Question about Pool & Spa
Power supply problem in INTEX-IT2600 multimedia speaker
3 Suggested Answers
  • 112 Answers
Make sure you are installing the right drivers to your operating system. If this is an older sound card, goto the manufactures web page and download the updated drivers there.
Posted on Apr 04, 2008
  • 27725 Answers
SOURCE: i have bought two intex
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Apr 02, 2011
Samsung E1105F ringer problem and itel it2600 speaker problem
you can contact the service provider.....
Aug 13, 2011 | Cell Phones
My keyboard does not work short cut keys are working. my keyboard modal is intex multimedia keyboard IT-2015MM (SD0080)
Some keyboard manufacturers supply driver cd/dvd for their keyboard for fully functionality of extra multimedia and shortcut keys. Install the keyboard driver that supplied with else change a new one.
Aug 08, 2010 | Computers & Internet
I have a pair speaker altec lansing model acs300.1 i need the power supply transformer
Buy some broken ones off eBay, throw them in the bin and just use the power supply :D
Dec 15, 2009 | Altec Lansing Multimedia Computer Speakers
I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
May 02, 2009 | Altec Lansing AVS 300 Computer Speakers
Driver for INTEX PC it-102 WC silver
Hi! it's Amit..
m sending intex driver link to u..
pls Download and install it..
Dec 09, 2008 | Logitech Quickcam Chat Webcam
Apr 03, 2008 | Creative Labs Sound Blaster Live! 5.1...
Intex 3D multimedia pci soundcard
Hi, check your speaker leads and speakers, if both of these are ok replace the sound card. a good test for the speakers is to use them with the onboard sound to see if you still get the growl.
Regards mistyman
Nov 06, 2007 | Computers & Internet
HI Surthi
First thing came basic, check your speakers with other PC, and see if work correctly, then use the software control volume to see if not set to "mute" connect the speakers to the right slot in the sound card, sometimes according to the colors, usually green. see if you have installed the drivers for your sound card.
good luck!
Nov 05, 2007 | HP (PP036AA) Computer Speakers
Pool & Spa Logo
22 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
