Question about Sewing Machines
The material is bunching up in front of the feed dogs
  • 84 Answers
SOURCE: My fabric won't advance.
Hi Jodyk...Remove your flatbed so you can access your bobbin area. Open the cover of the bobbin area. The shiny/bright components consist of the Bobbin, which snaps into the Shuttle Hook, which is contained in the Race. Immediately right of the Race is a pewter/matte silver colored lever. Press the lower portion of the lever to raise the Feed Dogs. Pressing the upper portion drops the Feed Dogs, and is commonly used to accomplish free-hand applique work......good luck my friend.
Posted on Aug 02, 2007
  • 192 Answers
SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
  • 202 Answers
SOURCE: Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
Posted on Feb 07, 2009
  • 11 Answers
SOURCE: Feed Dog problem
I listened to all that...and none of it I took the plate off and gave it a good clean. Still nothing. If your machine's a bit old like mine or tends to get stuck...physically lift up the feed dog with your fingernail or a flat screw driver or something (once the plate is off), then push the feed dog lever across and release the feed dog. It should hold in place if nothing else has worked...woo!!! :)
Posted on Feb 18, 2009
SOURCE: feed dogs are not pulling the material back
White sewing machine model 510, feed dog problem; fabric is not moving; I must firmly pull fabric through.
The feed dog is moving; fabric is not.
The fabric is not feeding properly; the fabric goes back and forth. However, the fabric does not continue to move away from me.
The feed dog is positioned up and is not smooth, it feels rough when I touch it with my fingers.
Because I had not used this sewing machine for a couple of years, before sewing, I cleaned the inside with the wire brush that came with the machine.
In an attempt to trouble shoot the problem, I applied varying pressure foot levels and stitch lengths.
Does anyone have any suggestions as to what may be the problem?
Posted on Dec 11, 2009
Elna 5200Q The material is bunching up in front of the feed dogs
Are the feed dogs actually raising, moving, and dropping (raise the presser foot and hand-rotate the handwheel and watch how the feed dogs are moving)? If not, check to see if the stitch length is set well above the zero (which means it sews in place)? Perhaps the presser foot pressure is set too firm and is preventing the fabric from moving under the foot.
May 17, 2017 | Elna Sewing Machines
Janome Machine will not feed material !!
If the fabric is not feeding, the feed dogs are probably not operating properly. Check that they have not been dropped below the needle plate (which is done when darning or free motion quilting). In this setting, the feed dogs never rise above the needle plate to grab and pull the fabric.
The other issue could be that the feed dogs are defective or perhaps seized.
Since you did not provide a model, I can provide only this assistance. It would be helpful to locate (search for make model manual) for your machine.
Dec 30, 2016 | Janome Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
How do I raise the feed dogs
Make sure that your top and bobbin thread are the same and that the tension is set correctly. Then, be sure that the bobbin is put in correctly. If this happens when you are starting on an edge of your material, try putting a piece of material or even a piece of paper, like typing paper, under the edge of the material and sew a little beyond that and then onto your material. You can tear it off later. It gives stability to the edge of the material and should alleviate the problem. I hate when that happens! And, last but not least, be sure you are using the right needle. I love the ballpoint needles for most sewing projects.
Dec 30, 2015 | Baby Lock Evolve
Brother SE270D material got caught in the feed dog and the feed dog will not return to the up position
Owner's manual? Troubleshooting section? It needs cleaning, pulling the thread out, you may need a magnifier and tweezers to pull the bits of thread, possibly something like a dental tool to make sure it is clean. May need same thing on the bottom side if you can get to it. If you do not have manual, perhaps MFG website, or you will probably need it again.
Mar 27, 2015 | Brother SE-270D Computerized Sewing...
Feeds dogs are lowered even when in the up position
Check to see if there is a bunch of thread under the needle plate preventing the feed dogs from returning to run position.
This may mean having to take the needle plate off and really looking
Jul 29, 2012 | Brother CS-6000
My material won't feed through. It gets bunched up. What do I do to fix this?
you might check your feed dogs, your operation manual will show you where they are & what position to put them in to sew
Oct 10, 2010 | Euro-Pro Sewing Machines
Thread bunches up from bobbin feed.
Remove the needle plate and clean the feed dogs there could be fluff gathering.
Check your needle is not damaged.
May 30, 2009 | Singer 1120 Mechanical Sewing Machine
Machine is not sewing properly
use larger needle, check bobin thread, bobin should go one way, if it bunches up switch dirrection the bobin turns
May 23, 2009 | Bernina Virtuosa 160
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
Dec 01, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
