Question about Furniture
How do I replace the LCD display on my salton 8-bottle wine cooler.
My wine cooler has started to make a constant, mid-pitch beeping noise and the lcd is rapidly flashing. The noise is coming from that and it has become very annoying.
5 Suggested Answers
t0pc4t
  • 132 Answers
SOURCE: Magic Chef wine cooler clicking
If I was abetting man - I would suspect that the fan is polarised, and has been wired incorrectly..
Check that there is nothing obvious in the way of the fan blades..
Posted on Aug 15, 2008
  • 833 Answers
SOURCE: 8 bottle wine cooler unit won't cool
First, see if the fan is actually blowing anything out of it. YOu may have an obstruction. If not that...Generally, there are three reasons that you won't get cooling:
  • The condenser radiating fins on the unit are dirty which won't allow cooling air flow to liquify refrigerant. Clean them.
  • The unit is frozen up inside because of excessive humidity. Defrost the unit by leaving it off and open for a day.
  • The unit is low on refrigerant. Check this by leaving the unit off for one hour. Locate the pipes coming out of the compressor. Turn the unit on. If the larger pipe stays frosted up for more than 15 minutes, you need to get the unit charged.
Posted on Jan 04, 2009
  • 11800 Answers
SOURCE: I have an emerson fr24sl
The flashing signals that the thermoelectric element - the on that does the cooling - is no longer operational or the wiring between it and the control board has failed. To find out which you must open the cover on the control board and test them with a ohmmeter. Since the replacement parts are very hard to obtain by an regular person it would be better to take it to a repair shop.
Posted on Oct 11, 2010
emissionwiz
  • 77499 Answers
SOURCE: trying to find a rplacement lcd display for salton wine cooler, model wc2002
Sorry we do not sell parts or do we have any locator service for parts.
Posted on May 17, 2017
Whirlpool 22" wine refrigerator wwc287bls. Makes a high pitched sound pretty much constantly (compressor seems to run constantly too)
Howard, We're sorry to hear about your Wine Cooler making a high pitched noise. Our Wine Coolers are handled by a different department. Please call 800-263-2629 for assistance.
Jun 13, 2017 | Whirlpool Refrigerators
Trying to find a rplacement lcd display for salton wine cooler, model wc2002
May 17, 2017 | Furniture
How do I program the temp on a Salton 12 bottle cooler?
It depends on the model Alan. Some have a digital control on the front panel and some have a rotary knob on the inside.
A list of all the Salton instruction books are here.
https://www.salton.com/instruction-books-manuals/
Jun 12, 2016 | Furniture
How do I get a PCB70323E1
Have you looked at the back of the board for burn outs?
Jan 17, 2015 | Emerson Fr24sl 8 Bottles Wine Cooler With...
I have an Haier 8 bottle counter top wine cellar. No electricity to digital display, rear fan is not on and does not cool. Looking for schematic for possible fuse location.
look down of the wine celllar and take off the plastic cap and clean the electrics contact. After that use use the 4 screwed support to give it the right inclination._400.jpg
Apr 10, 2010 | Haier HVUE08A Wine Cooler
COOLER IS GETTING POER BUT NOT COOLING. TEMPERATURE CONSTANTLY SHOWING 72 DEGREES.PLEASE SUGGEST TROUBLE SHOOTING. #K0700305460011335 MODEL: OW0912H6H
Check the lint trap behind your cooler to make sure it isn't clogged... I had the same problem and after vaccuming the lint trap, my cooler started cooling again
Feb 06, 2010 | Oster 12-Bottle Wine Cellar - Black
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
Does not cool. Compressor Hot
Sounds like the compressor starting relay. This should be available from from most appliance parts retailers that carry refrigeration parts. It is probably a plug-in relay which is easy to replace. PULL THE PLUG UNTIL YOU GET IT! Constant cycling on the thermal protector will damage the unit.
Ray
Oct 19, 2008 | GE PWR04FANBB Wine Cooler
Furniture Logo
27 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
