Good day guys, i have an lcd tv that has dvd player attaches to it, when i insert dvd plate, it says error disc, i mean any dvd plate. pls what do i do?
    Top Expert:
  • Televison & ... Master
  • 77,499 Answers
Replace the player, these are not repaired due to the low cost to replace. You likely have a laser burned out.
Posted on May 17, 2017
SOURCE: DVD PLAYER
I used the suggestions from post 1 and they are sending me a 2007 dvd player and I don't even have to pay shipping. This will at least get you a free replacement that works!
Posted on Jun 26, 2007
SOURCE: Bad Disc - CH-DVD 300 DVD Player Problem
Goto the following site: http://www.drx9000repair.netfirms.com/#Cyberhome%20CH%20300 You more than likely have a bad power supply. The caps in the output circuit are pretty crappy and are well known for failure. Good luck! Art
Posted on Aug 22, 2007
  • 1003 Answers
SOURCE: DVD player says "no disc"
replace the player because laser lens is probably burnt out.
you can get a new player for 30 bucks at target or walmart
Posted on Jan 15, 2008
  • 12 Answers
SOURCE: Disk error with Kenwood DV-605 multi-disc DVD player
Try the following
when the error is on the screen, press the number 1 key on the remote, this should take you to the fist chapter of your DVD no matter which region it is
Miguel
Posted on Feb 16, 2008
  • 14 Answers
SOURCE: Built-in DVD player
Are you trying to play DVD's you've made or copied yourself or new one's you buy from an actual distributor? Because sometimes self-ripped Cd's & DVD's won't play on a LOT of DVD players. Otherwise it's bad DVD player and you should go get it swapped out if it's not too late.
Posted on Mar 02, 2008
FUNAI B2735 DVD/VCR COMBO
Have you tried a blank DVD with lower speed say 4X? Or for that matter, some other brand of blank DVDs?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 28, 2008 | Funai PY90VG DVD Player/VCR
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
"No disc" error
This means that the lens of your dvd player is having a hard time reading the discs. It could be dirty. You need to run a disc cleaner to run into your player for like 30 seconds. It it does not solve the problem. You might need to clean the lens manually. Open the casing and unscrew the plastice plate covering the lens. Then get a q tip damped in an alcohol. Gently wipe on the lens' surface and let it dry. Return everything back and play those discs again.
Feb 13, 2010 | Daewoo DVG-8500N DVD Player
I was watching a dvd wen it froze, i took out the disc and the nxt day the dvd player just says no disc! ive cleaned the dvd player but it still doesnt work! this tv is a bush flat screen dvd combination....
This means the disc is not spinning, replace the 5V motor or the optical lens has conked out. The display LCD is OK.
Looking at another angle, the motor plus lens is most likely error in that case a change of internal fuse will solve the problem........sodeep
PS: if its the lens, buy a new set !
Oct 27, 2009 | Philips DVP3962 DVD Player
Built-in DVD player in tv stopped reading discs
try to clean the laser lens with rubbing alcohol and a q-tip. be gentle
Sep 24, 2009 | Televison & Video
The screen says no disc even when I put a DVD in
Dear friend,
Pls clean ur dvd palyer lense or replace ur lense
Mar 28, 2009 | Cyberhome CH-DVD 300 DVD Player
Dvd reads wrong disc
Since 4 days I've searched 99% of internet to fix 'Wrong Disk' solution for my DVDV822-05 Player, but I could not get any such solution. Some solutions for other players of the same company is to change region codes but I could not find these codes for this particular model. I got this player from some other country which I dont know. It's sayying 'Wrong Disk' to all disks either MP3, audio, VCD, DVD etc. It's my humble request to all e-guys and companies to find some solution for this model.
Jan 02, 2008 | Televison & Video
Panasonic DMR-ES15
Just unplug it and let it sit for half an hour. Then try playing the lens cleaner disc, the problem would be fixed....
Sep 10, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
