Question about Ford Electrical Supplies
I have an Onan 30 genset generator model # 30.0 ek15 R w/ a Ford motor model # CSG 64916 005 and I need 2 know specs on what type of oil and how much and part numbers for oil&air filter
    Top Expert:
  • Ford Master
  • 77,514 Answers
Please contact ONAN on this, but as far as part numbers go as long as you know the weight of the oil spec any good name brand will do. I would use synthetic.
Posted on May 17, 2017
CarlGehrke
  • 169 Answers
SOURCE: need oil type for generator & motor for 5000 power mate
Unless you're in very cold locations use SAE 5W30 regular motor oil.
Posted on Dec 03, 2008
erickg
  • 116 Answers
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Posted on Apr 17, 2009
SOURCE: Have an Onan RV generator. WHat kind of oil do I
Standard 30W motor oil.
Posted on Apr 30, 2009
  • 127 Answers
SOURCE: I have a onan genset generator model #3.0AJ
The wiring diagram for the generator is pretty simple. You have three wires coming out, White/Green/Black. The black is the Hot, White is neutral, and green is ground. If the generator is running and you do not have power at the black wire, the problem is in the generator. Check the circuit breaker on the generator for OK. Make sure that power is passing through it.
Posted on Jul 05, 2009
  • 6 Answers
SOURCE: Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Posted on Sep 28, 2009
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
8kw onan genset wont keep running whrn it tries to take on the load, will run forever if i kick the breaker switch to off.
What is the Spec number?
Also can you read a fault code on the start switch?
Do you know how to read the codes and post? if not let me know
Nov 17, 2012 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
I need a manual for onan 6500 lp genset
You can buy a service and or operator manual from advanced-power-technologies.com
Aug 13, 2012 | Onan Cummins RV QG 6500 Generator, 6500W,...
Manuals for Onan 6.5NH-3CR/16004P RV generator
onan mcgraw RV model NH-3CR/1600HP, need to know how much oil,what weight of oil how much etc, the type of spark plug , oil filter, all the specs
Aug 04, 2010 | Garden
I have a Onan 7000 genset in my rv It starts and
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
Mar 07, 2010 | Watts Onan Portable Generator - 5000 ,...
Dear Please my Onan Generator Model # DFEC-3381761 I need wiring drawing to ATS connecting to Generator Thanks & Regards Farooqui General Electric Co. KSA
Here's a potential source that may help you...
http://www.genset.com/onan.htm
I searched Cummins-Onan and the model # you ask about does not exist on their website.
Jan 24, 2010 | Computers & Internet
6.5 RV Onan generaotr wont kick in when loaded. checked automatic transfer switch and excited it manually, worked one time but never again,
1. Does the generator stay running when you start it the first time?
2. What color is the housing on this generator? Try to get the model number and serial number.
If the genset is shutting down on the first try, then your probably not creating voltage. However, if this is an older unit then the genset may stay running although no voltage is created. Place a volt meter on the genset to check for output voltage.
Mar 08, 2009 | Watts Onan Portable Generator - 5000 ,...
Electrical Supplies Logo
Top Ford Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Ford Electrical Supply Expert? Answer questions, earn points and help others
