Question about The Computers & Internet
Recorded shows don't appear on DVR page, why?
My whole house sling is showing unlinked. Everytime I hit the button to link, nothing happens.
    Top Expert:
  • The Master
  • 76,682 Answers
Faulty DVR or the hard drive is full and can store no more data.
Posted on May 18, 2017
  • 86 Answers
SOURCE: Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Posted on Jan 22, 2008
  • 374 Answers
SOURCE: Dish Network DVR 625 Problem with playback of recorded shows
It sounds as though the hard drive is about to go south on you soon and the receiver is going to need to be replaced however, in the interim you can change the options of the recordings and make it a default so that the recording continues past the end of the show. It is possible that extending this time will allow you to view the portion you want before it skips to the end. In order to do this press the guide button and select a program in the future. On the create timer screen select the option icon. You will now be at the timer options screen you can extend the time the recording will last after the end of the show and when it will begin recording prior to the show. I would also set this as your systems default so that it performs the same way regardless of what you are recording. According to the latest known receiver issues this is not identified as it is a common indication that the hard drive has an error internally. If this works I suggest that you have a replacement sent to you so that you do not lose the use of your DVR un-expectantly.Remember to watch all recorded events prior to replacement as you will lose that info when the receiver is swapped. Thanks for using Fix Ya.
Posted on Mar 10, 2009
hmerchant110
  • 7191 Answers
SOURCE: "oops, this link appears broken" appears on many attempts to open websites
What is the url you are trying? I see no problem opening http://www.shutterfly.com
Posted on Apr 19, 2009
SOURCE: Dish 625 DVR recorder won't play recorded shows.
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
Posted on Sep 05, 2009
  • 374 Answers
SOURCE: Dvr not working. Won't record, pause rewind
Try unplugging the unit from the electrical outlet for about five minutes- much longer than required- and try it again. If this fails you will need a service technician to resolve the issue. Thanks for using Fix Ya.
Posted on Sep 28, 2009
Bunker hill 67139 dvr hard drive wrong year 2058
The issue may be is that you have a DVD in your dvr , that still shoes that date and time. Just a possibility, not sure,. try to see if you can take DVD out of dvr, and use a new one. I happened to me but, the case was a vcr,and I had a recorded video tape which while playing , was showing a blue screen, with "no data received" which actually it was when no data vcr was receiving from cable at the time it was recording . If the problem still is not solved then there is issue with some circuits, and processors. Also you may want to check if Bunker Hill has any customer support, to check with them.
May 18, 2014 | Televison & Video
Ustvnow dvr tv shows unable to watch recorded shows when press play without causing tv screen to flicker twice and not able to watch tv program
It appears it is not your fault. I contacted ustvnow and they said they are "working on it" but currently the DVR service is not available on roku. If you find an answer elsewhere, I'd love to hear it
Dec 01, 2012 | Televison & Video
Is there anyway to get recorded shows back that were accidently deleted?
Hey there, Cheri Torres with DISH Network Customer Service here. There is unfortunately not any way to get recorded shows that have been accidentally deleted. What you can do for next time is connect an external hard drive to your receiver. The external hard drive will need to be a minimum size of 50gb and maximum size of 2tb for DVR receivers and minimum 50gb and maximum 1tb for non DVR receivers. This will save all recorded shows in case anything should happen to your DVR receiver. I hope you find this information useful and if you have any further questions or concerns feel free to email me directly at Cheri.Torres@Dishnetwork.com.
Jun 02, 2011 | DISH Network ViP722 DTV Receiver /...
How do I use "look
I'm assuming that you're referring to the Look Back service offered by Time Warner Cable. If not, then ignore this.
Look Back allows you play back shows that you might not have recorded on your DVR (maybe you don't even have a DVR). The time window is within 3 days after the show airs, and it's only for specific shows... oh, and only on certain channels.
If you are on a Look Back-enabled channel, an Enhanced logo will appear on the screen, at which point you can hit Select on the remote to access it. From there, you can go to the day and program that you wish to watch. For more info, refer to Time Warner Cable's website. This website is for Texas, but it gives you an idea (to get the specific Look Back channels in your area, you'll want to change your location at the top of the page):
http://www.timewarnercable.com/texas/site.faqs/DigitalCab/#Look+Back
I hope this helps.
Mar 02, 2011 | Televison & Video
Trying to dub from dvr to vhs vcr
Is L2 for composite video (yellow) or S-Video? Try watching a video on L2 with the composite video plugged into the back of your TV, if it works, then do the same with the DVR, if that works, then run the DVR composite video into a receiver, then the L2 from the VCR to the video out on your receiver. It's possible that the VCR won't record anything that isn't an applified signal. That's what the receiver does.
Oct 01, 2009 | Sony RDR-VX555
Dish 625 DVR recorder won't play recorded shows. It gives me an error code (05)
Sep 05, 2009 | DISH Network DVR-625 DTV Receiver /...
Unable to record show on the DVR
Try a hard reboot. Hold the power button on the box till it turns itself off. It will turn itself back on. After restarting try to record live tv. If you can't watch recorded shows either your harddrive may be fried. After thought, a $20 tv tuner card from e-bay for your computer, you could record them to your desktop.
Mar 11, 2009 | Televison & Video
DVR not playing.
Try this: Press the power button and hold it for about ten seconds and let the system reboot. Try to use the dvr again. If that was unsucessful try unplugging the receiver from the wall outlet for approxiamately 30 seconds and repower the systen and try again.
If these have not worked You can press menu-6-1-3 and view the system info screen. Go to the details options and select it. Once the details screen loads arrow all the way down until you see the values of which value 9 is the last one. If value 7 is not 4 you need the unit replaced. If all the above did not work the unit will still need replacing as the hard drive has locked up.
Dish has a new receiver called a 222k which has an expansion USB port that will allow you to use an external hard drive to use as the dvr as the 222k is not a DVR unit; it is a HD dual tuner. The external hard drive offers many advantages such as being able to take your recordings on the road, ability to keep recordings if the receiver fails, etc. Another awesome device they have also is called a sling box which will allow remote viewing of your Satellite from a remote location over a laptop, PDA, or cell phone.
I hope this helps you and thanks for using Fix Ya.
Dec 05, 2008 | DISH Network DVR-625 DTV Receiver /...
Jan 22, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Toshiba dvr 160 gig can't play dvd's
While Pressing Easi Navi-Hit the number 2 on the remote control
Jan 01, 2008 | Toshiba 160HD4 160GB HD Digital Video...
Computers & Internet Logo
44 people viewed this question
Top The Computers & Internet Experts
d3yavu3
kimblebear
Level 1 Expert
baklogic
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
