WEATHERKING 10AJB48A01 COMPRESSOR NOT WORKIN. I FIXED ELECTRICAL CONNECTION ON COMPRESSOR AND IT WORKED JUST FINE FOR A COUPLE OF YEARS.
UNIT WAS DAMAGED BY SANDY STORM, I REPLACED CAPACITOR, RELAY AND FAN MOTOR. UNIT WORKED FINE UNTIL LAST AUGUST.
    Top Expert:
  • Heating & Co... Master
  • 77,499 Answers
I would pull and test the motor, it may be burned out.
Posted on May 17, 2017
Testimonial: "UNIT WAS UNDER WATER DURING SANDY I REPLACED FAN MOTOR AFTER THAT, MOTOR NOT BURNED OUT, NEW MOTOR, NEW CAPACITOR, NEW RELAY."
  • yadayada
    yadayada May 18, 2017
    I am not a mind reader, all I know is what you write. If it was underwater or worse salt water, scrap the whole thing it is so much junk..
10ajb48a01
One year labor and 5 on the compressor only. and it is 14 years old right?
Aug 21, 2014 | Heating & Cooling
Trying to get info (tonnage seer rating) on a weatherking mod# 10ajb48a01 condencing unit to find a matching evaporator coil and cannot find anything on internet
This is a 4 ton model condensing unit. You can go up 1/2 ton for the evaporator, meaning a 4 1/2 (A) coil will work just fine and allow a bit more cooling capacity.
Sep 10, 2011 | Weather King 12AJA4801AH Air Conditioner
Compressor Problem WeatherKing 13AJA36A01
Your warranty on your WeatherKing is five years on the compressor. When you buy a compressor to go in your unit it is 1 year. Several resons for bad valves. Dirty evaporator coil, overcharged and bad evap fan motor. James
Jul 10, 2009 | Heating & Cooling
WEATHERKING 10AJA4801 BAD COMPRESSOR
You have 10 seer 4 ton unit. A compressor install in my company (4 ton) is about 1400 dollars. Remember when you change compressor you only get a 1 year warranty. A new unit can have as much as 10 year compressor warranty. Amana has a 10 year parts and labor with their unit. The new unit will be 13 seer and you may have to install a TXV inside. You might think about changing the whole system with the new 410A system. Either way a new condensing unit is needed. I have not had anyone just change a compressor in an older unit. Just not cost effective. Get several estimates before you make up your mind. Rus
Jul 04, 2009 | Heating & Cooling
I have a weatherking 13AJA60A01 Ac unit and the condensor fan is not moving, I can hear a sound assuming electricity goes through the system but the condensor fan not working. The unit is just 1 year old...
Weatherking has five year parts on there equipment. You may just have a breaker kicked or tripped float switch. Check for stopped up drain Shop vac **** out stoppage from the outside drain line for unit. Check breaker. The sound you here maybe the contactor. It energizes from the tsat inside. If the contactor energizes. You have a high voltage problem. Your warranty covers aprts not labor. So call a Rheem ,Ruud or Weatherking dealer. Any of these dealers can handle warranty parts. Rusty Feadback please.
Jun 13, 2009 | Weather King 10AJA3601AH Air Conditioner
Compressor valve failure
That is not correct. The system is not mis-matched. They just put a heavy condensor outside to get more air volume for your house. The failure of the valve is not to common of a failure but can and will fail. The problem with Palm Springs is the weather you get there, From very hot to very windy with sand storms to freezing rain and sometimes snow depending on where you are. What is the tech wanting to cahrge to replace the valve? Also this is something that should have been looked at closey and examined before the home was bought and that should have been known by the realator
May 22, 2009 | Heating & Cooling
2 TON WEATHERKING HEAT PUMP VIBRATION AND NOISE.
Your friend is correct. Installing a sump or p-trap in the suction line will probably help. The oil may be leaving the compressor but can't get back.
Feb 23, 2009 | Weather King 10AJA6001AH Air Conditioner
Weather King 10AJA6001AH Air Conditioner with bad compressor
If it is five years old it is either right in or out of warranty a service tech can determine this through the serial number. If not the unit is only a little bit more to replace than the compressor. A replacement compressor is only warrantied for one year verses a unit replacement with five years on the compressor and one year parts and labor.
Oct 04, 2008 | Air Tools & Compressors
I'm working on a Weatherking 10PJA with a 24AH. Is that a muffler or filter/dryer coming off of the compressor discharge line? What type of metering device is on the indoor coil? Thank you in advance for...
It is a filter, probably to collect either moisture or contaminents. This unit most likley has a fixed metering device oriface where the evaporator connects to the line set.
Aug 21, 2008 | Heating & Cooling
WEATHERKING AC MODEL # 10AJB48A01
Many different problems there. Is unit humming? Make sure you have power comming in to your contactor on unit first. Ensure your calling for unit to come on. If those don't work let me know and we can go further..
May 23, 2008 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
