Question about Filter Vacuums
What size filter do I need for a HEPA air filter Progressive 295
4 Suggested Answers
  • 1673 Answers
SOURCE: Kenmore progressive Direct Drive Vacuum w/Hepa
Check the hose and dirt inlet for a blockage. Also the brush roll, check it to see if you can turn it or not by hand. If not, then something may have jammed it.
Posted on Jun 01, 2008
the filter should be easily accessable on the right side of the vacum cleaner if it's facing you. at the base of the vacum there is a large round cover that is removable and behind it it the filter. generally you dont need to replace it. its a big round spunge that you could rinse with water and squeeze out until it's clean. you also need to rinse the filter cover which is like a plastic netting. let it dry for 24 hours and you should be good to go!
Posted on Aug 19, 2009
  • 102366 Answers
SOURCE: I just inherited a Kenmore
Posted on Jun 13, 2011
What would happen if I would take out both hepa filters from my rainbow e-series? I do need extra super filtering - previous versions didn't have it and it was ok... Hepa filters are not so expensive...
It won't hurt anything if you don't have a problem with the tiny particles that will be blown into the air. The Hepa filters trap small particles that can be unhealthy to breath. Most of these particles consist of human skin and hair, pet dander, dust mites, etc.. Many people are not bothered by these tiny particles. Others, like asthmatics, can have serious complications from them and the Hepa filters really help.
Nov 24, 2011 | Rainbow E series Canister Wet/Dry Vacuum
How to install the back hepa filter on canister vacuum cleaner. We are not sure which direction the air flows and therefore which way the arrows should point. Should the arrows point into the vacuum...
The arrows in this case should point out of the machine. not into the machine. This is because you want the black rubber seal to seal on the machine and force the air through the filter.
Good luck.
Nov 10, 2010 | Kenmore 25512/ 25513 Progressive Canister...
How do I open the canister to replace my vac filter EF-1?
There should be a cover on the top of the unit that says HEPA filter. There should be a little finger groove there to grab the cover and pull it off. Sometimes you may need a screwdriver or butter knife to get it open. The filter will be under that cover.
Good Luck,
Nov 07, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore progressive 360 vacuum cleaner has low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Kenmore 35912 / 35913 Progressive Upright...
May 03, 2008 | Kenmore 31913 Progressive Direct Drive...
Looks like there are is an 2 indentations on the back, these are tabs, push them in and push the cover up, it should come off.
Jan 29, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore progressive vaccuum
Did you replace the hepa filter with a new one? Those filters may not look bad, but after a period of time and use, air is restricted thru them. They should be changed at least once per year.
Sep 03, 2007 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
18 people viewed this question
Top Filter Vacuums Experts
Shekar Avadhani
Are you a Filter Vacuum Expert? Answer questions, earn points and help others
