Can i please have help with abt1512question paper for 2015
Non-recognition of the paper in the printer HP 2015
Hi mosayeb mohebi
I would be happy to help you with your Laserjet 2015. Based on your description, it sounds to me like you are experiencing a paper feed issue. Please use the following link to locate a document specific to the issue at hand:
HP LaserJet P2015 Printer series
If the issue persists, I suggest calling us. What you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get phone number
Case number and phone number appear.
I hope this helps.
I work on behalf of HP.
Jul 04, 2015 | HP Laserjet 2015 RM1-4251-000 Input Paper...
Follow instrctns in right cover to remove
Probably is a paper jam. Make shore that you remove all the peaces of paper.
If you have any more doubt reply to me so i can help you
Mar 31, 2011 | Ricoh Aficio 2015 Copier
When copier turn on and taking copies first 6 copies are printing with some scartches and it comes to paper jam in every. Please reply me with a best solution?
If the paper is not getting out of the tray, the rollers need cleaned.
The scratches. If the paper jams in the hot area. You will need a new hot roller.
Also the scratches may be coming from the drum. Sometimes it is hard to determine between the drum and fuser hot roll.
Aug 27, 2010 | Ricoh Aficio 2015 Copier
Hp laser jet 2015 it roll the paper
is the paper rolled around the fixing assy, or goes out rolled?
If it comes out rolled these means that you have too much moisture on paper used for printing.
In paper tray flip the paper upside down. If now the paper comes relatively OK, open fresh package of paper.
Hope that helped!
Aug 06, 2010 | HP Office Equipment & Supplies
Ricoh 2015
Please check the paper size sensor on the paper tray,
The sensor is located in the right-front corner of the tray when you will open it see do is the correct size set and see the position of the paper as it is set in the tray.
Please answer do this is helpful for we to know do have need for some more information
Jan 22, 2010 | Ricoh Aficio 2015 Copier
Paper coming out from the tray is folded for richo 2015
You do have a fuser problem. There are a set of stripper fingers that are supposed to keep the paper from wrapping around the heat roller. One of them may be damaged and is catching the paper. The Pressure roller can also cause problems if it is torn. You need to have the fuser looked at by a tecnician to determine the problem. Hope this helps.
Jan 26, 2009 | Ricoh Aficio 2015 Copier
Printing problem with HP 2015 Laserjet Printer
If you have an adjustable paper tray, make sure that the tray is set for the right size paper. Also, you may have some type of sensor in or around the printer tray that tells the computer when the paper tray is empty. Sometimes these sensors get stuck and you have to free them up (very gentley).
Hope that helps - Ghost
Oct 27, 2008 | HP LaserJet P2015dn Printer
19 people viewed this question
k24674
jasbo
jasbo
