Question about Aluratek Computers & Internet
I do not know how to pair up my Aluratek AISO1F up. Can you help?
Pairing MacBook Air (2012) with Aluratek 30 pin bluetooth audio receiver please help
I'm not clear what "30 pin" refers to. It sounds irrelevant to your question or am I missing something?
Try this:
Go to System Preferences, click on Sound. Make sure you are on the Output tab. Select your device.
Jun 23, 2014 | Apple MacBook Air
How do I music onto my Aluratek ereader?
First hook your Aluratek to the computer with the USB cord that came with your Aluratek. Then make sure your Aluratek is on. Go to start menu on your computer. Open the computer file it should list your Aluratek along with your computer hard drive. Left click on your Aluratek drive. It should say open. Open it then click on the file that says the type of files you want to move. Books, pictures, mp3's. Now drag and drop the files to your open file. You can also do the same with the SD card rather than the internal memory both will show up as separate devices.
Jul 07, 2011 | Aluratek Libre eBook Reader PRO Black
How do i download things to the aluratek libre?
Jun 25, 2011 | Aluratek Libre eBook Reader PRO Black
I loaded a book on my sd card then put it in my reader then it tells me that it is incompactable I can not figure out how to read it off the sd card or how todownload it from the computer to the sd card...
First make sure your SD card is formatted for your Aluratek. You do that by hooking your Aluratek up to your computer. Turn your Aluratek on with the SD card inside the Aluratek. Go to start menu. Open file named computer. There should be your computer drive your Aluratek and the SD they will be lettered left click on the one for your SD card. It should list format. Click format. Use safe to remove hardware remove your Aluratek and SD card. Now press the reset button on your Aluratek with a paper clip or needle do not use a ball point pen. Now it should be ready to load with anything you want on it. To do that you hook up your Aluratek to your computer open the drive as stated before in your SD or your Aluratek. Now drag and drop your files into the drive you have open. It should now be compatible. I know this works I had the same issue with some of my mp3's.
Jun 15, 2011 | Aluratek Libre eBook Reader PRO Black
Can't find manual For Aluratek AEBKO7FS Libre
You can download and print the instruction manual in PDF format by clicking this link.
http://aluratek.com/media/uploads/AEBK07FS_Manual.pdf
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Mar 11, 2011 | Aluratek Libre eBook Reader Pro
Need a new manual
Go to the Aluratek site: http://aluratek.com/products/ebook-readers and select your model.
There is a link to the manual just before the Overview section. The direct link for the Libre Pro is http://aluratek.com/media/uploads/AEBK01FS-AEBK01WFS_Manual.pdf (for the model that comes without the SD card).
I hope this helps.
Jan 29, 2011 | Aluratek Libre eBook Reader Pro
I dont know how to turn on the flashlight on my aluralek hd 1080p cinecam?
I had this problem and Aluratek did a poor job describing this feature in their product. Use the FUNC/SELECTOR (Circle below the record button) and press it up for flashlight, to the sides and down for other options.
Hope that helps.
Oct 30, 2010 | Aluratek AHDVC03F CINECAM HD 1080p DV...
Aluratek went away and won't show up
I have the same problem with my Aluratek AHDDS100F Sata to usb 2.0 docking unit. It will only work now if I connect it via usb 1.1. I am using a Iomega usb 2.0 pci card.
Aug 16, 2008 | Aluratek AHDU350 USB 2.0 Hard Drive
Computers & Internet Logo
Top Aluratek Computers & Internet Experts
Don Hart
Marcin
Are you an Aluratek Computer and Internet Expert? Answer questions, earn points and help others
