My tv has sound but only vertical lines. what may the problem be, i cant see the menu to make any adjustments.
alxz
  • 89 Answers
SOURCE: vertical line picture
problem is caused by the loss of horizontal deflection signal. It is quite surprising that the entire unit is still working, since usually, a loss of H-Out will disable the entire set. Problem can be as simple as loose solder connection to a more complicated defective horizontal circuit. I would suggest havint it checked by a professional TV tech.
Posted on Jul 17, 2008
SOURCE: vertical lines in my ltv 19bg tv
need to reset the remote. Point remote at TV and hold down enter button for 10 seconds.
Posted on Sep 11, 2008
ProMonkey
  • 59 Answers
SOURCE: colored vertical lines with sound no picture
im afraid to say that your display has gone the best thing you can do is call the supplyer of the tv if its under warranty or call samsung. the cost of a new display will be 400 - 500 pounds so you may have to buy a new set.
Posted on Mar 10, 2009
toolkits
  • 1099 Answers
SOURCE: Vertical blue lines appeared on the screen with no sound.
All plasma an LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. Good luck.
Posted on Jun 07, 2010
SD Tech
  • 14553 Answers
SOURCE: can't get rid of coloured horizontol and vertical lines on my tv
The problem is not the signal it is in the set--have the set inspected by a service center or a repair person.
Posted on Apr 23, 2012
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    How do you set convergence
    What is your Make and Model number?
    No picture at all, black screen, audio works , cant work menu cant see it
    sounds like video problem take to tv shop they will address your problem okay good luck
    May 02, 2009 | Televison & Video
    Tv bows
    I have the same TV and just finished having my TV repaired for the same problem. I was unable to converge the colors even in the advanced convergence setup menu. The lines were bowing so far that adjustment was not possible. I had to replace the vertical and horizontal convergence controllers located on the main electronics panel. They require a lot of soldering and should be done by a professional. Unfortunately this is a common "maintenance" repair that happens every 5-7 years, depending on the usage, costing around $500.00 for in home repair. DO NOT USE YOUR TV IF THE CONVERGENCE IS BAD AS IT MY CAUSE THE POWER SUPPLY TO BLOW resulting in addition repair costs.
    Sep 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
    Lines on tv screen
    Picture displaced vertically, picture too high or low
    This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
    Vertical line at the left of the picture
    Replace L506 on A board, replacement part number 1-407-366-00
    Nov 26, 2007 | Televison & Video
    Wanlida LTD-1510
    sounds like filter ac problems dont ajust anthing check for cold solder connections
    Sep 11, 2007 | Wanlida Group LTD-1510 15 in. TV/DVD Combo
    Horizontal lines across the top 2 - 3" of the screen
    Sounds like you have some capacitors that are needing to be changed in the vertical circuit. The cost I cannot quote but, it probably won;t be worth the cost as replacement TV's are much cheaper now. Zeniths and other brands for the longest time have used not controls inside the TV, they are technician adjustments through a service menu only.
    Apr 19, 2007 | Zenith C27A24T 27" TV
    Televison & Video Logo
    15 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
