Question about Microwave Ovens
My microwave filter light is on and it will not reset after I hold it down for 3 seconds. I seldom use the vent fan and the microwave is less than7 months old .
SOURCE: Microwave shuts off after a few seconds
Nov 22, 2007. I also had the 3 second shut off problem with my G/E 1650 MWO. Read all the above and tried them all. Finally I just took a 8" x 8" piece of Reynolds Wrap Aluminum foil and but it in an zip lock bag and placed it behind the control panel. It's been working for 2 weeks now. Just take out the 2 screws that hold the vent across the front right above the door. Next on the right side is one screw, take it out and then gently lift the control panel (panel with the buttons) about 1/2" and it will fold out and stay there. put the zip lock bag inside. Close it back up. I'd test it before replacing all the screws. You don't need to un-plug anything. Just don't stick your fingers on all the exposed parts...Mine works great now and didn't cost $0.10.
Posted on Nov 22, 2007
bobjrdns
  • 84 Answers
SOURCE: Sumsung MU3250W shut down
The problem is your magnetron tube is leaking RF. The mag tube comes on 2-3 seconds after you hit start, and the RF interfears with the board and shuts it down. Drop the front of the control panel down and watch, it wont happen.. Get a new mag tube put in and you'll be good to go.
Posted on Oct 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Obertelli
  • 3006 Answers
SOURCE: My keypad is also dead.
No, but as with all electronic items faulty ones typically show themselves up during the first few months of use.
You've probably just been one of the unlucky ones.
Posted on Sep 08, 2009
  • 148 Answers
SOURCE: microwave on w/light but fan and heat not working
The problem is the door switch is defective. I'm on my third new switch in 3 years. The part number is 5304440026.
Posted on Oct 16, 2009
Cannot unlock the display panel
Elise,
So I'm understanding that the lock icon stays on no matter what you have tried. I would try pressing and holding the START/STOP button for 5-10 seconds to see if it changes. I don't know how long you've been leaving it unplugged for when you do unplug it, but i would suggest at least 3-5 minutes. If these don't work what I would do is either contact the manufacturer or maybe even a local authorized technician. This way they would be able to assist and possibly have some more suggestions or be able to find and solve the issue for you.
-Best regards-
Jan 16, 2014 | Frigidaire FFMV164LS 1.6 Cu Ft 1,000 Watt...
We changed the charcoal filter & reset it. The vent fan still does not run. I cannot turn the vent on by pressing the vent button but the micro still heats up. What happened to the fan?
follow this steps and fix iT. God bless you
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#12#ixzz2gURd1VtM
Sep 30, 2013 | Whirlpool WMH2175XVB Microwave Oven
Screw/nail in microwave housing loud rattle when exhaust fan is on.
A screw that falls into it from the top should be in the vent fan in the top rear of unit. I think you will have to take the unit down from the wall, at that point, either remove the vent blower fan and shake it out, or turn the whole microwave upside down and it may fall out.
Oct 17, 2017 | Whirlpool GH7208XRS Stainless Steel 1200...
I have an GE Eterna Microwave Model Number: EMO3000HWW01 The microwave resets itself after aboout 10 seconds of use. Before it would do this and we would reset the time and date and it would work for...
It may be that the internal cooling fan is not working or the filters or air duct may be clogged, but it may also be a "noisy" magnetron.
First, check the filters. Then determine if the internal cooling fan is coming on.
I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
If that is working, and you have good air flow, then see this FixYa solution.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Sep 07, 2010 | GE JVM1650 1000 Watts Microwave Oven
How do I unlock the key pad? The display shows locked and I don't know how it locked.
Here you go.
The Child Lock shuts down the control panel pads to prevent
unintended use of the microwave oven.
When the control is locked, only the Vent Fan and Light pads will
function.
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound
and a lock icon appears on the display. Repeat to unlock and
remove the lock icon from display.
May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave not heating, but does count down minutes.
Press clear/reset button and hold 5 seconds. If this doesn't work unplug unit or shut off breaker for 10 seconds.
Sep 25, 2009 | Hotpoint RVM1435 Microwave Oven
My Micro vents into the kitchen instead of venting up the exhaust vent. What could be wrong
The fans on an over the stove microwave can be rotated up to 180 degrees depending on how the installer intends to vent the hood. Your fan is pointed forward and venting into the kitchen through a charcoal filter. If you want to vent through the ducting and out of the kitchen, you'll have to drop the microwave down off of the mounting bracket and rotate the fans in the back, pointing the dicsharge upward for a vertical vent, or 180 degrees, if it discharges out the back (wall vent). In both cases, an adapter is necessary, and can be obtained at any hardware store.
Best regards, --W/D--
Aug 08, 2009 | Tappan TMT104E1 Microwave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Good luck.
Oct 19, 2008 | Samsung MU3250W Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
