I am trying to figure out why when someone calls me from another station it is not automatically on speaker?
PROGRAMING RADIO STATIONS\
In the recent Pioneer models there is a function called BSM, in which it automatically programs all the radio stations, give it a try!
Nov 15, 2013 | Pioneer FH-P404
I have a KX-TG6700 base station and 4 Handsets. When I have been calling on the handsets I have recently found that there is static on the line. Later I realized that there is problem with the DTMF being...
The KX-TG6700 manual at: http://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdfhttp://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdf
States:
For best performance
Base unit location/avoiding noise
The base unit and other compatible
Panasonic units use radio waves to
communicate with each other.
For maximum distance and noise-free
operation, we recommend the following:
LPlacing the product away from electrical
appliances.
LPlacing the base unit in a HIGH and
CENTRAL location with no obstructions
such as walls.
LRaising the antennas vertically.
LIf you use the handset near a microwave
oven which is being used, noise may be
heard. Move away from the microwave
oven and closer to the base unit.
LIf you use the handset near another
cordless phone’s base unit, noise may
be heard. Move away from the other
cordless phone’s base unit and closer to
your base unit.
Have you considered all these points?
Is there a way you can move the base station to another location in your house to see if the problem get better? I don't beleive your base station is faulty, I suspect interference from something.
I don't think the 2.4GHz set is causing any issues, but you never know, try unplugged it for a while to investigate.
If you do determine that the base station is faulty there probably isn't many options to get it repair other than sending it to Panasonic. May be cheaper to buy a new base station to go with your extra handsets.
Good Luck!
Mar 14, 2008 | Lands Phones
When I try to call out or if someone calls I can't
You have not given the model no of the handset OK any ways its may problem in your speaker or speaker ways so change the speaker and check the connections well best of luck
Aug 31, 2011 | Cell Phones
My message button is flashing on my Toshiba DKT2020SD phone, telling me i have a message. When i press the Msg button, it it calls another phone extention in another office and i hear that it is on speaker...
This is what I wrote up for our inhouse manual on telephone administration for this phone:
Problem: An employee pushes the Message button to receive a message but it calls someone else's desk. This is caused by whichever extension the phone forwards to when pushing the Message light. For example: if the person at 333 pushes their blinking message light and it forwards to 316 that means that the person at 316 most likely tried to call 333, got a busy signal and accidentally pushed the Message button before hanging up thus setting 333 to call forward to their extension when they got off the phone.
All phones on our system should have this feature turned off, but if it happens this is the two step process to resolve the issue:
Solution: First, push the Message button to figure out which extension it is forwarding to. Take note of the extension and hang up. With the hand set NOT picked up, dial #409 and Release. You may have to do this multiple times to clear the call forwarding because it needs to be done for each incidence that the person accidentally set up call forward. Finally, in the management software go to Station > Station Assignments. Select the extension # that the Message button was forwarding to (the one you noted above). Under the Basic tab at #41 Active Message Waiting select Disable. Select Submit.
Aug 29, 2011 | Toshiba DKT2010SD Phone
Radio
Hello george_nutti,
The model number you posted is for a center channel speaker which has no controls, and not knowing the exact model number it's difficult to be specific.
Some Kenwood KDC models allow you to select one of 3 "tuning modes", 1) AUTO1 - Automatic search for stations; 2) AUTO2 - Search Preset stations; 3) MANUAL - Normal manual tuning control. If your Kenwood is one of these models, you need to set the tuning mode to MANUAL. For Kenwood Excelon HD receivers, direct access tuning is done by using the included remote. 1) Press DIRECT button on the remote; 2) Press number buttons to enter desired channel number; 3) Press DIRECT button again to exit direct tuning.
Hope this helps.
Sep 08, 2009 | Kenwood KSC-310CCS Center Channel Speaker...
Norstar M7310 phone doesn't ring and doesn't pick up calls
You can look at the manual here:
http://www.fixya.com/support/p98000-norstar_m7310_corded_phone_nt8b21ac03/manual-34096/page-3
Jun 24, 2009 | NorStar M7310 Corded Phone
Automatic redialling isd call from my phone nokia n70
someone has hacked your phone or your sim and is making full use of your phone. Whether file a report in police station or change the o thats the only thing you can do. after filing the report the person who is using your phone will be behind the bars.
actually you can save yourself from that person by changing the software of your phone
pls rate me thank you
Feb 14, 2009 | Nokia N70 Cellular Phone
Speaker picks up automatically
callers maybe calling you and than pressing 1 to voice call you. Dialing your extensions than 1.
Pick up the handset before pressing speaker.
Mar 12, 2008 | NEC Electra Elite 32D-1 Corded Phone
15 people viewed this question
 Grubhead
Grubhead
