Question about Music
Hi, i bought a IBANEZ sz520 2nd hand. which knob adjusts what? i know 1=tone and 2=volume but not sure which is which...
PolyrhythmFX
  • 109 Answers
SOURCE: trying to rewire the pickups and the pots on my
It's wired like this: http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=HSH_1v_1t_5w
Posted on Oct 09, 2009
  • 5603 Answers
Try the Ibanez site:
http://www.ibanez.com/support/wiringdiagrams.aspx
Posted on Oct 10, 2009
  • 94 Answers
SOURCE: Dean Bass , single pick
GO TO KIJJI
Posted on Oct 25, 2010
  • 17 Answers
SOURCE: Whenever I slightly adjust the "Channel Volume"
You've got a loose wire! What's happening is that there's a bad potentiometer (the electrical component behind the knob) that's out of place and is only connecting fully at one point in the knobs circuit (the part where you get full volume) take it in to an amp tech at your local music store and they'll fix it up easily.
Posted on Mar 05, 2011
  • 2418 Answers
SOURCE: Shadow Kill Pot Wiring Diagram with 2 active
Are you using the original solderless wiring? Are you starting from scratch? Are just wanting to install the Shadow pot into an already working guitar? If you are working on an already working guitar Please give the model number, if EMG equipped, So I know where and what we have to work with. But this should be a straight up fairly easy setup. The Shadow pot just replaces the normal volume pot. Off to work, but will be back with you.
Posted on Sep 09, 2011
I am trying to wire a Delano 4 conductor pickup with a simple volume and tone control harness wiring into my Ibanez Bass guitar. I am new at this and just getting a buzz when testing.
If you are getting a buzzing sound, the ground connection is wrong. If you google how to wire an electric guitar there is a lot of info on it.
Oct 23, 2016 | Ibanez Music
Which is the master volume to boss me 25 ?
Hi, I can help you with your question. On the face of the effects, towards the right side, there are three settings that can be adjusted: DRIVE, TONE and VOLUME. The VOLUME knob is your master volume. The expression pedal can adjust volume, but it's output volume is controlled by the master VOLUME knob we just identified. I hope this has helped you, and if it has, could you please click on the "helpful" button ? Thank you!
Feb 03, 2016 | Roland Boss ME-25 Guitar Multiple Effects...
I need a wiring diagram for an Ibanez GSRM20 Mikro Bass.
normally the third knob would be the mix between two pickups.
Apr 13, 2015 | Ibanez Music
My ibanez sr700 bass guitar's volume knob is very
To remove the knob, there should be a small hex key or allen screw on the side of the knob. Just loosen the screw. You don't have to remove it.
To tighten the nut properly, you may have to remove the back panel of the bass and hold the potentiometer from the other side. If allowed to turn too much, it could mess up the wiring.
Feb 26, 2013 | Music
Hi there. I bought my friend's Ibanez RG3EXFM1 and the volume knob doesn't work. When I plug it into the amp, I don't get a sound unless I mess with the knob a bit. I opened the guitar up
your gonna prob have to replace knob but try and re sodder the connections. if that doesn't fix it then its your knob that needs to be replaced
Dec 19, 2012 | Ibanez RG3EXFM1 Electric Guitar
Dean razorback db electric guitar knobs
the knob closest to the neck is your volume. And the other two are tone. one is tone for bridge p/u & other is tone for Lead p/u. which is which can vary. you'll just have to listen. hope this helps
Jan 31, 2012 | Dean Razorback Db Electric Guitar
Hi, My Ibanez AEL 20 has a preamp - tuner 5AEQ45F. Tuner works but there is no signal in output jack. Guitar is quite new, and the preamp hasn't been used before. Can I get a PCB schematic diagram...
Remember that while in tuner mode, the audio output is disabled. Try additional presses of the tuner button to see if the audio comes back on. Also verify the volume and EQ gains are turned up. Verify the battery is new.
May 30, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
EQ THEORY
There is no basis for that theory.
Feb 08, 2010 | Ibanez Ts808 Vintage Tube Screamer Reissue
Music Logo
48 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
