Question about HP Garden
24 hp zero turn mower... It is only hitting on 1 cyclinder ... Ferris mower
    Top Expert:
  • HP Master
  • 79,865 Answers
Check spark on errant cylinder, if that is ok check the cylinder compression as compared to the good one. Also check for intake manifold leaks, a vacuum leak can cause this problem.
Posted on May 17, 2017
Testimonial: "Thanks will check on this."
What plug type goes in this engine
Since you did not specify the engine type, here is a site to find the correct plug and gap: http://www.briggsandstratton.com/us/en/support/faqs/identifying-the-correct-spark-plug-and-gap
Apr 19, 2015 | Ferris NEW 44 IS500 Series Zero Turn Lawn...
How do I get a belt diagram 5100 z ferris diesel
I see you need the complete model number to do this.. here is their website.. hope it helps.
http://www.ferrismowers.com/us/en/support/manuals
Oct 07, 2014 | Ferris 72 IS5100 Zero Turn Lawn Mower 33.5...
My ferris IS 3000 zero turn mower. why will the right rear wheel will not move?
FIRST CHECK THE BRAKE MAKE SURE IT IS FREE,IF YOU CANT TELL DICONNECT IT. NOW THAT IS NO FACTER,CHECK THE BELT DRIVE MAKE SURE ITS ON/TIGHT,NO CHECK THE OIL LEVEL FOR THAT SIDE IN THE RESUVORE,I DOD KNOW IF HAVE TWO SEPERATE TANKS OR JUST ONE.NOW I WOULD JACK THAT SIDE OFF THE FLOOR[TIRE] ,GET A PAN UNDER THERE /REMOVE THE FILTER ON THAT SIDE.WHEN CRANKING THE ENGINE TO START OIL WILL SHOOT OUT IF THE ABOVE IS CHECKED.IF NOT REINSTALL THE FILTER,REFILL THE OIL,AND START MOVE THE FR LEVER BACK /FORTH WHILE LOOKING AT THE HYDROSTATE ROD THAT THE LINKAGE IS HOOKED TO IS MOVING,TIGHTEN IF NOT,IF ALL ABOVE LOOKS GOOD THEN MY FRIEND YOU HAVE A BAD HYDROSTE,BE NICE TO HERE BACK STEVE
Jun 09, 2014 | Ferris IS1500 52"" Zero Turn Lawn Mower...
Ferris mower cranks but won't start
FIRST DO HAVE GAS IN TANK,CHECK TO SEE IF VTHE BLADE SWITCH IS ON.NO THAT OUT OF THE WAY STILL NO START YOU WILL NEED TO CHECK FOR SPARK AT THE PLUGS,CHECK WITH A PLUG TEST LIGHT,IF YOU HAVE SPARK AN FUEL,PULL THE FUEL LINE FROM THE FUEL PUMPTO THE CARB,HOOK UP A TEMP LINE PLACE IN A POP BOTTLE AND CRANK IT OVER,IF YOU HAVE NO FUEL ETHER YOUR FILTER IS PLUGGED OR THE VACUME FUEL PUMP IS BAD.STEVEH
Apr 16, 2014 | Ferris IS2000 61"" Zero Turn Lawn Mower...
Ferris ztr model is4500z pto quit while mowing and wont re engage
check for power and ground going to the clutch and see if you have a bad clutch or bad wiring or switches
Jul 31, 2012 | Husqvarna Zero Turn Mower Z5426
What hydraulic oil do i use in my ferris 1500 mower
Ferris doesn 't standard hyd oil. They fully synthetic 15-50w like Mobil 1
Apr 04, 2012 | Garden
Garden Logo
Top HP Garden Experts
Vernon Taylor
michael vanier
Are you a HP Garden Expert? Answer questions, earn points and help others
