Good afternoon i have an error code on my pioneer air handler E C , can you please tell me the meaning ?
4 Suggested Answers
SOURCE: What does this error mean Line: 44
Char: 8862
Error: Handler already exists
Code: 0
Posted on Dec 08, 2009
SOURCE: We have 2. LA125HV w/ 1 condensing 1. air handler
I could not find a "fault code" list for the LA125HV but for thier Multi Split Units LG lists code CH7 (C7) as "Indoor Unit is Set in Different Cool/Heat Operation Mode." So maybe your air-handler tihinks it's in Heat mode will the compressor is in Cool mode, or vice-versa....
Posted on Apr 29, 2010
hvac1960
  • 2133 Answers
SOURCE: Fedders air conditioning error code E2
Indoor coil temp defective. Replace it.
Posted on Jan 01, 2011
What does code Soaoo indicate?
Search Results
    S0A00 Set-Top Box Error Message Help - Comcast
    customer.xfinity.com/help-and-support/cable.../getting-error-code-s0a00...
    Learn what S0A00 on your Comcast cable box means and how to resolve this ... A number of signs can tell you if your computer may be infected with a bot, ...Missing: pioneer
    ref code S0a00 - Comcast Help and Support Forums
    forums.xfinity.com/t5/XfinityTV-and.../ref-code-S0a00/td-p/855021
    Jan 18, 2011 - If you getting S0A00 errors, that means you have signal issues, most ...fios is cheaper than comcast, can you give an example of how fios is ...Missing: pioneer
    Comcast Ref Code S0a00 - How Do I Fix It? - GeekDrop
Jan 23, 2016 | Pioneer Televison & Video
Pioneer Aircon error code is E-C what does this means
please confirm error code - pioneer error codes are letter-number.
E0 = no feedback being received from outdoor EEPROM chip
Nov 10, 2014 | Heating & Cooling
Why does our Lennox AC Air Handler, Model CBX26UH-060 makes a beeping sound when it starts up?
Dear Friend,
Normally all Lennox handler beeps right after turning on and off, but if beeps all the time it might be that there is an error with the handler or it beeps because it was program to beep when going on and off. Please refer to your user manual for any beeping error.
Good Luck!
Sep 20, 2014 | Heating & Cooling
Why is my affinity dryer not heating and showing error code 56
Good Afternoon Friend,
I understand your Frigidaire dryer, model# ATF7000ES, is not heating and showing an error code 56. The E56 code means there is high motor current, meaning it is possible something is going on with the motor. The other possibility is this is a false error code. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Error F8 on a Frigidaire AC model FASE24C6****
Good Afternoon Konrad,
I understand that you are receiving an F8 error code on your Frigidaire air conditioner, model# FASE24C6. I also see that it will work for hours before displaying F8 or sometimes only minutes before displaying the error code. The F8 tells me that there might be a key stuck. I suggest resetting your air conditioner, by unplugging it for 3-5 minutes. Plug your appliance back in and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 08, 2014 | Frigidaire Heating & Cooling
My mini split comfort star has an e1 error code, what does it mean
the E1 code is a communication error.First check for proper voltage at your condenser, then check all wire terminations between condenser and air handler. you should have LED's on your main board as well as your PFC board. if they show normal operation then chances are the main board is bad. be sure to check the ground .it must have a proper earth ground.
Jan 18, 2014 | ComfortStar Heating & Cooling
I have a fs c2126 kyocera printer it gives me c4600 error code
Good afternoon,
Please can someone tell me what is the error C4600 printer kyocera TASKalfa 2551ci?
How can I solve it?
Jul 20, 2011 | Kyocera FS-1118MFP Laser Printer
Good Afternoon to You, I am currently working on
This means error code of E-1 and E-2. Indoor room sensor defective. Replace it. And also rotate motor manually. If hard, replace fan motor bearings. Helpful?
Jan 04, 2011 | Fujitsu 36CS Air Conditioner
What does this error mean Line: 44 Char: 8862 Error: Handler already exists Code: 0
Char: 8862
Code: 0
Dec 07, 2009 | Facebook Social Network
Air handler circuit breaker
WITHOUT ANYTHING TO LOOK AT I WOULD SAY HE CONNECTED HALF THE LOAD TO ONE OF THE PHASE WIRES AND THE OTHER TO THE OTHER PHASE WIRES , PHASE WIRES MEANING 120/240 SINGLE PHASE , SO IF THAT IS THE CASE TAKE THE WIRES HE HAS BUNDLED TO ONE PHASE OR ONE TERMINAL ON THE BREAKER AND THE OTHER TO THE OTHER TERMINAL OF THE BREAKER IN SOME CASES IT IS NECESSARY TO CONNECT THE WIRES WITH CONNECTOR, APPROVED TYPE AND THEN TO THE BREAKER TERMINAL ,THIS JUMPER SHOULD BE RATED THE RATEDING OF THE BREAKER YOU ARE INSTALLING ,GOOD LUCK
Nov 19, 2008 | Gb Electrical 1 30 Amp Ground Fault...
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
