Question about Sewing Machines
Whats the threaded part thatthe hose screws onto called .. threads gone.. aquatak 120i
  • 1011 Answers
SOURCE: Thread gets caught in the screw behind the thread take-up lever
dear,
it might be possible that screw pulled away due to the vibration as it became loose and after working the machinary it did like this.
so try after tighting it properly.
regards,
dont rate it until it satisfies u
Posted on Sep 25, 2008
SOURCE: Thread looping onto itself
when i try to pick up the bobbin thread it does not pick it up at all i even try threading it all back over many times can yuo help me please
Posted on Oct 06, 2008
SOURCE: Elna SU missing stiches and breaking thread
it sounds like the needle hook timing is out. You need to get the needle in the lowest position and measure the gap from the needle to the hook point on the bobbin shuttle. It should be 1/4". You will need to remove the foot and foot plate to be able to see. I use a 1/4" drill bit as a gauge. If you need to adjust it, you will need to remove the free arm cover to the right of the foot and loosen the 2 allen head screws that hold the drive gear. Adjust the gap, tighten the screws and retry. Usually if the needle catches the thread to early, it will make a bad stitch and the upper thread will break. If it catches to late, it will make thread loops and the machine will skip stitches. Good luck, these are a good machine and worth fixing. Phil
Posted on Nov 13, 2008
  • 97 Answers
SOURCE: thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
Posted on Mar 11, 2009
miket756
  • 2702 Answers
SOURCE: NECCHI, model 4795. Thread bunches up at bobbin.
it sounds like the thred tenshion is to loos or the timing has sliped a little and its off a bit this can also happen with wear on the gears or just a loos fixing letting the timing slip back a bit,
Posted on Nov 20, 2009
Bobbin not not threading, what's the problem?
We don't know the make & model of your machine. Are you trying to wind the thread onto the bobbin?
FWIW, for ~$30 there is a stand-alone bobbin winder called "Sidewinder" that can be used to wind all your bobbins. It saves wear-n-tear on your machine and you can wind bobbins without removing the thread from your sewing machine. Just be sure to verify that your bobbins are compatible with the Sidewinder.
Available at JoAnn's, Walmart, Amazon...
Amazon com Simplicity SideWinder Portable Bobbin Winder
Jul 19, 2017 | Sewing Machines
Tip
Winding a bobbin correctly
The heart of sewing is producing a well tensioned seam and achieving this with any sewing machine will be difficult if you don't wind a bobbin smoothly and with even tension onto the thread. If you look at your bobbin and the thread on it looks all lumpy and uneven, then this tip is for you.
Each time you wind a bobbin, whatever sewing machine it is on, it is really important to keep even tension on the thread as it winds onto the bobbin. Many machines will have a little tension disc you take the thread around but your technique is important too.
Usually you take the thread from your spool of cotton on the right, across to the left on the top of the machine and around a tension disc, or through a thread eye, then back to the right to your bobbin winding spindle, if your bobbin has holes in it, then pull the thread tail up through a hole and pop it onto the spindle. Engage the spindle by pushing across against the stop. Now start winding SLOWLY while holding the thread tail up in the air until the core of the bobbin has been covered in fully and your thread has covered up the starting point to hold the beginning tail. Stop winding, and trim the tail off against the bobbin with a pair of snips. Now resume winding at 1/2 to 3/4 speed and do two things, one with each hand. With one hand put tension onto the top of the spool you are winding thread off - use the curve of your scissors handle into the indent on top. And with your other hand, give the thread a nudge as it winds onto the bobbin to ensure you wind fully across the whole bobbin evenly. Watch it carefully to ensure that you get a smooth even wind.
An analagy: if you wind the garden hose onto the hose reel really fast and let it go anywhich way, the hose will kink and wind mostly in the middle then the reel's full and you've still got half the hose to put away. Thread is the same, its been wound onto a spool by a machine in a very precise way; you want the same smooth evenly tensioned winding onto your bobbin so that when you stitch out the seam the thread is consistently fed off the bobbin.
Don't be tempted to wind flat out and just let it take its own path as you won't get good smooth bobbins of thread. And if you let the thread come off the spool at a fast pace the spool may bounce around, causing fluctuations in the tension on the thread. When you stich a seam, the thread will relax unevenly in your seam causing puckers and ho hum stitching.
Simple stuff but it makes a difference!
on Oct 02, 2011 | Sewing Machines
Tangled thread on wrong side of fabric, I did the remedy as per manual but problem still exist
Unthread the machine fully. Remove the bobbin. Is the bobbin thread the same as the top thread? Is it a Quality thread (yes, cheapie thread can give big issues!!) Do you have several different threads wound onto the bobbin?? Is the bobbin thread wound on quite tight? If you push your finger nail into the thread wound onto the bobbin, it must not feel soft or spongy. Check if there is any roughness / burr on the any part of the shuttle hook. If so, remove it with 800 grade wet and dry abrasive or similar. Put in a NEW needle as per user manual specs (not a 'new' one you used before 'just for a little bit'.!) REPEAT - put in a NEW needle - amuse me!!. Place the bobbin into the bobbin holder (the CORRECT direction - yes there is a Right and a Wrong direction!), thread it ready to put back into the machine. BEFORE you do, hold onto the thread tail and let the bobbin and bobbin case dangle. Thread should slip thru when you give a gentle pull upwards. If no slip, loosen the tension on the tension finger a LITTLE. If it slides down easy, tighten it a little. Fit the bobbin into the machine. Lift the presser foot (this releases the top thread tension discs) Check there are no bits of thread or fluff between the tension discs Rethread the top thread - check the thread path is 100% correct. Hold onto the end of the needle thread and draw up the bobbin thread. Hold both threads, start to sew - check the result. Tip : If you use a different color bobbin thread (same brand etc etc) it will help you to see more easily what is going on. You should be seeing some of the bobbin thread color on the top side of the sewing. If not, INCREASE top tension a little - retry.If there is a lot showing, decrease top tension. Good luck
Dec 14, 2012 | Sewing Machines
Thread is getting tangled in the bobbin chamber of my brother xl3125 when I sew. When I pull the fabric out, several strands come out of the bottom and the bottom side of the sewing is tangled and loose. ...
try these suggestions
change the needle
rethread the machine top 7 bobbin ---make sure the presser foot is in the up position before rethreading--use every thread guide
clean under the needle plate & in the bobbin area for lint
make sure the thread has not come off the thread take up lever
make sure the bobbin is turned the right way in the bobbin case & that
the bobbin is not over full
Sep 27, 2012 | Brother Sewing Machines
Not picking up bobbin thread
try rethreading the machine top & bobbin
put in a new needle
make sure the bobbin is not over wound
make sure the bobbin case is inserted correctly in to the machine
if the machine still doesn't pick up the bobbin thread it's possible that
the machine is out of time
Aug 28, 2012 | Elna 2005 Mechanical Sewing Machine
Bobbin will not wind straight
the thread guide & the bobbin spindle need to be check to see if there
is something wrong or just needs to be adjusted
Jun 03, 2012 | Singer 7422
Bobbin placement we cant get in correctly and it wont pick the bobbin thread up. when trying ti sw it bunches in knots and breaks sometimes
Sounds like the bobbin may not be the right one for your machine. YOu haven't said what make and model this is but you should check your manual or online to ensure you have the correct bobbin for it. I've seen Elna's with Singer bobbins in, they'll stitch okay but then tension problems occur, you need to have the right one for your machine. (if you aren't sure, try looking at www.sewusa.com or www.sewingpartsonline.com to find the bobbin described for your machine.)
Also metal bobbins can get squished if they've been stood on, so have a good look at it and make sure the bobbin is in good shape and looks okay.
Now take the thread off it and rewind a fresh bobbin making sure you've got tension on the thread the whole time and that the thread winds onto the bobbin very smoothly and evenly. This is something that is not emphasied in sewing machine manuals but makes a HUGE difference. Think of your garden hose coiled onto the hose reel. If you wind as the hose wants to go, it goes onto the reel all over the place, then jams up and you can't get it all on there. Look at how a thread spool is wound, the factories wind the thread in a very neat sequence and you want your bobbin to look the same. So always use the tensioner on top of the machine to take the thead around when winding the bobbin. If you don't have one, then put tension onto the thread spool the thread is coming off to ensure the thread runs off at a constant tension and speed.
Carefully watch the thread as it goes onto the bobbin and nudge it with your fingertip to get it to fill evenly top, bottom and middle of the bobbin. Stop when 3/4 full.
Now put bobbin to bobbin holder ensuring that it goes in the right way, always the thread should come off the bobbin and reverse direction in a V shape. Click the thread into the tension spring. Double check it is in there and then thread up the rest of the machine and test sew.
THere is some good trouble shooting tips at www.sewusa.com so this might help you also.
Sep 14, 2011 | Sewing Machines
Bobbin is clumping up
You haven't given a lot of details so I'll just assume this is a bobbin issue initially.
Take out the bobbin and rewind a fresh bobbin of thread paying attention to the following.
You want to keep a bit of tension on the thread spool as the thread winds off it - good way is by placing the round handle of a pair of sewing scissors onto the top of the spool. If you let it just bounce around it will affect the bobbin winding neatly and the thread won't then run off the bobbin smoothly as you sew.
Also visually watch the bobbin as it fills, and give the thread a nudge with your finger tip to ensure it fills top and bottom, not just in the middle.
Think of how you wind up the garden hose reel, if you let it all go in the middle, it jams up before the whole hose is wound onto the reel. But if you wind it carefully and move the hose around winding it evenly across the whole reel, it stays neat and doesn't all jam up. Same principle for bobbins; don't just run the thread through the little tension disc and press the pedal hard until it stops.
Also quality of the thread is important; cotton wrapped polyester is nice to sew with and has a bit of spring, strength and good sheen; not sure where you are. But the brands I look for are Sylko Supreme, Guttermann and Mettler threads; there are other good brands too. Don't use those cheap bags of 5 white or black thread in the bargain bin. Some threads you can actually see particles of dye coming off the thread around the spool holder as you sew. Darker colours do this more.
And keep your threads stored neatly in air tight containers away from light, insects or damp; textiles fade and break down under UV rays eventually.
Now rethread your machine and ensure that the bobbin has gone into the bobbin holder winding in the correct direction for your machine, and that the thread has clicked into the tension spring.
Hope this helps, a good source of general sewing machine info is www.sewing.about.com.
Mar 06, 2011 | Brother SE-270D Computerized Sewing...
How to thread the bobin on a elna air electronic su. where do i put the loose end when threading the bobin
I assume you mean when you wind a bobbin full of thread??
You take the end of thread from your spool through the tension device or an eyelet on top of the machine, then back to the bobbin on the bobbin winder and thread the loose end through a top hole on the bobbin. Click the bobbin in against the stop and press on the pressure foot to start to wind. Hold the top thread for a bit as the bobbin starts to fill and then once it has been covered by a row or two of thread, stop and cut of the loose end from top of the bobbin. Now continue to wind the bobbin until it cuts out as it fills against the stopper. Nudge the thread with a finger tip as it spools onto the bobbin to help get the bobbin filled top and bottom and not just in the middle. (bit like when you coil the garden hose onto the reel, it always wants to go in the middile only and then jams up LOL).
Also a really good idea to place your scissors handle into the top of the thread spool to slow/control it as the thread reels off it. This helps give an even tension on the thread going onto the bobbin which really helps with stitch quality later.
Jan 18, 2010 | Elna 8007
THREAD BUNCHING UP
there should be a small flat screw on the bobbin case that needs to be adjusted - turn to the left very slightly to weaken or lessen the tension and turn to the right very slightly to strengthen or tighten the tension. there may be two little screws in the same place - on my bobbin case, the screw to turn is the bigger one and is closer to the thread opening. hope this helps!
Apr 13, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
