Question about Garden
Turf Trac 149-995-502 A250D Serial # 41-008-0224 and looking to figure out what fluid to put in hydrostatic transmission? Also has a hydraulic system, is it part of transmission?
  • 3 Answers
SOURCE: Steering gear fluid capacity and type of manual trasmission fluid?
Hello Dave,
I own a 1988 Ram 50 5-Standard and will go off my own experiences to answer this question.
I use a synthetic 80W transmission fluid.
If you know what is/was already in there; my recommendation is not to change the grade of oil in the transmission unless it is necessary because of driving conditions or vechicle requirements (i.e. towing/hauling/efficiency).
Anyway the Ram 50 Manual 4 & 5 Speed transmissions take a range of fluid grades from 70W-90W. You can use this in both conventional and synthetic oils.
For the power steering, universal power steering fluid works the best, and I honestly don't know the exact amount to put in Ram 50, but may I suggest you purchase ~20oz. Fill it half with half the bottle, then check the dipstick, then put in half of that half-bottle (a quarter of the bottle in), check, and repeat until you get it to the appropriate level.
-Cbeach76
Posted on Oct 15, 2008
  • 69 Answers
SOURCE: what kind of fluid goes in a craftsman hydrostatic
Consult on owner's manual, which you can look up here..
http://www.managemyhome.com/mmh/prod...Display.action
Posted on May 18, 2009
  • 85 Answers
SOURCE: checking fluid level
most units of this size & quality have a factory sealed transmission. to check or change oil, the transmission would have to be removed.
Posted on Sep 12, 2009
mowerman1857
  • 389 Answers
SOURCE: transmission fluid low, hydrostatic transmission
Quoted from your Owners Manual. . . . .
TRANSAXLE PUMP FLUID
The transaxle was sealed at the factory and fluid maintenance is not required for the life of the transaxle. Should the transaxle ever leak or require servicing, contact your nearest authorized service center/department.
Posted on Oct 29, 2009
  • 3 Answers
SOURCE: Hydrostatic transmission Fluid alternatives
no it will not work use hydra or hydra ultra
Posted on Dec 09, 2009
What kind of oil is used in a sabre hydrostatic transmission
John Deere transmission fluid recommendations
For Sabre? and Scotts? garden tractors and commercial mowers
This bulletin serves to clarify the transmission fluid service requirements for several models of lawn and garden product and commercial mowing equipment that were recently introduced. The operator's manuals for these products call for 20W50 synthetic oil, which is not carried in the John Deere parts system.
The following chart has been developed from the factory and engineering as approved replacements for 20W50 in each application, and should supplement the information previously published. Transmission fluid recommendations Machine Model Recommended oil for service requirements Sabre
2048HV
2148HV
2254HV
2354HV
2554HV
Plus-50®, 0W-40
or -John Deere Hy-Gard®
(bothoils are for top-off only) Sabre All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Scotts S2554 Plus-50®, 0W-40 Synthetic
- or -John Deere Hy-Gard®
(both oils are for top-off only) Scotts All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Mid-Ztrak
Mini-Z M653 through M665
737/757
717/727 Plus-50® II, 15W-40
Plus-50®, 0W-40 Synthetic Front-Ztrak F620
F680/F687 Plus-4?, 10W40
- or -
Plus-50® II, 15W-40 QuikTraks 647/657/667 Plus-50®, 0W-40 Synthetic Last modified: 23Jan10.
Apr 03, 2017 | Garden
Hydrostatic transmission fluid needed for bowlens tractor
The Bolens or iseki G152 will take a "TDH" fluid. The local Tractor supplier told me that as long as it says "Transmission / Hydraulic" on the container I would be OK. Most of the newer (and some older, like ours) have a single sump for the Hydraulics, differential, and Transmission and this is the product most of them use. I've been putting that in on my G152 (tx1502).
Any local tractor supply will have it. Even NAPA auto parts carries a TDH fluid. Again, whatever brand you get make sure it says "transmission / hydraulic" on the label.
Flyer
May 26, 2016 | Garden
Hydrostatic transmission in YTH2348 is very weak, pulls intermittently then stops. I changed the oil put 50wt in it, still doesn't work.
hydrostatics will not work with gear oil they take transmission fluid . or hydraulic fluid check with a dealer or read you manual
Sep 15, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do you fill the hydraulic fluid for the craftsman kohler magnum 19.5 lawn trctor
its hydrostatic fluid not hydalic fuid dont put hydralic fluid in it the fill is on the back of tractor on the transmission there is a dip stick do not overfill or you will blow seals
Dec 15, 2014 | Craftsman Garden
What is a hydrostatic transmisson?
Hydrostatic transmissions are automatic "Hydraulic drive" transmissions. The largest producers of hydrostatic transmissions are Hydro-Gear, Tuff Torque and General Transmissions.
Jun 16, 2014 | Ariens 42" Riding Lawn Mower Blade ...
What is hyrdrlik fluid for a waldon 4100 loader
Automatic transmission fluid type F. Or john deer hy gaurd for hydrostatic transmissions
Apr 16, 2013 | Office Equipment & Supplies
What kind of fluid goes in the hydrostatic drive ? The mower goes fine in forward and reverse when first started. As the mower heats up it has trouble pulling itself. After about an hour it will barely...
Hi Jeff,
Use hydrostatic fluid. Consult your owner's manual for information. Do not use hydraulic transmission fluid.
If you do not have your owner's manual, you can find one on www.managemylife.com Just go to that site, click on manuals and enter your make and model number.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 09, 2011 | Briggs & Stratton Garden
I have a case 4210 farm tractor and need to know what the best type of hydraulic fluid to use would be ??????
Older case machines used a fluid identified as TCH (Torque Converter Hydraulic) for both the transmission and the hydraulic system. It's not readily available so has been replaced by default by separate products. Hydraulic fluid for the cylinder system, and transmission fluid for the torque converter. I'm currently using NAPA TDH with no problems.
Sep 07, 2009 | The Times Case Corporation Tractors...
Changing oil in hydrostatic drive of YAMAHA WR 450 2-trac
Hi, Dragoj for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
YAMAHA 2 TRAC TWO WHEEL DRIVE need more info please
https://www.yamaha-motor.eu/designcafe/en/about-bikes/off-road/index.aspx?view=article&id=441269
YAMAHA WR450F Owner Service Manual
Yamaha WR450F 2 TRAC Supplementary Owner Service Manual
https://www.partsfish.com/page/oem-parts-for-yamaha
YAMAHA WR450F Owner Manual
Oct 30, 2017 | 2005 Yamaha WR 450 F 2-trac
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
