Question about Garden
Cannot pull cord to start the machine - Garden
My B&S cord will not pull out. It is not stuck. Help
If the recoil starter was pulling free after you took it off, Are you sure the engine isn't seized?
May 11, 2017 | Garden
Sym red devil feels sluggish
Instructions
    • 1 Locate the red button on the top of the handlebars. This is called the "kill switch." When you pull it up the engine can run; when you push it down, the engine will shut off immediately.
    • 2 Pull the kill switch up.
    • 3 Turn the key to the "on" position.
    • 4 Make certain the cord running from the key is attached to the steering column. This device acts in the same manner as the kill switch - the engine will run only when it is secured.
    • 5 Pull the start cord, which looks like an enlarged lawnmower pull-cord and is generally found on the right side of the machine.
    • 6 Listen to the engine - if it starts, let it get going slowly . If it "pops" but does not continue to run, try pulling the start cord a few more times. If you do not hear the engine turn over at all, proceed to the next step.
    • 7 Find the pull tab under the right side of the handlebars. This is called the choke - it often has a circle with a diagonal line through it. The choke helps to start an engine when the weather is very cold or the machine hasn't been used in a while. When using the choke, try leaving it on only long enough to hear the engine fire a couple times, then return it to the "off" position. A choke left on too long can flood the engine.
    • 8 Place the choke in the vertical position - this is called the half choke position. Pull the start cord several times. If the engine fires up, place the choke back down to its original position and let it slowly warm up. If the engine still has trouble starting, proceed to the next step.
    • 9 Pull the choke 180 degrees from its original position - this is called the full choke. Pull the start cord until the engine sputters a couple times.
    • 10 Replace the choke to the original off position and continue to pull the cord. The engine should fire up and settle into a steady hum, ready for fun in the snow.
Jan 15, 2013 | Motorcycles
Pull on cord for weed eater y 28 yard machine hard to pull how do i repair it
Hmmmmm. The question is why does it pull hard to begin with? Did the pull cord get wrapped around the pulley in an awkward manner or is the machine seized up? If it's not to difficult, pull the muffler off the machine and look at the piston. If it looks scored (lines up and down the piston through the rings) It's shot and probably not worth fixing. But, If everything looks good, then I'd pull the starter assembly off and see if there's something going on there that's doesn't look right.
Sep 23, 2012 | Garden
The pull cord will not pull to start the trimmer
i had a problem like this on an old mower, the cord had become tangled inside the unit, it limited the pull of the cable so it would now spin the engine enough to start. it is not too difficult to to pop the top off the unit and check for tangles or knots
Apr 05, 2012 | Garden
I have a yard machines 31cc y28 17'' how do I fix the pull string it is pulled out fully
Take the top cover off, You should then see 4 bolts around the engine cover, take these out and the cord head will come of,Depending on where the cord broke is the question of using the same cord, But if you're getting a new cord you will need to thread the cord into the eye for the cord, Tie a knot to prevent it pulling apart. then tie your handle on. After this you will wind the cord up tight on the pulley and a screw driver holding the pulley from moving while you put the cord and cap back on the engine, You can then start back installing the bolts and the other cover..
Aug 28, 2010 | Yard Machines 21A240M000 Garden Tiller
I have a 2004 polaris sportsman atv. I went out to start it and with not being turned over for a couple of month the battery would not fire the rig up. so when I pulled on the start cord it just recoiled...
powered up the battery, still wouldn't kick over the machine. then tried for the heck of it to pull the start cord and it wasn't pulling the engine crank just recoiled for three pulls then suddenlly it caught and started the machine on the first pull. percervierence prevails!!! Now my life is whole again.
Jan 29, 2010 | Polaris ATV
Yard Machine won't start
Maybe the Spring is broken in the housing, that is assuming you are talking about a problem with the pull cord. Your question is kinda vaque. Submit more information !
Sep 13, 2009 | Mtd 22" Yard Machine Push Mower
Just bought a john deere 3300 power washer. It started with no problem. shut it off to answer the phone. When I went to start it the pull cord wouln't pull tryed everything but still the pull cord was in a...
first turn off the water to the machine.
pull the trigger to release any trapped pressure in the high pressure hose, then try to start the machine. if it starts then turn on the water to the machine.
it may be that the engine is trying to start up under load....
if this doesnt work let me know.
Jul 17, 2009 | Garden
Plugged in recently purchased, refurbished, ibm infoprint 1567n printer, within the first minute the cord started smoking, employee yanked cord from machine, cord was breaking down and melting. There was a...
The source of your refurbished printer either did not refurbish it completely or failed to test operation before turning it over to you. From your description, it may have been delivered wired for the wrong input voltage.
Mar 24, 2017 | IBM Infoprint 1567n Laser Printer
Will not start
sounds like water in the carb bowl - loosen nut on bottom of carb to drain and retighten then try to restart
Oct 27, 2008 | Yard Machines 24a 021h700 4.5 Horsepower...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
