Question about Electrolux Ovens
Electrolux icon gas oven lights are flashing continuously as if went thru a power recycle, but my normal process to reset by turning oven on to any cycle and temperature is not working.
Prior to this recycle flashing today, the only oven cycle that would function for past few days is CONV BAKE. It didn't work on BAKE, CONV ROAST or BROIL.
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
  • 3 Answers
SOURCE: Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Posted on Dec 30, 2007
  • 33 Answers
SOURCE: Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Posted on Dec 17, 2008
    • 905 Answers
    SOURCE: I have an electrolux icon
    yes, if the humming is not the loud sound then the fan may need some lubrication or if it is tripping the circuit it will need replacing , but if it seems like it is a viberating noise from the fan , then it could be that its bearings are bad , but the whole fan motor would still need to be replaced , but if it sounds like it just may be a loose fan motor , then tightening up the screws on the motor would stop the vibrating sound and or the fan blades from scraping metal( another sound you may be hearing )
    Posted on Dec 24, 2008
    fixyourboard
    • 310 Answers
    SOURCE: Display has very light illumination and does not display temp.
    This is a failure in the electronic range (or oven control) ERC or EOC. You can replace it with a new one, or have it repaired.
    - www.fixyourboard.com
    Posted on Jul 26, 2009
    Remove oven racks
    Hello Laurent, thank you for your post!
    I see that you have removed your oven racks from your Electrolux oven and the lights continue to flash and not start. This could be a miscommunication within your oven and I would recommend performing as reset. You can reset your oven by flipping the circuit breaker off for at least ten minutes. If the reset does not help correct your issue it could be a problem with your sensor or control panel. We would then suggest having a professional technician out to perform a proper diagnosis to avoid any unnecessary part purchases. Best of luck! -Matt
    Dec 18, 2015 | Electrolux Ovens
    Electrolux E36DF76EPS Why does the lock light keep flashing ( note oven works normally )
    Hello Thecarsons, thank you for your post!
    I understand that the lock light on your Electrolux range keeps flashing and everything else is working properly. This could be a potential problem with your latch or control panel. I would recommend looking over the latch or strike for any visible damage. If you do not see any, I would suggest performing a reset on your range. You can reset your range by disconnecting the power cord or flipping the household circuit off for at least ten minutes. If that does not resolve your problem you may need to have a technician out to your home to provide a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
    Jun 10, 2015 | Electrolux Ovens
    Electrolux oven wont stop beeping
    Hi Friend, I am happy to assist you!
    I understand your Electrolux oven is continuously beeping. Without knowing your specific model number, let's try resetting your oven. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is best to wait roughly ten minutes and then turn on your oven. If resetting the power does not correct the issue, then your range could possibly be experiencing a communication problem with the EOC (electronic oven control) or a potential wiring failure. Hope this helps! - Z
    Jul 13, 2014 | Electrolux Ovens
    Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
    Good Afternoon Friend,
    I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
      1) Place the rack holders and the racks in your oven.
      2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
      3) Restore power.
      4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
      5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
      6) Take the racks and rack holders out and start the self-clean cycle again.
      I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
      -Best Regards-
      WP
    May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
    We have an Electrolux Icon oven and cannot get the self cleaner to work. We removed all racks (including side racks) turned it to clean and nothing happened. We shut off the power and turned it back...
    There is a small white plastic triangular switch that needs to be in the out position for the oven to recognize that the racks have been taken out. Look at the back left side WITHIN the upper rack support channel. (This is not the small U-shaped piece that can be seen slightly lower on the wall oven.) If the switch is still depressed, with power turned off at the breaker, depress the switch using a small screwdriver. It should pop outwards to the proper "racks out" position. When we had this problem and recycled the power, we again got the signal. Husband switched to a nonconductive tool and repeated the depressing/releasing of the switch while the oven was giving the "remove racks" command. It sensed that all was well and now operates properly. If this does not fix the problem, you may have to replace a board $$$.
    Aug 01, 2011 | Electrolux ICON Designer E30SO75ESS Oven
    What to do by Err 23
    Hi, i had the same problem. I called Electrolux and they said it is a mis-communication between the panel and the timer. You have to turn off the power (throw the breaker) to the oven and leave it off for one minute. When you turn the power back on the oven should reset itself. If you can't turn the oven on then a service call is needed. My oven came on and I was able to use it after that.
    Take care
    May 13, 2010 | Electrolux ICON Designer E30SO75ESS Oven
    I have an electrolux icon double wall oven. I turned on the self-clean function for 3hrs and it making a very loud noise during the cleaning process. Is that normal?
    Dec 24, 2008 | Electrolux ICON 30 in. Double Wall Oven
    Electrolux EOG7330 gas cooker - electric timer fails?
    Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
    Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
    Glass
    glass is glass. wouldn't say its normal but not an unheard of complaint, YOu purchased an ICON, id call the manufacture, wouldnt be suprised if htey took care of that for you! thats their pride and joy!!!!!
    Feb 27, 2008 | Electrolux ICON 30 in. Double Wall Oven
    Electrolux Wall oven E30EW75ESS
    Same F23. Resetting the beaker seems to fixed it. Thanks to all
    May 27, 2007 | Electrolux ICON Designer E30SO75ESS Oven
    Ovens Logo
    64 people viewed this question
    Top Electrolux Ovens Experts
    Mack Baxter
    John Tripp
    John Tripp
    Are you an Electrolux Oven Expert? Answer questions, earn points and help others
