Question about Cameras
When the camera is turned on this message comes out PLEASE TURN CAMERA OFF AND THEN ON AGAIN, my question is this has arrangement
  • 5 Answers
SOURCE: when i turn it my camera on it say turn on and off again
try leaving the battery out of the camera for a day. Put the battery back in then turn it on
Posted on May 17, 2006
SOURCE: Dropped the camera, shutter won't closed, focus keep moving in and out, message "please turn off camera and turn on again"
This recently happened to me and I too got a hefty quote from the company since mine was no longer under warranty. I figured since it was trash anyways, I might as well take it apart and see if I could figure out what was broken. After removing all of the screws and removing the top pin strip from the board (there is a piece of tape on it) and flipping the lens part away from the board, I was able to remove the small gear compartment on the side of the lens housing (held on by one small screw) and the 3 screws on the back of the lens and carefully flip out the digital camera part and push the lens back into it's original closed position. I then carefully reinserted the digital part back into the lens making sure everything was nice and flush and closed it back up. Works like new :D However, if you're nervous about digital machines, I wouldn't reccomend doing this. Luckily for me when my camera fell it simply knocked the digital lens out from the housing and it didn't pop back in right afterwards, causing the lens to not be able to turn completely like it should. If yours is damaged more than this, it may not be such an easy fix. And the camera is difficult to handle as it is connected by those pin strips everywhere. It made me nervous to handle it as I probably could have made it worse, but, I had nothing to lose. Hope this helps out the next person.
Posted on Aug 20, 2007
SOURCE: Message - "Please turn off camera and turn on again"
take out the memori card for istage!
Posted on Sep 01, 2007
SOURCE: Malfunction -turns on and message to return on
the camera has a lens fault and needs to be checked by a panasonic repair technician.
Posted on May 31, 2008
bobint17
  • 270 Answers
SOURCE: please turn camera off & then on again
off the camera again and try to open the menu and try to reset it .if the problem persist send it to the survice center
Posted on Feb 03, 2009
Panasonic DMC-ZS6 when in camera mode lens comes out and I get the message "Please turn camera off and then on again" when I turn off the lens just stays out.
There is an issue with the camera focus circuit in lens. That is why it is ok when you go into playback mode but negative when the lens is involved.
Aug 25, 2017 | Panasonic Cameras
I have Panasonic digital camera DMC-LC80. When I turn on camera, it turns off, and on display write "please turn off and on the camera again". I do it, but on display this write again and...
Mine does exactly the same - still holds all it's stored photos but seems to struggle to focus when turned on, then gives up & comes up with the 'turn camera off' message. Get the feeling it's something to do with whatever makes the camera focus.
Jul 09, 2011 | Panasonic Lumix DMC-LC80 Digital Camera
Panasonic DMC-FX35 error message
Sounds as if it has either received a knock, or foreign matter (grit etc) has got into the lens mechanism.
May 30, 2017 | Panasonic Lumix DMC-FX35S Digital Camera
Please Turn camera off and then on again
This message usually appears when force has been applied to the lens.
Sep 12, 2009 | Panasonic Lumix DMC-FS5 Digital Camera
Please turn camera off and on again
The message appears when force has been applied to the lens.
Sep 07, 2009 | Panasonic Lumix DMC-FX500 Digital Camera
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
'Please turn camera off and then on again'
The barrel is defect inside,dit it fall on the lens? A new barrel will cost about 175 euro.
Jun 07, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Turn Camera Off error message
hi
I have the same error code if you can help me please let me know
thanks a bunch
Jun 29, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Apr 23, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
When powered on, message comes up...
The lens can not move due to a possible obstruction.
Gently put some force on the lens, turn the camera on and it works. I suppose there is too much friction between lens and camera.
Best regards from Holland!
www.SemafoonWinkel.nl
Dec 14, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
