Question about OKI Office Equipment & Supplies
Appeared a fatal 929 error on my oki c910 printer. what do I do?
SOURCE: Oki C5200n 002: Fatal Error
We have to change firewall settings in our Fios router. I just don't know which ports or udp to open.
Posted on Jan 08, 2008
  • 97 Answers
SOURCE: OKI C7300 Printer
moz-screenshot-1.jpg Unfortunately it's a Hardware problem.
If you bought it from a dealer, contact them.
Error 020
When an error has occurred in the controller board (CU) or the program Rom.
Resolution:
Replace the Rom Dimm, see chart below for the correct part number. If the Rom Dimm does not correct the issue, then replace the (CU) controller board. Please refer to the service manual for (CU) part number depending on the printer revision
Posted on Dec 07, 2008
  • 9 Answers
SOURCE: fatal error 122 on a oki c5200 printer
YOUR DRIVER CD IS CURREPTED.ANOTHER DRIVER CD USE.
Posted on Jun 23, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
  • 97 Answers
SOURCE: My Oki C9600 Printer showed an error message,
940: Error
Waste Toner Transfer Error
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
Posted on Mar 29, 2010
Oki c7300 Fatal Error
all oki errors are fatal errors, there will be a 3 digit number that will tell what the error actualy is
Jun 02, 2014 | OKI C7300 Led Printer
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
929 fatal error on my oki 9600 printer
This is a very unusual error. 929 refers to the waste toner motor not running properly. Remove the waste toner bottle and put a hoover to the outlet to the bottle in case the toner is hard and blocking the exit of toner into the bottle.
Jun 30, 2011 | OKI C9600hdn Laser Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
My Oki C9600 Printer showed an error message, Reset Drum Basket - Waste Toner Transfer Error. After removing and replacing the toners, drum and waste toner bottle a new message appeared, 940: Fatal Error....
940: Error
properly.
printer).
board.
toner.
Dec 21, 2009 | OKI C9600hdn Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
'928 Fatal Error message' on OKI C5550MFP
928 - fuser motor lock error
take out fuser and check for paper stuck on roller
make sure roller can move
if roller is stuck or damaged, repalce fuser unit
Apr 11, 2009 | OKI C5550N Multifunction Printer - Color...
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Have OKI c5200 Printer Message window reads Service Call 030: Fatal error Mac Mini OSX system What do I do? Prior to Message  Black Ink cartride was low and replaced cartridge after message appeared
I had the same error with an Oki C9600N. Called OKI, and was told one of two things has apparently gone bad: a DIMM (in slot 1) or the controller board. I removed the RAM, cleaned the contacts, blew out the slots (w/canned air), and reseated the RAM. Printer is back up and running. Hope this helps someone.
Feb 02, 2009 | Office Equipment & Supplies
Fatal error 172
From OKI error list:
Error 172 - Upper Heater Temp State: High
Heat Roller Thermistor indicates high temp
Solution:
Turn off printer, let cool down.
If problem still exists seek service
Mar 07, 2008 | OKI C5300n Led Printer
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
