Question about The Office Equipment & Supplies
I cannot get the shredder to turn on - The Office Equipment & Supplies
    Top Expert:
  • The Master
  • 39,286 Answers
The overheat sensor in the motor windings may have opened.
Posted on May 18, 2017
Black n& DEcker paper shredder CC600 will not turn on
Check if there is power from the outlet. Check the cabling. Then do a check on the shredder to see nothing is blocking the free movement of the "knives " then check if all sensors are engaged. Not closing the shredder 100% ant the not closed sensor will prevent the motor to run. See and here if the paper in sensor is in tact and clicking when putting in paper. Needless to say, you better unplug the shredder when you open it to check.
Apr 18, 2015 | Black & Decker CC600 Shredders
Does not shredder middle of paper
First, make sure you turn your power to the shredder off. Take off the top of the shredder and turn it over. Is there paper stuck between the shredding wheels? I had to carefully pull this paper out with a set of tweezers. Be careful, as the shredding wheels are very very sharp!
Good luck,
Paul
Apr 11, 2015 | Shredder Office Equipment & Supplies
How do I fix the rollers that won't turn when paper is inserted in shredder?
That shredder is as weak as they come - it is probably a broken plastic part inside the mechanism. Recommend you throw it away and get the Amazon Basics shredder, your experience will be much better. Sorry.
Jan 16, 2015 | Royal Office Equipment & Supplies
Shredder will not turn off
Unplug the shredder from the power outlet. Remove the paper canister. You will need a can of air to blow all areas both from inside of the shredder around the blade area and outside of the shredder around the blade area. After you complete that part, Check the sensor area to make sure no paper is jammed around it. Plug the shredder back in and turn it on. If that fixes the problem, get a sheet of paper and put some shredder oil on it and put it thru the shredder for lubrication.
Apr 11, 2012 | Office Equipment & Supplies
Shredder does not work
Hello there. I'm sorry to hear about your shredder I'm sure there is something we can do. The first thing we need to do is check to see that it even turns on. If there is a light that turns on while plugged in then we know that it is properly turning on. If the light is off then it must be an electrical problem, either with your socket or your shredder. I recommend trying a different socket.
BEFORE TRYING THIS STEP, MAKE SURE TO TURN OFF THE SHREDDER!
If it turns on correctly you might want to see that the blades aren't stuck with paper. TURN OFF the shredder and try and move the blades with a screwdriver or a flat head. You can also see the paper in some printers. If you cannot see the blades then we can take an alternative.
You can find shredder oil in any office supply retail store. You put some oil on the blades and it lubricates them, and at the same time eats away the paper that is stuck. Most times this is the problem. If you can't go to the store you can use a little bit of cooking oil. That will do the trick as well.
If none of these methods work than it must be an electrical problem in the shredder. Hopefully not however.
Good luck
- Oblivior72
Mar 01, 2011 | Aurora Electronics AS662C Shredder
Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
Sep 01, 2009 | Royal Office Equipment & Supplies
XF50D motor won't turn shredder blades
There is no viable solution.  There are no replacement parts available.  The Office Depot shredder is a cheap low quality product made by a cheap company.  The FIXYA service agreement costs more than the product.  Bad choice to buy the product!
Dec 07, 2008 | Office Depot Ativa DQ60M Shredder
Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Jun 21, 2007 | Royal 150MX Cross-Cut Shredder
Paper Shredder will not shut off when in auto mode
if you answer no to the following question, then I do know your solution: Q: When you unplug the unit immediately after your action of "When those paper complete the shredder does not turn off."...and then plug it back in, does the shredder STILL continue to operate? if no, then the solution is to disassemble the feeder unit and manually unclog the paper sensor.
Jun 14, 2007 | Royal VF1012mx Shredder
20 people viewed this question
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
