Question about John Deere Garden
John Deere LX280 cranks but won't start
I have replaced spark plugs, fuel filter, oil filter and oil change, and bought a new battery. Air filter foam was dirty so I cleaned with soap and water, dried, put small amount of oil on foam, checked the paper part-not very dirty, so I replaced it. It ran for about 5 minutes and now it will not start for me again. I've rechecked the plugs, oil filter & checked oil, air filter, battery. I have not done anything with the carburetor or tired starting fluid yet. I'm not really sure where to spray the fluid?? Oh fuses have not been checked either as I was unsure of which one to check--there are so many!!! Can you help? I am a 60 yr old lady that does a lot of DYI projects. I would like this to be a success story also!! Thanks, Cheryl P.S. I mow all the lawns on my side of street-5 lawns-and I haven't been able to mow any yet. Onr more thing, last fall the mower died in the middle of the lawn. I put gas in it, wouldn't start. Then it got really cold, so I covered it with a tarp and left it sit. I know, BIG,BIG mistake. Plus, sometime during the Winter the gas cap mysteriously disappears. I know these added details will better help you, help me! Thanks again for your time and your help in advance!
  • John Deere Master
  • 7,515 Answers
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
Best Manuals
Posted on Jun 08, 2017
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
What type of oil does it use? John Deere RX75
some use straight 30 some 5-30 others 10-30 jd has their own oil as well the following chart showes the type
May 12, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John Deere LA105 lost power
Hi Hank:
Did you hit something with the mower, or did it happen gradually?
Probabaly a good idea to start with a basic service:
- Clean air filter
- Clean fuel filter
- Flush carbuerettor
- Fresh gas?
- Change spark plugs
- Change oil and filter
- Underside of mower deck clean and free of all built up grass?
Hope this helps.
May 09, 2015 | John Deere Garden
Why won't my Scotts brand John Deere L1742 start ?.
Check your fuel pump lines in right place
Apr 24, 2015 | John Deere Garden
John deere lt133
Engine oil does a couple of things, lubricates and cools. Your crankcase probably takes about 2 qts. Fill it to full and park it over something clean to see if there are leaks.
For your engine to run it needs fuel and air. If the engine is dying, more than likely you have a fuel/air issue. Check your fuel lines for leaks, replace your fuel filter. Clean or replace your air cleaner. Make sure your tank cap can breathe, so air can replace the gas going to the engine.
Jul 19, 2014 | John Deere Garden
John deere mower Won't start
Sounds like the carb is varnished up and needs to be rebuilt. They make rebuild kits depending on the carb number and you can rebuild it.
May 05, 2017 | Garden
John Deere will not start. fuel filter dry
some models have a fuel pump some are grivitey
May 03, 2012 | John Deere Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
John deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
May 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
95 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
