to get a new spring. this spring should be hooked to the control section of the carb.
Nov 13, 2017 | Craftsman Garden
The rope broke when I tried to start the chainsaw. How do I replace it?
Your rewind spring is now sprung. Remove recoil assy ( the part your rope slides into). Remove all old rope remnants and rewind the spring. Install new rope, tie it off and slowly release spring rewinding the rope.
Mar 14, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Starter cord will not pull
The pull cord or rope works on a tight spring just under the cover that the rope is in. Usually three to four small bolts on the edge of the cover to remove to repair/replace either the spring or the rope. First I would try to turn the motor manually with your hand on the flywheel, it should move around either direction freely with no effort. If it does not the motor itself maybe stuck not the rope. Then you have a seized engine and a different problem to deal with.
Dec 27, 2013 | Husqvarna 41 141 41 136 36 Recoil Pull...
My Craftsman lawn mower starter cord doesn't retract after mower starts.
I have had this situation before on a lawnmower. I didn't have a craftsman, but is probably the same issue. Basically, the spring that recoils the cord back in either broke or came unwound. When the mower is not running, the cogs on the pull chord keeps the cord from coming out. When the mower is running, the spring is not wound enough to hold the chord in and thus releases or doesn't hold it in.
Try pulling the pull chord assembly off and rewind the spring.
May 05, 2011 | Craftsman Garden
Doesn,t engage with engine
sounds like the dogs and or springs are worn.When you had the cover off the machine did you check that the dogs would freely move out when the rope was pulled? They some times stick and will not engage.
Dec 26, 2009 | Toro Garden
HOW DO I GET TENSION BACK ON THE STARTER ROPE?
Try giving a few light tuggs and hopefully the spring will recoil itself. If not, you probably spung the spring and you will need to take apart the recoil assembly to get it working again. BE CAREFUL, springs have a tendancy to just 'jump' out and completely uncoil themselves and then you will have a headache for sure. Also, try reaching under the deck (hopefully the motor isn't running :P ) and turn it counter clockwise while someome one tugs at the rope. Many times it will engage itself and rewind just fine. Let me know what happens
Sep 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My chainsaw cord would not retract when i pulled it to crank it so i took the pully off my 14 inch chainsaw to see if i might fix it it was stuck fast so i took the cord off to check the spring and it came...
Your spring is probably broken. You just need enough tools to take off the cover. One end of the spring fits over a peg or mount in the casing and the other end on the sprocket. One end or the other is probably broken. Both ends need to be attacked and then you set the sprocket or pulley back into the casing. Before you do, you spool most of your rope back onto the sprocket or pulley. Somewhere on the pulley you will see and indentation so that you can set it back into the case but the rope remains on the top of the pulley. You keep the rope outside so that you can then wind up and tention the spring. The number of turns you need to wind up the pulley depends on how much rope you have that isn't on the pulley. It should take about 4 or 5 turns of the pulley then you stop the indentation on the pulley where the rope enters the case then pull on the rope handle as you feed the rope out the indentation. ONce all the rope is back outside the case or on the pulley, you can let the pulley go and the spring should have enough tention to wind it all up again.
Jun 06, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need to rewind craftsman chainsaw pull rope.
I have tried to do this many times and have yet to suceed, believe me it's not worth the fustration and the extra days in hell you will spend from cussing.
Take to a repair shop, they can do it quickly and cheaply when you consider how difficult this is for the ordinary person. (me)
Mar 01, 2009 | Garden
Poulan starter rope
to fix starter rope first you must wind spring and place back in housing. just grab spring by middle and wind ,you will have to get it smaller than housing hole. One end should hook to a tab at housing rest of it sets inside itself. once set in housing dont let go, insert rope housing over top & screw in. rope housing should have some return spring to it when pulled. if rope is not tight on return pull simply add one winding to spool. hope it helps!
Feb 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
20 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
