Question about Garden
Pull start won't release - Garden
  • 1,830 Answers
Lawn mower?
Posted on May 17, 2017
Pull start won't pull
make sure the safety handle cable is releasing then check the oil if there is no oil you might have burned out the engine
Aug 13, 2012 | Toro Garden
Pull start rope is hung up and won't release on my ryobi s430
a broken spring a tangled rope a stuck ingaugement tab
Aug 10, 2012 | Ryobi Garden
How can I move my exmark zero turn lawn mower when it won't start?
on the rear of the machine there is a release lever for each side pull that back and down to lock it in place
Jul 12, 2012 | Garden
Ignition switch won't release key when it is put in park. But when I removed switch and key tumbler, the key tumbler/cylinder releases key. Why won't the key release when it is in park?
Most newer models have a safety feature called
shift interlock. This prevents the key from being turned back
to the lock position if you forget to place the gear selector in park.
Depending on the model,
If it uses a cable, it may be sticking or needs adjusting.
If it uses an electrical solenoid. may be blown fuse or park switch.
Tap, shake, and pull up on the shifter and make sure it's in park.
May 25, 2012 | 1993 Jeep Grand Cherokee
Pull started cord won't recoil after attaching a new one
your spring may be broke or might just have to rewind it they could be a pain somtimes
Apr 07, 2012 | Ryobi Factory Reconditioned 18" 40cc...
I have a Troy-Bilt Briggs and Stratton 675 series lawn mower. The pull cord is stuck and will not move. I can lightly pull the cord repeatedly and the cord slowly allows me to pull more but if I release it...
Take the plug out and try to move the blade. If the motor won't rotate, the problem might be with the motor and the cord can't move because of it.
Gary
May 19, 2011 | Garden
18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Feb 18, 2010 | Poulan Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
