Question about The Optics
I have a Bosch front loader washer have changed pump checked drain, but still won't drain all the way out I get the code E04
It's model is wrong2100
    Top Expert:
  • The Master
  • 77,939 Answers
What is error code e04 bosch front loader washer
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely
Nov 22, 2016 | Bosch Washing Machines
E04 error code, washer wont drain, water left in tub on a Bosch Nexxt 300 series
Make sure you click helped, if helped that is.
Apr 12, 2013 | Bosch Washing Machines
What does the E04 error code mean?
E04 means that you are not draining quick enough, if you are using HE detergant then your drain line is probably clogged. There is a round access panel on the lower right corner of your washer. If you stick a small screwdriver through the tiny little hole on this panel and twist the panel off you will see the drain pump catch. You can twist this cap off by hand and remove all the debris inside. WATCH OUT a lot of water will be coming through.
Dec 07, 2012 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Got an E04 messege (not the first). Set the washer to drain and it makes a horrible noise. Water won't drain out. Some E04's in the past have been accompanied by a rubber burning smell, but not...
The problem maybe the pressure switch if you have a multimeter check for any electrical issues if there is no reading your pressure switch needs to be replaced
Jun 30, 2011 | Bosch WFMC2100UC Nexxt Essence Washer
We get the error code eo4 on our Bosch front loader, and it does not spin.
Hi, "E04" means the "suds or pump is blocked"
Bosch E04 Solution:
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say! I'd guess you could get wet.
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole to 6'oclock and it should come free.
  5. Once the door out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hands. There is a small collector lip at the bottom of the cap, that is where I held my wet/dry vac to catch the water. Unscrew slowly so you don't get flooded. Take your time and keep unscrewing it until it is free.
  6. Pull out the trap that you just unscrewed and you'll most likely see the item that caused the E04 error code. There is an side of the trap that is marked that it needs to be installed facing downward, so watch for that when you put it back in.
  7. Read these direction upside down and backwards to put it all back together.
  8. Run a load and watch for leaks. You could leave the door off until you are sure you screwed the cap in tight enough.
Jun 23, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
My Bosch washing machine model WFMC2100UC has been giving alarm code E04 and the indicator light "rinse" is lit. The manual suggests that the pump or the drain is blocked, this is not the case,...
This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch nexxt 500. E04 message, checked drain area (round circle at bottom, checked ball valve, checked drain hoses, checked and cleaned container at the top right back of machine-where exterior discharge...
Feb 01, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch wsher reading E04
On the Bosch washer this indicates a problem at the pump. Probably some sort of obstruction. You may need a #15 Torx screwdriver. There should be a small round access door at the bottom front of the washer. If you turn it to the left you should be able to remove it to gain access to the pump cleanout port. Be ready with lots of towels when you remove the cap from the drain pump. There will most likely be a flood. LOL
Clean out anything that is clogging the pump. (like the occasional stray sock) Check the condition of the pump at the same time, but there is most likely something clogging the pump. Hope this helped and best wishes.
Aug 28, 2009 | Bosch Washing Machines
Washer stopped. E04 beeps but won't spin or continue any cycle. Have shut off machine but only makes a strange sound.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I had the same problem. Error code E04 with a full load of laundry and water in the washer. Unplug the power to the washer. Take off the round cover plate in the front right. Mine did not turn clockwise or counter-clockwise, it was completely stuck. Used two flat tip screwdrivers to carefully pry it away, without damaging anything. The plate is a hard plastic but just pliable enough.
Once removed, you will see the pump (img_0001). Unscrew the pump cover slowly. There will be water coming out, so be prepared. In my case we had a LOT of water, so I drained it gradually into a couple of large garbage bags. Wrap the bag opening tightly against the pump surround to minimize spills (img_0002).
Once all the water is gone, remove the pump cover and clean out any items trapped in the pump and in the drain from the drum (img_0003). In my case it was some loose change and a small ColorCatcher sheet. Reassemble the pump and you're done.
Also helpful:
May 16, 2009 | Bosch WFMC2100UC Nexxt Essence Washer
I have a bosch wfmc 2100 washer that doesn't drain
Have a look on the Bosch web site, they offer solutions to some problems, if not contact them via email
Jan 01, 2008 | Bosch WFMC 2100 Front Load Washer
Optics Logo
106 people viewed this question
Top The Optics Experts
David Clark
David Clark
Are you a The Optic Expert? Answer questions, earn points and help others
