Question about Garden
Model # BL160 mixture of oil to gas and what kind oil
    Top Expert:
  • Garden Master
  • 77,932 Answers
The mix is 50 to 1 (with 2.6 oz. of two-stoke oil being added to 1 gal. of gasoline). Use any approved two stroke oil, I prefer synthetic due to the cleaner burn and less smoke and prolongs engine life..
Posted on May 17, 2017
What kind of trimmer is this? 2 stroke or 4 stroke? Is it just gas or a mixture? If a mixture, what type?
We would need a make and model to be able to tell you this. NORMALLY, if a two stroke, the mix is stamped into the gas cap.
If it is a two stroke, you use two stroke oil, mixed to the correct amount. Again NORMALLY you are supplied with a measure to put the oil in with one gallon of gas.
May 02, 2016 | Garden
What is the gas/oil mixture for a poulan pro model BVM 200 VS. How much and what kind of oil do I add to the gallon of gasoline?
You should add two stroke oil designed for use with a chainsaw to a ratio of 25-1.
Oct 20, 2011 | Garden
Never owned a 2cycle product and some one gave me a John Deere t105c trimmer but dont have an owners manual and dont want to pay $20 -$40 for one just to find out how to fill with gas/oil mixture. Can you...
You need two-cycle motor oil, do not use regular motor oil. Almost all two-cycle motors are designed to run on a 50 to 1 mixture of gas and oil. Look for two-cycle motor oil at any store that carries two-cycle tools like chain saws, line trimmers, etc. A good bet is Lowe's or The Home Depot. If you get the 2.6 oz bottle you have to add that to one gallon of gas to get a 50:1 mixture. Always read the oil bottle for correct mixing amounts and mix the oil with the gas in a separate container then put it in your trimmer.
Jun 06, 2011 | Garden
What kind of gasoline?
  1. Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  2. Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
  3. Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
  4. Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
  5. Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
Mar 06, 2011 | Garden
What kind of gas
Regular unleaded gas mixed with 2 cycle oil. (You need to check your model for mixture ratio but 30:1 (thirty parts gas to one part oil mix) is usually a good place to start) You can find mixing instructions on the back of the 2 cycle oil container
Dec 08, 2010 | Garden
I need to know the proper gas/oil mixture.
Hello. 40 to 1,or 8oz 2 cycle oil to 2.5 gallon of gas, or 3.2oz of oil to 1 gallon of gas. Joe
Jun 05, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Oil and gas mixture
Mixture is typically 40 or 50 to 1, gas to oil. The exact mix should be stamped on the gas cap.
Apr 10, 2010 | Ryobi 15" Electric Factory Reconditioned...
What kind of oil does my 2003 rm 125 need
For the gas tank= 2-stroke motor oil mixed at 32:1 *stock mixing ratio* [that's 32-parts gas to 1-part oil]. **[I personally use a 40:1 mixture for trail riding,..and 50:1 mixture for racing at the local MX track].
Mar 16, 2010 | 2003 Suzuki RM 125
What kind of oil do I use in the oil reservoir of my chain saw?
I believe the reservoir you are talking about is for the bar chain oil. You can get it most anywhere. As for mixing the gas and oil mixture, you will need 2 cycle oil. It is available most everywhere also. Most modern chain saws use a 50:1 mixing ratio which means 2 1/2 ounces of oil to 1 gallon of gas. Hope this helps.
Apr 26, 2009 | Remington 16" Electric Chain Saw
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
