How to make my mouse larger. I have an android.
How do I install wireless mouse on my virgin telly tablet
Wireless mice come with a wee USB transceiver. You should be able to find one for U$20 or less for the least expensive model.
If Android 6.0 Marshmallow supports USB mice (which is the OS the Virgin Telly site says is running your unit), all you need to do is plug the transceiver into one of your USB ports, put batteries in the mouse, and start mousing it up. :)
I'm no Android expert, so I can't speak to the particulars of your OS, but normally an OS will tell you that it is installing a device when you plug it in for the first time.
Cheers, and good luck!
Nov 22, 2017 | Computers & Internet
How do you make the letters and numbers larger
In android phones you would find this feature in settings and then accessibility .
Tap on "settings" scroll down to find "accessibility "
And then find "large text "
This can be turned off or on as required.
Sep 14, 2015 | Cell Phones
How to connect HP WiFi mouse to nextbook 7
Android machines like Nextbook 7 do not accept mouse or keyboard working over wi-fi, only Bluetooth (if compatible) or direct using usb.
Mar 03, 2015 | HP Computers & Internet
The print is too small. How do I adjust print larger?
Holding down the Ctrl key turns the mouse wheel into a size changer...up is larger and down is smaller. You can also hold down the Ctrl key and repeatedly press the + key for larger or - key for smaller.
Sep 20, 2013 | Yahoo Mail
How can i make my letters bigger
you need to change your font and size settings. If it it isn't on the tool bar, right click mouse in tool bar (top of screen) area and choose tool bar properties. You may need to move mouse over different areas , don't give up, right click is your friend.
Sep 21, 2012 | HP Computers & Internet
My mozilla browser seems to get larger, the view is not centered. please help me.
here is what to do to make your screen smaller.
1st option.
  • If your using a mouse with a wheel, then here is what to do.
  • Hold down the control button (ctrl) and then scroll the mouse-wheel up to make your screen larger or scroll the mouse-wheel down to make it smaller.
2nd Option
  • If you don't a mouse with a wheel, you can do this instead.
  • Hold down Control Button (Ctrl) and then press minus ( - ) to make your screen smaller or press plus (+) to make your screen larger.
  • You can use the minus( - ) or plus (+) either in the keyboard or in the numpad. They both works.
Hope my solution helps. Thank you for using Fixya!
Jul 08, 2011 | Mozilla Firefox
I just bought a netscroll optical mouse,but the
Yes you can get a ps2 connector to usb. They sell them at Radioshack and some Walmarts. What computer are you using the brand and model? The ps2 connector should fit into the one on the tower, unless its a really old computer.
Jan 15, 2010 | Genius Mouse Netscroll 110 High-Precision...
Tote n Go laptop, mouse click not recognized
It is very likely one of the wires came loose inside the mouse itself. There are 4 black foot pads on the bottom of the mouse. With the batteries removed, pry off the four feet and remove those four screws. You will see two tiny brown wires that correspond to the mouse button.
Examine these two smaller brown wires and ensure they are not loose or have become disconnected from the small computer chip inside. The two smaller brown wires are on the interior of the chip and should be soldered to the board, opposite a larger brown wire and a larger white wire. The two larger wires, brown and white go back into the main cable that connects inside the laptop.
If these four wires appear to be intact, the next step would be to remove the two larger screws in the central blue piece with two larger holes on either side. This will release the mouse from the base. Examine the two solder points where the two brown wires are connected for any breaks. If these look good, there are two more screws that hold this chip in place. remove them and examine the button of the mouse.
Many others have found the actual push button under the mouse fails. This blog entry explains how he fixed the mouse button:
If you need further help, send a request to: kjhenseler [at] gmail [dot] com
Jun 18, 2009 | Vtech Tote n Go Laptop Plus
Computers & Internet Logo
David Payne
David Payne
