Model ARWDF129NA. Ariston Combo Washer/Dryer - I need to replace the Control Knob and do not know how to remove the front control panel to get to it.
  • Gail Jun 28, 2017
    Thank you for all the answers. My machine is in an RV in a tiny closet space, so removing that top panel is just not that easy, but I suspected it might be the case. I am still trying to locate someone in the Victoria, British Columbia, Canada area that might do it for me. I am unable to rate any of the replies as I have not yet fixed my problem. But I do appreciate the time spent by all of you in replying. Thank you.
jaylex
  • 417 Answers
SOURCE: Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Posted on Feb 05, 2008
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
  • 116 Answers
SOURCE: How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
Posted on Aug 02, 2008
vickygomar
  • 460 Answers
SOURCE: How to remove front panel of dryer
Be sure to unplug the machine from the mains,
1.-Remove the top cover of the machine, very straight forward.
2.-Unclip the universal coupling from the main timer to the back of the knob.
3.- The whole knob assembly is held in place by a backing plate.
4.- There are 2 clips at the top of this backing plate raise them and the backing plate and knob can be pulled out.
5.- there is a plastic clips but be careful not to break it.
Your ffeed back and ratting are so important for me. thank you
Was this helpful?
The knob breaks when it has been turned in the wrong direction several times. It's a safety device so as not to damage the main timer.
Posted on May 21, 2009
SOURCE: how to replace the selector control knob on a
Push-in center knob and and turn Counter Clockwise to loose it from the treaded shaft. Next, without Pushing in, continue turning CC till it comes off.
If necessary, remove the outer indicator knob by sqeezing the two release clips in the center. This knob is keyed to only go back on one way so you don't need to remember its location before removal.
Reverse the process to install new knobs.
Oh, if you need to replace the cam or timer which are behind these knobs, the front panel will have to be removed by first removing the top cover of the washer. Now you can access the six screws inside the washer and one in front behind the detergent dispenser.
Posted on Aug 25, 2009
I have an ariston washer dryer combo. today I turned it on to do a wash cycle. the knob no longer clicks or shows the times of other cycles. I've turned it off and on a few times but nothing helps
Ariston armf 125 washer dryer combo - YouTube
? 4:14
www.youtube.com/watch?v=zPtG5Q3qQ3Q
Oct 23, 2010 - Uploaded by troykm Rinse cycle. Correction - it does do 3 rinse cycles!! :-)
[PDF]Instruction Manual - Ariston Appliances
aristonbrand.com/media/WDG-8629-User-Manual-19510586801_AU.pdf
WASHER-DRYER ! This symbol reminds you to read this instruction manual. ... from its packaging. 2. Make sure that the washer-dryer has not been damaged.
Sep 22, 2015 | Washing Machines
Thanks J
Feb 05, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Need part number for door glass replacement Ariston ARWDF129NA
it is the whole door and glass. C00277532
check this link http://r.search.yahoo.com/_ylt=AwrBT8FtQthU9zQASwhXNyoA;_ylu=X3oDMTByMG04Z2o2BHNlYwNzcgRwb3MDMQRjb2xvA2JmMQR2dGlkAw--/RV=2/RE=1423487725/RO=10/RU=http%3a%2f%2fwww.guaranteedparts.com%2fpicture_library%2fAriston%2fARWDF129NA.pdf/RK=0/RS=MKzVwRgG.yYF8eJHJVxrlf8MM_U-
Feb 06, 2015 | Hotpoint-Ariston ARWDF129NA Washer
Ariston washer/dryer arwdf129na
F04: Overflow and Pressure Switch Empty found at the same time (Pressure Switch stuck on Empty)
Overhaul CN1
Overhaul Pressure Switch Contacts
Control CN1/Pressure Switch Continuity
Replace Pressure Switch
Replace Card
Dado
Apr 23, 2014 | Ariston Technologies Washing Machines
F13 error code on Ariston washer dryer combo
Model ARMF 125 with same error code F13 how to fix please advise Thks
Nov 06, 2011 | Hotpoint-Ariston ARWDF129NA Washer
I need to replace a broken knob for a kenmore 24" stacked washer/dryer Model 11108875279
Their are a total of 5 knobs on the control panel for that laundry center i do not know which knob one you need so this link is for the parts breakdown of the control panel http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-dryer-combo-Parts/Model-11088752792/0582/0152000/P0403242/00001?blt=06&prst=&shdMod=
Gene
Aug 11, 2011 | Washing Machines
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
