Hi-Fi S.XBS MH2001 needto connect to a flat screen tv. Can you please give me step by step instructions on how to set them in in order for me to hear the TV sound through them
3 Suggested Answers
  • 4924 Answers
SOURCE: RE: Logitech MH2001 Hi-Fi S-XBS Wireless
the issue is to pair the headphone with the transmitter ..which has to be connected to the exit signal in the computer or device of choice ..
Both have to be powered (batteries or cord) ..and tuned ([paired ) so that the radio signal to be received..
In sort get the signal from the computer 's outlet..and turn the transmitter on ..and be sure it is emitting the radio signal ...after that all you have to do is tune the headphones to receive the signal ..if they do not have a permanent frequency ..
Posted on Jan 04, 2011
  • 1557 Answers
SOURCE: Logitech MH2001 Hi-Fi S-XBS Wireless....How
they slide into the back slim panal via the bottom of the base
Posted on Mar 01, 2011
How do I activate HBO on Netflix on my Smart TV?
You must have a direct internet connection or a WI-FI connection to the internet established on your tv. This is done in the set up menu. Once you have that then it will give you step by step instructions on how to access you movies/netflix
Dec 26, 2015 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
My router type is WRT54GR and does not connect my Philips TV
1. Make sure your WRT54GR router is operating in wireless mode.
2. (a) if your Philips TV has Wi-Fi built-in, go to Step 3.
(b) if your Philips TV does not have Wi-Fi built-in, check to see if it has one (or more - unlikely) USB port. If it does, check with Philips technical support if that port will accept a USB-based universal Wi-Fi adapter. If they say yes, go buy one and plug it into the USB port on your TV and go to Step 3.. I bought a universal Wi-Fi adapter for my Sony Bravia TV at Walmart a few years ago for $50. You can also ask Philips support if they can recommend one certifified for your TV model.
3. Use the Menu or Settings button on your TV's remote to set up a network connection. Follow the on-screen instructions or use the TV's manual.
If the suggestions in 2(a) and 2(b) do not apply to your situation, there may be a third solution: using a powerline networking kit, but this is more complicated, costlier and requires that your TV be equipped with an Ethernet jack.
Hope this helps.
Oct 19, 2014 | Computers & Internet
No audio from TV through Wireless Headphone
Unfortunately, this product has a reputation for unreliable operation. Many Amazon users report that they can't get it to work with their TVs. To isolate the problem, try plugging a good set of wired headphones into your television; if you hear nothing, then the TV is at fault. Otherwise, try plugging a different, known-good adapter cable into the TV. If you still don't get sound, then the Genica is broken.
Dec 26, 2013 | Genica MH2001 5-in-1 Hi-Fi S-XBS Wireless...
Just bought an open box LG LED 42 inch TV. I got a couple questions. 1. What is the recommended way of cleaning the screen? 2. How do I get it to recognize my wifi? 3. Please provide me a link to an...
Hi Rob,
Here's the link to the product support webpage for your TV. The full manual can be downloaded here (Click "Support," and the link is under "Documents" on the right side of the screen.)
From the manual, here's what it says about cleaning:
thomascha103_1.jpg And in order for the TV to recognize your wifi, you'll need to plug in a wireless network adaptor to one of the USB ports. (network adaptor sold separately.) Follow these instructions to establish a wifi connection, and then follow the on-screen instructions for wifi/network settings. Or for details on how to adjust your wifi/network settings, see pages 58 and 59 of the manual.
thomascha103_2.jpg That's kind of hard to read, but it says.
"The LG Wireless LAN for Broadband/DLNA Adaptor, which is sold separately, allows the TV to connect to a woreless lan network.
The network configuration and connection method may vary depending on the equipment in use and the network environment. Refer to the setup instructions supplied with yur access point or wireless router for detailed connection steps and network settings.
1. How to connect
Connect the "LG Wireless LAN for Broadband/DLNA Adaptor (sold separately) to the USB IN 1 or 2 port on the TV.
2. How to use
Select "Network Setting" in the NETWORK menu
After connecting, you can use the NETCAST menu"
Best of luck!
Jan 12, 2011 | LG 42LE5400 42 in. LCD TV
I want the user manual of mh2001 wireless headphone
I need manuel for MH2001 HI-FI S.XBS. I want to be able to chat.
Jun 27, 2010 | Logitech MH2001 5in1 HiFi SXBS Wireless...
Connecting TV to Hi Fi wirelessly
There are several different wireless receivers that you can consider.
A simple solution would be the following:
Both devices being connected must support the ARC feature. HDMI ports may be marked with ARC to show which one to use. If not, check your product manual or specifications to see if the ARC feature is supported.
If you find that your TV, A/V receiver or home theater system does not support ARC, you will need to use Option 2: Coaxial Digital Cable, Optical Digital Cable, or Audio Cable to connect your devices.
Make sure that both devices support ARC functionality.
Make sure that the TV and receiver are connected using an HDMI cable.
Connect the cable to the HDMI port that is labeled ARC or the port identified in your manual that supports ARC.
Turn on the Control for HDMI setting on both the TV and the receiver or home theater system.
NOTE: The steps required to enable the Control for HDMI feature may vary. Check the operating instructions supplied with the devices for model-specific steps.
Apr 18, 2017 | Televison & Video
Humming tv
Try Vance Baldwin for the part.
Apr 09, 2008 | Vivitek V37835 46 in. LCD Television
Downloading music from internet to an MP3 player
I guess Sanyo means that have an input jack (line in or aux) where you can connect your mp3 player (after you've downloaded music into it), then hear it on your hi-fi.
Just make sure you connect either the line out or the earphone jack from your mp3 player to the aux or line-in on your hi-fi, then set the hi-fi to play aux or line-in.
Oct 29, 2007 | iLO (2 GB) MP3 Player
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
