Question about Pool & Spa
My hayward pump is making a high pitched noise however it is still working? Just too noisy
    President:
  • 1,378 Answers
The motor bearings are failing. A local electric motor repair shop should be able to fix it rather inexpensively. You should probably have the pump seal replaced at the same time.
Posted on Jul 26, 2009
How to fix a noisy water pump on a grand jeep Cherokee 2007 3.00 deseil
a noisy water pump ( low growl or rumble noise) is a problem bearing and the cheapest fix is a new water pump
squeaks or other high pitched noises can be tested with soapy water on the belt--noise will stop for a short period of time
If the water pump housing is cast iron, you may be able to get a repair kit for the pump but the cost of the kit and the labor to do the job is generally around the price of a new pump
Dec 10, 2016 | 2007 Jeep Grand Cherokee
My 2hp hayward super pump is just out of warranty and has begun leaking. It also has a high pitched whine which comes and goes. Does that mean waters gotten into the bearing and if so can I replace it?...
Yes, water may have entered into the motor, mainly into the front motor bearing, where it washed away the lubrication. This will only make the noise louder and will need to replace the bearing. otherwise it will eventually seize and no longer work.
Apr 23, 2014 | Hayward Super Pump 2hp, Sp2615x20
My Hayward pump was very noisy but now trips the breaker. I can turn the impeller from the rear pretty easily.
Hayward is synonymous with junk. Let me guess. It's been in service for about two or so years when the noise started. Eventually the motor will burn out. I've gone through two motors and a diffuser on my Hayward pump. It's already making noise again.
Jul 16, 2012 | Hayward Pool Products Hayward Power Flo LX...
My Hayward Tristar 1.50 HP pump is 3 years old, and recently developed a high-pitched humming noise that is causing a noise disturbance. The performance seems to be operating okay, but it never used to...
sounds like the bearings are going out on the motor. The noise will increase as they wear out more until it locks up and throws the breaker. You can have the motor rebuilt or just replace the motor. Consult a pool professional to help out with this.
Nov 22, 2010 | Hayward TRISTAR PUMP 1.0 HP, 115/230V
Noise at pump
Your problem is just a little vague. Noise could be several things including.... vibration can cause noise especially if the pump is not sitting solid on the ground. Cavitation around the impeller can cause the pump to be noisy. something stuck in the impeller can not only cause a number of irregular noises, but also affect performance. If the bearings are going bad they can make a number of bad sounds; anything from just sounding a little noisier than normal or a loud grumble to a loud high pitched squeal the can make a banshee turn and run.
Sep 18, 2010 | Jandy PHP High Head Pump 2 HP Up rated
Fuel pump is noisy is brand new but makes load high pitch noise
different style drives in pump one was impellar the other is turbine
Jul 23, 2009 | Chevrolet 1500 Cars & Trucks
We have a hayward pump and the motor keeps stopping and tripping the circuit breaker. What could it be?
The motor might be too powerful for the line it's on, (usually a pump should be on a somewhat dedicated line) no Ac's running on same breaker.
An extension cord longer then 6ft is also a suspect in not allowing the pump the draw enough power.
The pump may not be drawing enough water, overheating and tripping the breaker, or the motor might have rust on the inside causing the armature not to spin freely, and shut off. (usually motor will make a high pitch noise) while running)
Jun 29, 2009 | Hayward Pro Series 18" Above Ground Pool...
Noisy pool hayward pump
Dont run pump any longer. Could damage it further. Recommend overhaul at qualified well established pool repair shop. If unset of noise suden probally somethign stuck. If onset of noise gradual probally bearing. Kirk
Feb 14, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hyundai Excel 1990
fuel pump and filter
Sep 24, 2008 | 1990 Hyundai Excel
Pool & Spa Logo
1,794 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
