Question about Garden
My 2005 L120 won't engage the deck. After a few minutes the twenty amp fuse blows. i have repaired the wire going in the connector to the clutch. . is there a short somewhere?
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
ToolBoxHero
  • 171 Answers
SOURCE: Everytime I engage the clutch
Yes, this usually means the elelctric blade clutch is bad and will have to be replaced. Sorry, this is an expensive part.
Posted on Jan 13, 2011
  • 5370 Answers
SOURCE: L120 deck clutch blows 25
It can be faulty magnetic clutch or shorting pto switch or the blades are getting stuck or not moving right.It has be checked and inspected.Click this link below and follow the troubleshooting:---http://technoanswers.blogspot.com/2011/07/john-deere-l120-lawn-mower-blows-25-amp.html ---------- This will help.Thanks.Helpmech.
Posted on Jul 14, 2011
  • 6468 Answers
SOURCE: John Deere L120 blows fuse when starting. Starter spins very briefly, then 25 amp fuse blows
one of the safety switches could be shorted out internally
Posted on Apr 10, 2012
yakuzza2
  • 68 Answers
SOURCE: craftsman mower deck engaging intermitantly
I believe I would start by looking at the grounding for the solenoid(clutch) sounds like that it may be intermittent. Or the spring assembly that physically engages the assembly on the deck my be dirty or need a lubricant and a cleaning or both. Good Luck
Posted on Jun 05, 2012
Even with the mower not running when i pull the switch to engage deck it blows 20 amp fuse
Kelly, ray g. nailed it, First be sure it is only to be a 20 amp fuse, The wires to the clutch that drive the deck will be broke or bare shorting out on each other or on metal, wire are quite commonly broke by the clutch plug or close by. what you can do is carefully follow the wire from switch through the system and look for damage or bare spots, pay special attention when wire runs through frame/body holes and any where it could rub on metal or moving parts. Check the attached links,instruction and guides,4th link see Randy T. reply in forum, has good test method for your problem. Good Luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Craftsman 917 273631 Fuses keeping blowing when blades are engaged
CC1042 with Kohler Keeps Blowing Fuse when PTO Engaged
Blowing Fuses
265 blowing main fuse when engaging PTO
Apr 25, 2016 | Garden
Ac not working, air compressor clutch not engaging
Hi Adeyeri
Keep in mind that the Clutch won't engage for a few safety reasons.
Temperature inside vehicle
Temperature of compressor or pipes
Pressure inside pipes
Compressor jambed
Eg It's out of refrigerant Gas
You can momentarily engage the clutch by simply giving it +12v to the wire attached to clutch. Usually has a connector close by.
Or
If it has a Relay (click) in fuse box
You can by pass it with a jumper
A quick engage & disengage should allow you to detect possible problem.
But don't over ride the built in safety for more than about a minute.
Cheers
Hope this Helps
Vehicle Air Con testing YouTube
FIXED Car Compressor Clutch Won Engage
12 Volt Car Relays Used In Automotive Industry
Feb 23, 2016 | 2002 Infiniti QX4
F525. Updated mower switch by John Deere is not engaging mower
The John Deere F525, a front cutting machine, has 3 fuses.
20 Amp
15 Amp
10 Amp
Check the 15 amp fuse. I believe this supports the PTO clutch. If you replace the fuse and it blows again, check the electric clutch. You will likely find burnt or melted wires. The bearings do go out on these clutches causing them to run hot and eventually burn up.
PTO Clutch will not engage: There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
Resistance 3.7 ohms
Current Draw 3.25 amps
It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
Cap Screw torque 55 lb-ft (75 N.m).
If the fuse blows, I recommend you check the resistance of the clutch. If the clutch is shorting to ground it will show zero resistance when you ohms the connector wire to a ground position. In which case, you will have to replace the clutch.
Fixing Electric Clutches
Other possibilities.
On the F525 there is a cut-off switch in the hydraulic system. It is a low pressure cut off. If you were running the mower and deck and then it suddenly stopped, it may be low pressure in the hydraulics. It will not automatically reset as you are using the same volume for the drive pumps. Once the oil gets low enough it cuts out the deck drive 1st, then the drive pumps.
Apr 16, 2015 | John Deere Garden
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Craftsman mower deck engaging intermitantly
Jun 04, 2012 | Garden
I have a cub cadet lt1554, when engage the pto the engine cuts off, fuse blows
near the engine where the wire goes to the clutch there is a plug unplug that connector and try the switch again if the fuse blows the problem is in the wiring if not the short is after the connector i have seen the wire going into the clutch rub on the clutch housing and i have been able to repair it
Jun 02, 2012 | Cub Cadet Garden
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
2005 L120 mower blades not engaging, I would like a link to wiring diagram to track problem, I do not have a manual available to me.
Check wire connection coming up behind right rear side of engine to see if you have voltage to the PTO clutch.The wires feeding clutch go through frame at rear side of engine,make connection and go into harness.I would also check your RIO switch to see if its working.Fuses?
Nov 11, 2009 | Garden
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
