Question about Grohe Home
I have replaced a grohe Aquadimmer diverter, now water come out of tge shower head and bath spout, can anyone help?
    Top Expert:
  • Grohe Master
  • 41,919 Answers
The diverter was installed incorrectly or is defective.
Posted on May 17, 2017
4 Suggested Answers
  • 44 Answers
SOURCE: Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Posted on Dec 20, 2008
  • 50 Answers
SOURCE: Grohe Atrio Bath Shower Mixer Flow Problem
Check for a flow restrictor in the showerhead, also a clogged intake screen or filter in the showerhead. or hose or pipe...
Posted on Jan 05, 2009
housejess
  • 317 Answers
SOURCE: I have a movatio shower head with a grohe allure
not the shower head ..its the hot and cold handles...
Posted on Nov 17, 2009
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
I recently move into a condo that has a Delta single lever Series 1400 single lever bathtub fixture. The bathtub has a shower nozzle that looks like it has been used. I cannot find where there is a button,...
Is there a button on the tub filler? How about the spout on the tub, does it lift up? If there is not a tub spout then it should be shower only, if it has a tub spout it has to have a lifter of some sort, the foto I found showed the little button lifter. Hope this helps.
May 29, 2010 | Delta & Single Handle Shower Faucet
I turn the shower on; half the water comes out of the bath and shower head?
the Diverter is not working. is it on the tub spout the pull handle type. just replace.
Jun 25, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    Diverter valve does not work correctly.
    the connections are reversed,just change them over and this will fix the problem.
    Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
    Dripping shower head
    If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
    Jan 25, 2009 | Grohe Aquatower 3000 Shower Tower...
    Kindly
    Richie (UK)
    Dec 17, 2008 | Grohe Home
    Nov 25, 2008 | Plumbing
    Home Logo
    66 people viewed this question
    Top Grohe Home Experts
    Mike
    Oloyede Monsuru
    Are you a Grohe Home Expert? Answer questions, earn points and help others
