On the remote control up- down button is missing and it not work do you have a remote or could it fixed
    Top Expert:
  • Televison & ... Master
  • 77,939 Answers
It can not be repaired. You can order a new OEM remote at this website. 1 800 Remotes
Posted on May 17, 2017
2 Suggested Answers
SOURCE: Channel Up/Down button quit working on the remote control
I had the same problem. You need to go into SETUP > CHANNEL > SKIP and select NO for every channel with a signal. A few months after we purchased the TV it defaulted to this (software glitch). We had lived with it for months before figuring this out. There is no easy way to reset these that I know of. I literally had to go to each channel and then change "skip" to "no." JM
Posted on Jun 13, 2009
HOW do i open Remote Control for recorder, AKB35912904. It is not working.
Try code scanning with a universal remote. My favorite are directv and comcast. directv is mute + select, then 9912, then power, then channel up until the unit powers with the remote, then push select. If you miss the code, you can channel down and back up. Good luck.
Eject button may be any button on the remote, just mash buttons while the unit is on.
Nov 30, 2014 | Televison & Video
Keypad numbers no longer work to input/change channels, but the up/down channel changer still works -- how does one fix?
Connect the remote to your computer and launch the software that came with your remote. Chose the device that your having an issue with (I'm guessing the tv) from the devices tab. Click on settings. Customize Buttons. Check at the bottom of the screen if the numbers are in the command column of not. If the are missing provide them. Press done and follow the prompts If that does not fix it. Repeat the previous steps to get back to this screen and choose reset defaults. Press done and follow the prompts
Jul 06, 2011 | Logitech SST-659 LCD Remote Control
Need intructions how to program remote control on vip722k second receiver
Press and hold down the SETUP button located on the remote. Wait until the INDICATOR light turns on. It will blink once the button is pushed, however once you see the indicator light stay one, release the button. Click the button to the DEVICE you wish to program. If it is a TV, then click the TV button. If it is the cable box, then click CBL button. After doing so, the indicator should still stay on. Press the DOWN CHANNEL button several times until you see the RECEIVER yo wish to program respond. Example: If it is a TV, then you will notice the CHANNEL change once the remote locates the correct settings for that receiver. If you see the receiver respond and you are pushing the down channel button but nothing is working, it means you passed the internal settings of the remote to the receiver. Try pushing the CHANNEL UP button slowly. It may be able to relocate the the proper settings. Once you see the channel change again, press ENTER to program the remote. If this fails, retry the same steps. In some cases you may miss the correct internal settings.
Nov 23, 2010 | DISH Network IR Remote Control
Why does every button work on my universal remote after i program it but the channel up and down
Universal remotes alway have somethings missing functions to comparation to the original remote.Well,ur universal remote don't have channels up and down functions.Try website like to buy an original remote.
Oct 21, 2010 | Universal Remote Control Remote Control
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Our philips DVP3252 was multizoned but is now playing just zone 4. I have instructions with a code number but can't get it to work - I think I might be missing a step in the instructions.
Try this hack.
Press the Setup button on your remote control
Using your remote control, highlight but do not select the Preferences menu
On your remote control press following buttons in sequence: 1 3 8 9 3 1
Using the Up and Down buttons on your remote control select 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
Press the Enter button on your remote control
I hope this works for you (:-)
Sep 08, 2009 | Televison & Video
SONY Remote Control - some buttons do not work.
Usually this means the conductive contact on the back of the rubber pad has worn down and cannot connect the circuits on the remote controls main board. There are several ways to fix this.
#1 Find some conductive adhesive or paint and carefully paint the back of the button tab ( let dry completely)
#2 Rear window defogger kits are available at most reputable auto parts shops and contain a paintable adhesive which you can apply to the back of the remote control button.
#3 try super gluing a small piece of aluminum foil to the back of the button tab.
I have used all 3 and they all work good.
Jun 04, 2009 | Sony RM-V310 Remote Control
Unlock codes Insignia NS-8PDVD
You may have missed a step in the procedure try this one. This information was found on the following website It is dated as working on 01-08-08. I hope this information help you with your problem. 1.- Power on with no DVD inside the player; 2.- Press open on the DVD player; 3.- Press Menu button on DVD (or SETUP on remote control), (you see General Setup Page on the screen); 4.- Press the right key 3 times to select the Preference Page; 5.- On the remote control press 9653; 6.- Use the up and down key to select the Region, Select 0 for all regions; 7.- Press Enter. (This works with NS-7PDVD and NS-8PDVD)
Jan 16, 2009 | Insignia NS-8PDVD
Unlock code for Technika DVD Faw08
The above don't work, half the suggested menu missing. No Set TV Standard option available:-(
Dec 20, 2008 | One For All URC 7740 Remote Control
Hughes Remote works the satellite but not the TV
You have to push and hold down TV and Mute button (for 2 seconds at the same time), then release them at the same time, then push channel up until the TV turns off.  Be patient and continue channel up until the TV turns off.  When it turns off, then push TV again to lock the code.
You were doing fine, but missed to push channel up to fine the code.
Oct 25, 2007 | Hughes HRMC11 Remote Control
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
