Question about Swiss Army Watches
When the battery was replaced in my Swiss Army watch the repair shop didn't replace the little insulator under the battery, causing it to only run for a few hours. Where can I purchase this insulator?
4 Suggested Answers
SOURCE: swiss army watch
Did you have the battery checked to see if it was bad a first? Take it to a Reputable watchrepair , and ask them to CHECK your battery NOT replace it. Alot of times your watch will have a mechanical problem which will make your watch look like it is o.k. once you replace the battery but, two weeks later the watch stops again because the battery has lost enough power to now stop the watch again. Also your watch may have a electrical problem which a battery will not solve the problem. The coil (the orange straight piece in the movement), or the curcit board could be bad. Always have the store check your battery because, if you ask them to change your battety they will no matter if your original battery is good or not.
Posted on Sep 09, 2008
escapement
  • 2334 Answers
SOURCE: Watch going in reverse
There is no difference in watch batteries as they are produced by the certain standards. That means you have replaced the right battery.
The simplest solution would be re-replacing the battery. Just take the battery out and leave the watch without battery for 5 minutes, then put the battery back. Make sure the battery is fitted the right way (the + side usually facing up).
If this doesn;t help - let me know.
Rate, please.
Posted on Mar 23, 2009
  • 299 Answers
SOURCE: How to remove the back cover of the swiss army
The back will either have a small slot on one edge to pry it off or indentations around the perimeter for a case wrench to unscrew it. Specialized tools are used to avoid scratching the case. You best bet is to take it to a watch shop and let them do it. Most places charge between $3 - $8 to properly do it without damaging the case and they should also change the gasket to maintain water resistance if so equipped. Once you have it open you risk damaging the movement as you change the battery. It's not that it's a tricky procedure but you can easily damage something that will cost a LOT more than $8 to fix if you don't have experience.
Posted on Apr 10, 2010
Swiss army watch 241083, what battery does it take
Any Brand, Type 371 1.55v. I replaced the same Swiss Army Victorinox Infantry Watch model 241083 specifically with the Energizer 371BPZ Zero Mercury Battery. BTW, the replaced original was also a 371.
Jun 30, 2013 | Swiss Army Watches
Im trying yo change the battery how do i open i know thers two ways one is unscrewing the back of the watch the other is like you open a can of paint i try both and none work what should i do or try now?
the Swiss Army watches I have dealt with have all required a Rolex back wrench, it costs in excess of $100.00, they most charge $7.50 to replace the battery and that includes the battery.
Feb 13, 2011 | Swiss Army Wenger Wenger watch
How do you open back to change battery?
Swiss Army watches require a special tool. You will need to call your local jewelers and ask if they do Swiss Army watches as not every jeweler has the tool to do it.
Good luck
Jul 19, 2010 | Swiss Army Wenger Standard Issue 70609...
The second hand jumps forward every 5 seconds but the watch still keeps time OK.
You need to replace battery.
Q/A from swiss army website.
Q. How do I know when the battery needs changing?
A. In select models, the battery end-of-life indicator signals that the battery should be replaced within two or three days. When the battery is low, the second hand stands still for 2-4 seconds, and then speeds up to the correct time. This indication will last for approximately one week, and then the timepiece hands stand still.
Jul 02, 2010 | Swiss Army Wenger Victorinox Swiss Army...
Scratched crystal
mcdevito75 here, If the crystal is Glass a replacement crystal may be your only choice, If Plastic It may be saved. Check with the watch repair service directory, right here on fixya. Bottom of this page, click on repair service directory then watches.
Jun 30, 2010 | Swiss Army Wenger Swiss Army Officer's LS...
How to take links out of the band of a wenger swiss army watch
Save yourself the time and frustration and take it to a reputable watch repair shop and let them adjust your band for you. Could be screws or could be pins! Plus if anything small drops you might not find it again!
Jan 19, 2010 | Swiss Army Wenger Sportedge Bracelet Watch
Connect metal strap to watch
If it brok at the hinge where the strap connects to the watch itself, then you might just need to replace the clip that slides in. Its a little metal tube with a spring in it. You should be able to find them at any retail shop. If all else fails, take it to a shop or jeweler.
Mar 11, 2009 | Swiss Army Wenger Sportedge Bracelet Watch
Wenger watch
swiss army watch had battery replaced after stopping, will not restart, replacement battery new and good.
Apr 22, 2008 | Swiss Army Wenger Alpenrose 70450 Wrist...
Swiss Army watch 70609 second hand pauses
Battery life indicater just warning to get that battery replaced so it wont stop at an inconveinient time
Jan 09, 2007 | Swiss Army Wenger Standard Issue 70609...
Second Hand
it is the battery life indicater get the battery replaced it will fix the problem
Oct 26, 2006 | Swiss Army Wenger Avalanche 70186 Wrist...
Watches Logo
Top Swiss Army Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Swiss Army Watch Expert? Answer questions, earn points and help others
