Question about Garden
Cannot pull cord enough to crank the engine - Garden
  • 1,830 Answers
Find someone that is strong enough to do it. A neighbor or friend.
Posted on May 17, 2017
I have a kolher 149cc engine on a Husqvara lawn mower, it seems to be out of time because is rips the pull cord out of my hand.
take the top of the engine off and remove the flywheel bolt blow out any dirt and look to see if the flywheel key is sheared. if it is replace it and put back together. you may want to check the blade also because for it to shear a key it had to have hit something probably causing the blade to be damaged.
Oct 06, 2017 | Garden
My string broke on my crank what parts do i have to replace
It's a fairly generic procedure. Here is a YouTube video. If this one is not close enough to what you have, you can search YT for others.
Small Engine Repair Replacing the Starter Pull Cord on Briggs Stratton...
Sep 19, 2017 | Garden
The pull cord on my Husqvarna trimmer just spins
in the system there is a small lever that is pushed out to engage the crank pulley internally so that it spins the crank
this small lever breaks off and needs replacing
they are available from husqvana spares , and mower shops a sit is a generic piece common with all pull start trimmer engines engines
full the start assembly of the trimmer engine and take it in as a sample
Apr 27, 2016 | Husqvarna Garden
I replaced a broken starter cord and when I reassemble the starter won't turn. Any ideas?
Remove for the n-th time the pull start assembly. Confirm the engine will in fact rotate by hand. Turn the flywheel a full turn or more ensuring that the engine is free. You should expect to feel some resistance from the compression cycle.
Holding the hand crank assembly attempt to pull the pull-cord and observe that the hub rotates. When released the spring returns the cord and handle into the wound position.
If the cord will not pull or operate as expected then remove and reassemble the cord into the pulley making sure that the knot retaining the cord is small enough and does not interfere with the operation. U-tube has several videos showing how to assemble the cord to the hub.
Nov 21, 2015 | Garden
My pull cord rips out of my hand
The string assembly should reach a point far enough out when you pull the cord that it lets it spin free of the engine. What you are probably experiencing is the engine kick-back, where the engine is compressing the air/gas in the cylinder, and the pressure pushes the engine back. The crankshaft is connected to the pull cord assembly, so it's pulling out of your hand. You may not be pulling hard enough, or the cord assembly needs replacing.
Aug 01, 2012 | 5.5 HP GX160 Engine
Briggs and stratton lawn mower 4 stroke engine
did you hit something while mowing the key way between the flywheel and crank shaft might have sheared it will act like the blade is missing pull back on you while pulling the rope
May 25, 2012 | Briggs & Stratton Briggs Stratton...
The pull cord will not pull to start the trimmer
i had a problem like this on an old mower, the cord had become tangled inside the unit, it limited the pull of the cable so it would now spin the engine enough to start. it is not too difficult to to pop the top off the unit and check for tangles or knots
Apr 05, 2012 | Garden
My 7021PHusqvarna LAWN MOWER WILL NOT START FOR ME WHEN i SHUT IT OFF TO EMPTY THE BAG i HAVE TO WAIT FOR IT TO COOL OFF THE CORD SNAPS BACK ON MY HAND WHEN i TRY TO RE START IT THE DEALER TOLD ME MY AMS...
It is because the engine is hot so the fuel pulled into the engine is more volitile, you do need a reasonable cranking speed to start the engine. if the deco valve in the engine is not working properly it will increase the compression and make cranking the engine much more difficult.
Mar 29, 2012 | Garden
Cannot turn engine over to start. Ariens 924 snow blower
pull spark plugs and see if it will pull over if not fuel may have filled the crank case drain & refill to proper level (starter is stuck in lube shaft & movethe gear up & down by hand to free up)
Feb 13, 2010 | Sport & Outdoor - Others
How do you put a new pull cord on?
With great difficulty on that machine!!!
Its a "Half Cranked" engine (which is cheap and nasty) meaing the recoil / pull cord is located between the shaft of the brushcutter and the engine (NOT on top of the engine like proper "Full Cranked" engines are).
You will have to remove the engine to do this and probably loose the will to live in the process! Bin it and buy a Stihl bent shaft trimmer instead
Oct 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
