Question about Garden
I have an orbit 56619 and cannot figure out how to eliminate the interval icon on the timer. I just want to set the days. Do I need to deal with intervals too? Thanks!!
  • 579 Answers
SOURCE: TV TURNS OFF AT DIFFERENT INTERVALS
How old is your TV?
TV's have a circuit that monitors the high voltage and shuts down the set if it senses something amiss. If the set is at least 10 years old this is typical and not worth repairing. If less, figure on replacing the flyback transformer.
Hope ya fix it!
Posted on Jan 06, 2008
SOURCE: Casio Gulfman G9100 tide setting. where to find Lunar Tidal Interval?
If you look at the GMT differential in the manual, you'll notice that it corresponds to the offset from GMT that your time zone resides in. I live in San Antonio but i don't see that on the list. I do know that when we're not in Daylight savings time, I'm -6.0 from GMT... so that's what i set it for. Also, if you're near enough to the coast to use this feature, it would probably be a good idea to compare the watch reading to the actual tides and adjust accordingly.
Hope this helps.
Posted on Jun 21, 2008
  • 13 Answers
SOURCE: How doI reset the engine service light?
If you open up the fuses box, you should find a fuse that has a reset button on it. You need to have the car on, but the engine not running. Then press and hold the button down for about 5 secounds. I don't think you can set it for differnt intervals.
Posted on Mar 22, 2009
  • 1071 Answers
SOURCE: What interval mileage or year does the cambelt neeed to be renewe
timing belt shold be replaced every 60k
Posted on Aug 21, 2009
  • 6 Answers
SOURCE: want to reset service interval? i've just finish
Ok,
Then turn on ignition. Press O button (top on the left) for 30 seconds. Release after you hear a beep and press M (lower left)
Scroll through the messages untill you reach the Reset Std message.
If you have used oil according to quality sheet 229.31 or 228/229.51, you can scroll to Reset.31 or Reset.51 respectively.
This selects the oil type used.
Now, when appropriate oil type is selected- press 0 for 6 seconds untill ''2'' is displayed. Press O once again briefly and the ''done'' message will confirm that the job is finished.
This work on 08 model some times you need to do it more than once for it to work
Posted on Feb 01, 2011
How can the orbit mdoel 57894 be progrmed for multiple start times?
The product manual is confusing... how do you set 1-5 am and 2-12 pm and 3-5 pm? The manual says to press program button to choose A B or C programs, but does not give steps for programming or when to press enter to confirm setting... or say which position the dial should be in when programming.
57894 lets you program separately for each station...turn dial to Run Time and use arrow keys to select a station. Press enter or arrow keys to advance to next station.
57894 offers 'select a station', 'pick days of the week or interval between watering for that station', 'duration of watering for that station'. But picking days of the week is not the same as setting exact times 1-5 am and 2-12 pm.
The dial is set to auto for programs to operate..
Don't forget to activate battery located top right on face of timer.
http://waterheatertimer.org/pdf/Orbit-57894.pdf
So the 57894 has more options than a 24-hour analog sprinkler timer that repeats same cycle each day with 14-day-skipper.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Gene
Water Heater Timers Save Money
Mar 12, 2015 | Orbit Hardware & Accessories
What am I doing wrong?
If your Orbit system is 8-10 years old, the timer may be worn out. This is especially likely if the timer is electromechanical rather than digital.
Aug 01, 2014 | Orbit Sprinkler System Power Source...
Mod 57880 am setting ok pm setting wont come on ?
Is this new timer?
Or timer that worked before and stopped working?
Check outlet with circuit analyzer for correct polarity and grounding.
Reset timer and re-program, being careful to avoid conflicts and/or overlaps. Each ON time must also have OFF time with consistent days for each. If selected time is 12:00, then use 11:59 instead to avoid possible problems with am and pm conflict.
product comes with 1 year limited warranty.
Orbit digital 57880 sprinkler timer manual is 19 pages long, which is good argument for using analog timers with 1 page manual.
Troubleshoot appears on page 18 of manual, and includes Tech service number.
http://waterheatertimer.org/pdf/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Oct 04, 2012 | Orbit Hardware & Accessories
Need instruction manual for orbit sprinkler timer model 57196
Copy following link for Orbit Sprinkler timer manuals
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=01&Type=Timers
Copy following link for various brand name sprinkler timer manuals, including Nelson, Melnor etc if you need new timer
Sep 10, 2012 | Hardware & Accessories
Red light
Hi, Anonymous here is how to reset/adjust Engine Service Interval (Wrench icon)
Upon selecting this item, there are two possibilities. If the Wrench icon is active, you will have the opportunity to clear it--proceed directly below. If the Wrench icon is not active, then skip over the next section to "CHANGE ENGINE SERVICE INTERVAL".RESET WRENCH ICON:
1. The display shows CLEAr and no.
2. Press and release SCROLL to alternate between no and yES.
3. Select yES if you wish to reset the wrench icon.
4. Press and hold SCROLL for 4 seconds.
5. WS appears in the display.
6. Release SCROLL.
If you selected no, you will not proceed to the next section; the display will revert to the Service Setup Menu.
CHANGE ENGINE SERVICE INTERVAL:
To get to this point, the Wrench icon must not be active or you just now reset it, as above.
1. The display now shows either CLK or km/h (or Mph).
2. The display now shows the number of hours between Wrench icon reminders. The factory setting is "0044".
3.The 2nd digit of the hours value will be blinking:
In addition, the display also shows the Oil Can icon above the word "OIL", and the "CLK" indicator is present. The presence of "CLK" indicates the interval occurs based on time (this can be altered for the Wrench icon, but not for the Oil Can icon).
For more information about your issue, please visit the websites below. Good luck and have a nice day
DOWNLOAD 2006 Aprilia Rs 125
Jun 17, 2012 | 2006 Aprilia RS 125
How do you set the timer in fifteen min. intervals? Especially when there are 4 pegs?
1) You need a timer that breaks 24-hour day into 15 minute intervals.
Hampton timer and other timers with movable trippers cannot be set for 15 minute intervals.
2) All mechanical plug-in dial-type timers have 1/2 hour intervals or more
a) For example Woods 59366: sold at Lowes as Utilitec 0148297 or Target as Westek TM series
http://waterheatertimer.org/Woods-timers-and-manuals.html#59366
b) Or GE 52012 sold at Home Depot
http://waterheatertimer.org/GE-timers-and-manuals.html#52012
3) If you want 15 minute intervals, you need digital timer.
a) For example GE 15091 sold at Home Depot
http://waterheatertimer.org/GE-timers-and-manuals.html#15091
b) Woods 59377 sold at Lowes as Utilitec 015671 or Target as TE06
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 30, 2011 | Hampton Technologies Brinks Timer
Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
