Question about Arrow Tools & Hardware - Others
Arrow CT50 stapler I am looking for a staple gun which I could use for upholstery, It would need to drive staples into extremely hard wood. Thanks
Anyone know if the CT50 cordless would be strong enough to put staples into hard wood?
    Top Expert:
  • Arrow Master
  • 78,267 Answers
Sorry we do not have that information. I suggest you contact a local Auto Trim shop and ask them what they use.
Posted on May 17, 2017
Why my arrow fastener ct50 wont staple
Open up the stapler and look for a jammed staple near the opening the staples c0ome out of, had this very same problem, just a few screws to open the gun up and a small screwdriver to pop the staple out.
Jan 11, 2018 | Arrow Tools & Hardware - Others
Will the Arrow staples # 405 fit into my Craftsman 68464 staple gun ?
thats the picture of the manual staple gun
and the picture of type of staples you want
on the staple box confirms you can use the staples in that
sears craftsman
note the staple has inches and metric dimensions
all you need to check is the stapler eject system is not worn out
or cause a jam as you try to staple
if sticky .. try some sewing machine oil on the stapler workings
Oct 14, 2016 | Arrow Fastener 405 5/16" Flat crown...
Upholstery stapler will not eject staples
sounds like they might be the wrong staple for the gun .
Jan 04, 2016 | Staples Tools & Hardware - Others
I have the Arrow CT50 stapler, it won't drive the staple, light works makes a sound like it wants to drive staple but don't. I have adjusted the power to all the way + and the battery shows 4 green lights....
It sounds like the battery is failing low battery voltage equals loss of power. The batteries used in this type of tool are the cheapest ones out there to keep the cost of the tool low, and have a very short lifespan, it is not the number of times used but how old they are that is the main factor
Feb 28, 2011 | Arrow Ct50k Professional Cordless Staple...
What size staples and what size Arrow stapler do I need to stable coaxial cable
I would use 1/2 inch or larger. Set the staple into the wood and then pull gently to see if it holds.
Jan 06, 2011 | Arrow T50P ARROW STAPLE GUN
I have a manual Craftsman stapler 68447 and an electric Craftsman stapler 68417 and need to purchase 1/4"Monel or stainless steel staples to do some marine upholstery. Where can I find staples for either...
you can try here:
http://cgi.ebay.com/NEW-ARROW-1-4-MONEL-STAPLE-504M1-/220606637809?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335d2e26f1#ht_2432wt_911
I checked the crown website and it is a little bit harder to buy from them
if it works for you don't forget to rate me
thx
May 21, 2010 | Arrow Fastener #508M1 T50 1/2" Monel...
Do I need to adjust the T50P to use short staples (like 6 mm). It is not working at all. The staples just pop off the surface. The 12mm are just barely going in to a wood chair frame I am working on.
You MAY need to lube the stapler. Use ONLY staples labelled for use in this stapler. Also check if there might be a smashed staple blocking the driver from doing a full stroke.
Jan 09, 2010 | Arrow T50P ARROW STAPLE GUN
Arrow et2025Hd staples won't go flush
The material you are putting staples into is too hard for this little staple gun.
You will need a more powerful stapler, such as a staple gun that uses compressed air to drive the staples and where you can adjust the air pressure.
Apr 30, 2009 | Tools & Hardware - Others
The staples do not enter the wood completly
often when squeezing the tool the front gets lifted and the staple does not set fully. try making sure the front is tipped down fully and in contact wood when it fires. if that doesnt work the push rod is not working properly and is easier to replace than try to fix
Apr 22, 2009 | Arrow CHROME STAPLE GUN ARROW IND....
Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Aug 27, 2008 | Arrow T59 Wire & cable staple gun
Tools & Hardware - Others Logo
60 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
